Old 07-10-2015, 09:45 PM   #201
slimneverdies
slimneverdies's Avatar
Re: My 89 CC Dually: Double Wide
I know you know better
Long live SLIM
At least try to buy American
slimneverdies is offline   Reply With Quote
Old 07-18-2015, 11:49 PM   #202
SCOTI
SCOTI's Avatar
Gauges/bezel done. Speedo & tach both work. Something weird going on w/fuel gauge when using the pass side tank. Gotta research that one.....
Got the crossover duct installed for the drivers side a/c vent.
Adjusted the toe. Much better.
Progress.....
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 08-25-2015, 01:17 PM   #203
SCOTI
SCOTI's Avatar
Still finishing up on my side project w/my buddy & his boys. We're working on cleaning up the wiring now & hope to have this thing ready to fire up again soon (1st time in over a year).
Over the last year or so, it's had:
  • Rear suspension rebuilt & upgraded (boxed arms, shock relocation brackets, bushings, shocks, & some 10" wide ralleys added).
  • Front suspension rebuilt, lowered 2", 1.25" F-body sway bar added & some 7" ralleys.
  • Roof re-skinned (had a crudely patched up section where an old sunroof resided) + new vinyl top.
  • Floor pans replaced.
  • Engine re-gasket/re-seal + engine bay clean-up & detail work.
He's already aquired all the needed parts to swap in some era correct bucket seats & the SS console shifter so the interior is right around the corner too. His boy is soooooo ready to start pounding the streets!
Hope to have my dually up soon for front end aligning & then off to get the bed Line-X'd.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 08-26-2015, 09:57 AM   #204
aggie91
I'm just glad to be here!
aggie91's Avatar
Good looking El Camino. He does look ready to go!
Hope to see the dually done soon...
Karl
1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues)
http://67-72chevytrucks.com/vboard/s...d.php?t=372424
The LST Challenge:
http://67-72chevytrucks.com/vboard/s...=1#post7812257
Korbin's 1st Square: "Sunburn"
http://67-72chevytrucks.com/vboard/s...d.php?t=418618
1985 GMC Sierra: "White Trash", Korbin's 2nd now...
http://67-72chevytrucks.com/vboard/s...d.php?t=632305
Henry - 1984 Chevrolet, Owen's 1st Square
aggie91 is offline   Reply With Quote
Old 09-29-2015, 08:12 AM   #205
n2billet
Village Idiot....
n2billet's Avatar
Any Dually progress?
http://www.hubgarage.com/mygarage/n2billet
-67 SWB Custom Porterbuilt Front and rear 20/22's Hazel Sold
-71 StepSide Porterbuilt Stage 2 with 20/22's Stella Mae Sold
n2billet is offline   Reply With Quote
Old 09-29-2015, 09:40 AM   #206
SCOTI
SCOTI's Avatar
Is waiting progress??
My side project is complete (the part I helped with anyway). My trailer will be empty & the elcamino parts occupying space in the shop are w/the camino or have been recycled/trashed. Now back to the dually.
I did swap in new inner/outer tie-rod ends last night. They were the last items on the front suspension that had not been done & I wanted to have everything fresh before aligning. My buddy assures me that he will have time to align the front end (& check rear thrust) before this Friday. Hopefully this happens. Then I'll move forward on the bed + stereo completion next week & try putting some road miles on it to work the bugs out.
I'll swing by your place hopefully during some of those miles (and a car wash... that thing is filthy) since I'll be on that side of town using the dually to bring home my 64's chassis.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 09-29-2015, 11:24 AM   #207
aggie91
aggie91's Avatar
Does this mean you are going to need help swapping bodies on to that chassis for the '64 this year? Last time we talked about it you needed some help to get it done and you have that frame I could use when you get that swapped around...
Karl
The LST Challenge:
Old 09-30-2015, 09:28 PM   #208
SCOTI
SCOTI's Avatar
I hope to start swapping it over but who knows. When I do it, I'll be getting creative & prob do it solo. Too dang hard trying to get help/people aligned so I try to plan/prep to do it on my own.
I did pull the dually out last night after work to reset the toe. After moving forward & backing up a dozen or so times I have it close. I also yanked an 1/8" shim from all 4 spots for some slight neg camber @ my planned ride height (~27" @ front wheel well C/L).
It still has something wrong mechanically. If it idles for extended periods (6-10 mins), you can hear slight backfiring in the exhaust. I noticed it before but thought when I heard it yesterday I would just drive it around my neighborhood & see if that helped clear it up. After the 3rd time around the circle (~7/10th of a mile), I put my foot into it aggressively & it does it then as well. I don't know what it could be @ this point & can't seem to find much TBI support/help locally. Frustrating.
