10-22-2016, 04:23 PM | #1 |
Medium Rear Window?
So, Since I cant go out and play... No clutch!
I was talking to the guys at the shop about a Medium not Big Back window. Low and behold Summit delivers a ford with a Medium window. So I laided it out how I would do this modification. Here is a paint chop. So if you just cut out a small window for a big window I would like a good inner and outer. But will be on the hunt as not to cut a good cab.
1962 shortbed 408cui small block, TKO 600 5-speed, bagged Porterbuilt suspension. 18" Salt Flats http://www.cardomain.com/ride/332579...t-c-k-pick-up/ http://67-72chevytrucks.com/vboard/s...d.php?t=560081 |
04-30-2019, 03:21 AM | #2 |
Re: Medium Rear Window?
Rendered Rides for my 62
04-30-2019, 07:01 AM | #3 |
It would be a cool look. If it could be done with out changing the inner panel that would be a good option for lots of folks.
Jimmy
60 to 66 Chevy and GMC window decals http://67-72chevytrucks.com/vboard/s...d.php?t=661131 Good friends, good food and a hotrod what else do you need? 1966 BBW long fleet Daily driver 1965 BBW short fleet Sold and going to a good home 1965 Suburban 2003 3500 Duramax 2005 Ultra Classic |
04-30-2019, 06:45 PM | #4 |
I plan on stretching to line of site, not behind head. 3 or 4" each side. Kinda like 50s ford truck small window.
05-03-2019, 01:47 AM | #5 |
Very cool look.
1961 GMC half ton, short step, Canadian model. Just starting work on it. |
10-25-2022, 03:53 PM | #6 |
No disrespect,but i don’t think it looks right just my 2 cents.
I think a sbw or bbw looks better. |
10-26-2022, 08:38 PM | #7 |
That's a no for me. But then again I like small window too lol
2000 c3500 utility bed 7.4l 5sp manual old body style. Cab and chassis 1964 GMC K10 1965 Chevy C50 |
10-27-2022, 07:45 AM | #8 |
I kind of like it and like the idea of something different. I like the blue truck image and how the window corners match the truck body lines that surround it.
10-27-2022, 09:00 AM | #9 |
Do the same rendering with BBW and that’s one sick looking whip!!
No need for change,the General knew what he was doing!!! |
10-27-2022, 03:39 PM | #10 |
When I laid it out unknown to me the actual glass size is exactly the 67 size. It is one of those you would double take mods. If you didn't know c10s you would think it was stock. Kinda like the 3" longer wheel base
10-28-2022, 09:52 AM | #11 |
EDIT - nevermind, I see this is a really old thread.
10-28-2022, 04:20 PM | #12 |
Yes, it's an older thread. But the guy that started it posted on it yesterday.
I'd say it's still a current/valid one.
10-29-2022, 08:45 AM | #13 | |
I agree with SCOTI. Even though a thread hasn't been posted on in awhile, if your reply is relevant to the thread, please post it to that thread. It also brings up information that some people might not have seen before
Christian Carpenter 1963 C10 - Frankentruck 283, 3 speed with overdrive Overdrive wiring here1963-ish truck bed trailer - Half-Wit 1981 C10 - Penny 305, th350 1995 Dodge Dakota Sport "I'll put it simple: if you're going hard enough left, you'll find yourself turning right." - Doc Hudson |
10-29-2022, 09:02 AM | #14 |
Moderator
I think it would be cool. I'd like to see one done in real life.
10-29-2022, 09:29 AM | #15 |
I'd have to dislike a small back window before considering this mod. Small window pickups are cool. Big window pickups are sexy. I think GM designs are the best.
10-29-2022, 03:41 PM | #16 |
I'd like to see one done. I prefer the big glass personally but the 'medium' size has me curious.
10-30-2022, 04:09 PM | #17 |
Mid 60's F100's have a "medium" sized window as standard and they look good. My gripe with the small window or a medium window is that Chevy styled and stamped the cab shape with a raised perimeter for the big window design, then the small window is inside that with another raised stamping around that window. It just looks strange to have the raised stamping and pinchweld for the big window and blank space between that and the small window. The back of the F100 cab looks better as a smaller window because it only has one stamping for the window. Small window '67 C10s are the same way, only has one design stamped in.
Maybe it's because I grew up in my dad's glass shop, but it reminds me of the cheaply made aftermarket conversion van windows that were slapped into a panel van body that has a recessed stamping in the shape of the window that would've been there, but the aftermarket window is a smaller generic shape.
Project Goldilocks '66 C10 Short Fleet BBW Build '65 C10 Highly Detailed Stock Restoration Thread '78 Camaro Targa Roof Build '55 International Metal/Body/Paint Work '66 F100 Full Rotisserie Restoration '40 Packard 120 Convertible Coupe Restoration How To Restore and Detail an Original Gauge Cluster How To Detail Sand Body Panels, Edges, Corners, Etc |
