Old 12-10-2015, 10:17 PM   #201
Advanced Design
Advanced Design's Avatar
Re: 1940 Packard 120 Convertible Restoration
Thanks for showing the steps you went through on this one. Nice work!
Advanced Design is offline   Reply With Quote
Old 12-14-2015, 09:09 AM   #202
Low Elco
Man, that's nice. Please keep it comin'!
Low Elco is offline   Reply With Quote
Old 12-22-2015, 08:31 AM   #203
theastronaut
theastronaut's Avatar
Thanks!
I started fitting the middle and rear floor pan sections last week. The edges needed trimming, indentions were added for the body mount bolts/washers, the outside rear corner was trimmed to fit around the inner fenderwell, and I also started drilling for plug welds.
I also offset the end of the rocker to make the B-pillar bottom fit flush. This seam will be leaded over once it's welded in. With the rocker offset finished I can extend that end of the rocker rearward 8-10", and that will finish the rocker.
theastronaut is offline   Reply With Quote
Old 12-22-2015, 10:33 AM   #204
flashed
Simply AMAZING what you do with metal ,you are a very talented artist .
flashed is offline   Reply With Quote
Old 12-22-2015, 11:02 AM   #205
MP&C
MP&C's Avatar
Beautiful work John!
Robert
MP&C is offline   Reply With Quote
Old 12-22-2015, 12:56 PM   #206
Bomp
Bomp's Avatar
You got this!
Great work, will you do an indepth write up on leading?
Bomp is offline   Reply With Quote
Old 12-24-2015, 06:51 PM   #207
duallyjams
duallyjams's Avatar
I meant to call the shop to wish you and family Merry Christmas but got tied up verses here but I'm sure you will have a good one.
James
63 GMC V6 4speed carryall
65 chevy swb bbw V8 auto
68 K20 327/4 speed, buddy buckets
2002 GMC CC Dually Duramax
64 GMC lwb 3/4 V6 4speed SOLD
66 GMC swb bbw buddy buckets SOLD
IG duallyjams
The only thing that stays the same is constant change!
duallyjams is offline   Reply With Quote
Old 01-20-2016, 04:21 PM   #208
theastronaut
Appreciate it flashed!
Thanks Robert!
Originally Posted by Bomp View Post
You got this!
Thanks, I posted videos earlier in the build but I can do a better/separate step-by-step when I get around to the other sections. It's pretty interesting to work with.
Appreciate that James, hope you guys had a great Christmas as well!
Old 01-20-2016, 04:27 PM   #209
theastronaut
Been awhile since I updated this. Pretty much everything I've been doing lately is a copy of the other side so it was fairly boring/repetative. I didn't keep up with documenting this side as well as I did the first side since it's basically the same thing.
With most all of the new panel fabrication finished, I pulled everything back out to wash with PPG DX579 and DX520. This cleans any light surface/fingerprint rust off from handling the parts while their bare metal and preps them for epoxy. Forgot to get an after pic, this is before washing. The smaller parts were blasted before epoxy.
The center seam will be butt-welded down the length so it will apear as one piece. To butt-weld a seal like this it'll need to be plannished like I did the quarter panel seam to eliminate any distortion. I can't reach both sides so I'll need someone to hold the dolly on the other side. I marked both sides with the same layout so we can both stay in the same place.
I've started welding in the floors and inner rocker, same process as the other side.
Old 01-20-2016, 09:01 PM   #210
Advanced Design
And that is how a talented professional does it. The reference marks are a good idea for the planishing work.
Old 01-27-2016, 04:13 PM   #211
theastronaut
I think it was on the show American Hot Rod a few years back, they were flattening a floor seam before applying seam sealer. The two guys were having trouble staying in sync with the hammer/dolly. Adding the marks should keep the reality show drama out of the shop.
Old 01-27-2016, 05:23 PM   #212
theastronaut
I have the pans and inner rocker welded in, so I moved to finishing the A-pillar bottom. I tacked the inner A-pillar in place and stuck the outer skin over it to mark the size/location of the hinge holes. Used a carbide burr to open up the holes almost all the way, then a step-bit to get to the final size which also cleans up the edges.
Squared up the other opening with a rectangle file.
Inner A-pillar welded, smoothed up, and mopped with epoxy.
Used tape to locate the edge of the outer skin, this will help with trimming the outer layer to size without having too big of a gap.
Outer skin stuck in place, another layer of tape placed over the first piece. The bottom edge of the tape will be the cut line.
Outer skin welded in place, welds smoothed.
Inner A-pillar brace welded in.
Inner cavity mopped with epoxy after welding.
And a "work in progress" shot. Currently working on getting the outer rocker ready for welding.