No alignment yesterday.
No alignment today......
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 10-08-2015, 09:08 AM   #209
SCOTI
SCOTI's Avatar
Progress!!
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 10-08-2015, 09:22 AM   #210
68Timber
I know the pieces fit
68Timber's Avatar
So clean.
John
79 2wd Blazer (Bruiser)
85 M1009 Blazer (Sarge) build
74 Honda Z50 build
Old 10-08-2015, 10:48 AM   #211
MTCK
MTCK's Avatar
Looks real good. Getting close!
-Marcus
1991 V3500 L29 454 4L80E NP205 D60/14 Bolt 4.56's
1984 K30 292 TH400 NP205 D60/14 Bolt 4.56's flat bed 7'6" Meyer Plow
2022 Silverado 3500 L8T
Project Daily Driver
Project Heavy Hauler
Project Plow Truck
MTCK is offline   Reply With Quote
Old 10-08-2015, 12:00 PM   #212
slimneverdies
I tried to skim through the entire thread but didn't find it but what size are those rolling sleeve airbags in the rear??
Long live SLIM
Old 10-08-2015, 12:42 PM   #213
SCOTI
SCOTI's Avatar
Ride Tech p/n 90002107 (Firestone)
6.5" min height
10.5 installed height
13" max height
9" OD
It's the bag they supplied for their original 'bolt-on' C-30 HD Air Bar kit.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 10-08-2015, 03:28 PM   #214
slimneverdies
6.5" min height
13" max height
9" OD
Thanks. Just order me a pair
Long live SLIM
Old 10-18-2015, 01:26 PM   #215
SCOTI
SCOTI's Avatar
Installing the bed solo was a PITA but I got it done. The additional weight made a noteable difference in ride quality which was a relief.
So w/that accomplished, I scraped off the 3yr expired registration/inspection stickers, knocked off the heavy dust, plugged in all the lights & cruised up the street for it's maiden voyage beyond my neighborhood.....
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 10-18-2015, 02:49 PM   #216
tinydb84
tinydb84's Avatar
Any pics with it aired down?
David
Instagram: myfabguy
Old 10-18-2015, 03:20 PM   #217
SCOTI
SCOTI's Avatar
Not w/the bed on. I'll prob get a couple one day this week.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 10-18-2015, 04:23 PM   #218
Advanced Design
Advanced Design's Avatar
Your dually looks really good at that height. Congratulations on the maiden voyage!
Advanced Design is offline   Reply With Quote
Old 10-18-2015, 05:22 PM   #219
cochino12
It followed me home?
cochino12's Avatar
good for your SCOTI !! Hope there arent many bugs to work out
Adam
That's why they call it a shortcut Kyle, if it was easy it would just be the way.
86 c-10 SWB
85 CCSB
90 GMC K30 Crew SRW
1985 C30 Dually
cochino12 is offline   Reply With Quote
Old 10-18-2015, 06:56 PM   #220
lolife99
67-72 parts collector,…
lolife99's Avatar
Looks perfect!
Keith
Convert to disc brakes.
Old 10-19-2015, 12:14 AM   #221
tinydb84
tinydb84's Avatar
Cant wait to see them. Very clean work (like all your other work).
David
Instagram: myfabguy
Old 10-19-2015, 07:19 AM   #222
SCOTI
SCOTI's Avatar
Thanks guys.
It was a good feeling buzzing up the road w/it back together. I went back to check off the last few items on my 'punchlist' yesterday & what a list! I hope to get it up today for inspection. If so, I'll be legal by noon tomorrow & will try to get the bed Line-X'd pending weather by the end of the week (supposed to rain this week after Tuesday).
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 10-19-2015, 08:08 PM   #223
SCOTI
SCOTI's Avatar
Tuckin caps.....
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 10-19-2015, 08:56 PM   #224
68Timber
68Timber's Avatar
Wow...
John
74 Honda Z50 build
Old 10-20-2015, 03:05 AM   #225
BLE 'BURBAN
In the Forgotten far North.
BLE 'BURBAN's Avatar
your tailgate insert.... where did you get it?
1987 R3500 CREW CAB DUALLY (BIG RED)Acquired 06/12/2015
1990 chevy suburban V2500 5.7L
My cluster Mods-Nov 2007
overhead console Stereo install Round 2 Aug 2009
Heated/turn signal mirror upgrade
BLE 'BURBAN is offline   Reply With Quote