Old 01-27-2016, 07:42 PM   #213
flashed
Wow ,it's looking like a car again ,still amazing .
Old 01-28-2016, 12:18 AM   #214
swamp rat
swamp rat's Avatar
Just caught back up on this thread, as usual my head is spinning looking at your work!
I have been curious how often, if at all, you are adjusting the turn buckles?
Also the first time i have seen someone duct some heat on an area before welding, does that help stabilize the part??
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline   Reply With Quote
Old 01-28-2016, 12:43 AM   #215
theastronaut
The cab section is starting to shape up. Won't be long until it's finished.
Thanks! The only adjustments I made were back when I adjusted the turnbuckles to fit the doors. Once the body was squared up and the doors gaps and body lines were corrected I added more bracing to maintain that alignment. To simplify body mounting in the future I have used the same shim stack height at each major body mounting point. I do expect slight shimming to be needed once the bracing comes out and the current solid steel shims are swapped out for rubber mounts, but I'm hoping its minimal.
The hoses are actually for pulling out welding fumes. It's way too cold to have the shop doors open this time of year! I threw it together using an 8" fan and duct parts from Lowes. Works very well for a quick/inexpensive home brew job.
Old 02-02-2016, 02:48 PM   #216
Low Elco
Beautiful as always. I dig the fume fan, do you find it drawing off your weld gas, or is it far enough away?
Old 02-02-2016, 03:48 PM   #217
theastronaut
It has two speeds, if it's too close and pulling the shielding gas away I can lower the fan speed.
Old 02-23-2016, 10:53 AM   #218
theastronaut
I have the rocker, inner and outer B-pillar pieces, and the lower cowl panel welded in.
Next step is to get the lower quarter panel fitted and welded in, then start leading the seams. To position the quarter I set the door in place to match quarter bottom to the door bottom and make sure the bottom edge carried the same line. The edge of the door (black) was blending into the black frame so I added blue tape to the edges of both panels to help visualize the line better.
Fitting and finishing the cowl panel:
B-pillar brace.
Rocker in:
Old 02-23-2016, 11:02 AM   #219
theastronaut
Since the door was out I took a few pictures. You might want to make sure there are no children around when you scroll down, it's pretty scary...
They're patched up so bad that they won't fully fit in the door jamb without hitting the rockers. Now it makes sense that the old rockers were bashed in and bondo'd as bad as they were. Like the rest of the body, the door is fixable with enough work but it would make more sense to just start with a better door if we can find one.
And that's just the bottom... the middle of the inner skin somehow rotted out. Very unusual place to have rust holes.
If that wasn't bad enough, most of the inner front edge is rusted through.
Old 02-23-2016, 12:09 PM   #220
MP&C
MP&C's Avatar
That door looks like a good project for Rock Hill! Come back with new inner door and new door skin...
Your work is looking stellar John, gives the owner a good perspective looking at the inner door next to it..
Robert
Old 02-23-2016, 01:16 PM   #221
flashed
From what I have seen you do with the rest of the car I think you could build a door blindfolded .
Old 02-23-2016, 04:00 PM   #222
duallyjams
duallyjams's Avatar
The rust in the middle of the door is the water line from being submerged under water.
James
IG duallyjams
Old 02-23-2016, 06:30 PM   #223
67ChevyRedneck
67ChevyRedneck's Avatar
Can 1940 Packard doors even be found???
Jesse James
1967 C10 SWB Stepside: 350/700R4/3.73
1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc
1968 Pontiac Firebird: Project Fire Chicken!
2015 Silverado Double Cab 5.3L Z71
2001 Jeep Wrangler Sport 4.0L 5spd
2020 Chevrolet Equinox Premium 2.0L Turbo
2011 Mustang V6 ~ Wife's ride
American Born, Country by the Grace of God
1967 CST Shop Truck Rebuild!
My 1967 C-10 Build Thread
My Vintage Air A/C Install
Project "On a Dime"
Trying my hand at Home Renovation!
1965 Mustang Modifications!
67ChevyRedneck is offline   Reply With Quote
Old 02-23-2016, 06:46 PM   #224
Russell Ashley
Russell Ashley's Avatar
Makes me wonder if another restoration shop did the door like that. One thing for sure, the restoration that is in progress on this car now could be used as a text book on how to do it correctly.
Russell Ashley is offline   Reply With Quote
Old 02-23-2016, 07:00 PM   #225
68Timber
I know the pieces fit
68Timber's Avatar
And before lunch. Packard or not, I bet it wasn't done this well when it was built.
John
79 2wd Blazer (Bruiser)
85 M1009 Blazer (Sarge) build
74 Honda Z50 build
