02-10-2018, 03:17 PM | #51 |
A day late and $1 short...
Re: Old Girl (aka Project Underhaulin)
I have a question about cooling. Before installing the Edelbrock water pump included with the Tru-Trac system the temp ran dead center on the gauge. now it spends most of its time on the right side of the gauge, basically at the upper limit of the normal gauge. We have the fans configured to come on at 180 and off a 170* but the fans never turn off. So I'm left with a quandary, is the new cooling system inefficient, is the gauge not reading correctly because I disconnected the ammeter, or do I need to put a 160* thermostat in it? I'd love to hear thoughts from folks that have experience with the Tru-Trac system. Thanks in advance.
Buck Instagram: C10_ustacould 1963 SWB Fleet Side 528 Desert Beige Milly 1967 SWB Step Side 506 Medium Blue The Old Girl 1968 SWB Fleet Side 503 Light Green Ellie SOLD 1965 SWB Fleet Side 507 Light Blue Prescription Strength SOLD 1971 SWB Fleet Side 521 White Shiro SOLD 1968 SWB Step Side 503 Light Green My Old Farm Truck SOLD |
02-10-2018, 05:37 PM | #52 |
i drilled a series of 5 or 6 3/16 holes in the thermostat to allow steam and extra water flow when the engine is warming up in a customers car that had the tru trac system just to keep the temps out of the red zone. BTW used a 160 thermostat new from summit, jarden high flow replacement, not the average $5 parts store special..
thanks for keeping ol girl alive and honoring the memory
A C Ward Retired US Army 66 El Camino 67 SWB underwent major Surgery- http://67-72chevytrucks.com/vboard/s...d.php?t=776475 |
02-11-2018, 03:19 PM | #53 |
I have a dilemma. I installed all the correct components for the e-brake system but the cable is too short. The only thing that isn't factory is the 11" x 2.75" rear brakes. I think the issue is the horizontal brake bar (gold piece in the picture) is pushing the parking brake lever too far back which retracts the cable farther than the stock 11" x 2' brakes. Does anyone have experience with this?
I had this setup on my green '68 stepper and it worked fine, not sure why this doesn't work.
02-13-2018, 08:29 PM | #54 |
Buck, the only thing I see missing is the little "star" wheel brake adjuster at the bottom.
Also, on the higher engine temp - did you mount the temp gauge in the intake manifold or the head? I have found that gauges mounted in the heads usually indicate a hotter temp. Nice work getting this truck up and going. I love the attention to detail in your trucks. Good luck man. POP
2016 RAM Laramie HEMI 1966 Fairlane GT/A, 390/335 HP If it costs you a dollar to make a friend, KEEP THE DOLLAR. If it costs you a friend to make a dollar, KEEP THE FRIEND. |
02-13-2018, 10:12 PM | #55 | |
02-14-2018, 09:38 PM | #56 |
Do you have the CCW rotation water pump? Looks like that serp setup will spin the pump backwards. It's the only obvious thing I could think of.
Looking good!
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO http://67-72chevytrucks.com/vboard/s...d.php?t=788602 93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday... 05 Jeep Wrangler Unlimited. 3” lift & 6-speed 02 E320 the insurance total “free car” 13 Tahoe LTZ |
02-14-2018, 10:10 PM | #57 |
hey there brother. love the pickup. i am going to do the 506 medium blue also this march
i'm nobody to offer advise to you guys but i changed my temp sending unit to the Letric Limited sensor a lot of guys are recommending. my temp gauge would peg hot and my temp gun read 195-ish. changed it out and gauge reads in the middle like i said, i'm as smart as my avatar looks.....hahaha
Steven '67 SWB, 250ci, 3OTT.......this is my first build...... I wonder if my grand kids will say, "I would give anything to have my grand dads 2005 Chevrolet Z71" |
02-16-2018, 07:04 PM | #58 |
For Front End Friday...
02-16-2018, 07:27 PM | #59 |
Steven "If dogs don't go to heaven, when I die I want to go wherever they went." -- Will Rogers R.I.P. Oscar R.I.P. Ratchet 1967 Pontiac GTO - Dad was the Original Owner 1970 Chevy 2wd SWB "Oscar's Truck" 1970 Chevy 2wd Blazer "Ratchet's Blazer" 2013 Chevy 2500HD Crew Cab Duramax/Allison Z71 LTZ "Brown Sugar" 2017 Chevy Suburban "BDB" 2020 Chevy Blazer Premier "Foxy" Member of Louisiana Classic Truck Club (LCTC) Shop Build |
02-16-2018, 10:03 PM | #60 |
Proprietor of Dale's Corner
It's looking great
"Some Days Chickens And Some Days Feathers" Dale XNGH ECV Sam Brannan 1004 R.I.P. 67ChevyRedneck R.I.P. Grumpy Old Man |
02-17-2018, 12:44 PM | #61 |
BlahBlahBlah
This is such a nice truck, perfect look. Glad to see its getting all the kinks ironed out. I will be sad though when you put the big bling wheels and tires on it. I'm saving all the pics posted of it in this form.
02-17-2018, 03:36 PM | #62 |
Thanks brutha! Your Blazer is coming along well, hope Brandi is well after her tumble. Too bad you didn't have a gold medal to give her since the Olympics are going on and all. Don't tell her I said that, she'll sic Ratchet on me!!
Thanks Ol Blue! Thanks, I like the white wheels too but it isn't my truck so...
02-17-2018, 06:32 PM | #63 |
I like the look.
'35 1/2 ton Pickup (bought 2020) '68 C10 Suburban (bought 2021) '72 K5 Blazer (bought 2013) '67 Stepside (bought 1997-sold 2021) '96 Bronco Eddie Bauer (inherited 2010) My 1st day here-'67 C10(sold)and '72 K5 Blazer http://67-72chevytrucks.com/vboard/s...d.php?t=702056 "Another Blue Chevy"(1935) http://67-72chevytrucks.com/vboard/s...d.php?t=799203 MIKE
02-22-2018, 08:05 PM | #64 |
Time for an update and some pictures. We got the temperature under control!! We bought a funnel that connects in place of the radiator cap and allows you to initially overfill the radiator, as the thermostat opens it allows the air to escape and the extra coolant to flow into the system. The thermostat was a 195º, we swapped it for a Mr. Gasket hi-flo 180º and set the fans to come on at 195º and turn off at 185º. This setup seems to work well and the fans actually don't run much, unless the truck is idling for a while, but the fans pull the temp down quickly. While we were at it we installed a overflow line using the same Russell Pro Classic hose and black AN fittings and hose ends we used for the transmission cooler lines as well as a black Billet Specialties radiator cap. Sunday morning we took the ZL1 and the C10 to a monthly cruise we do with some old friends, the Old Girl did great and we were lucky to have Hart_Rod join us in his Super Burb.
On the to-do list we have a rear disc brake kit and adjustable proportioning valve. New Rad cap and overflow hose... The boy and his girl heading to a cruise-in... The Old Girl and Super Burb... The boy let me drive the Old Girl to work today.
02-22-2018, 09:33 PM | #65 |
Looks like good times! And weather way nicer than here....
02-23-2018, 01:16 PM | #66 |
Has that truck got the early rear housing in it? To me (just saying) its begging for some Bonneville Gs, and bags. .. Just me, But you know how I am.
02-23-2018, 07:07 PM | #67 | |
It's got the longer '72 rear end in it. No money for Bonneville G's so a set of 20" Billet Specialties Speedways will have to do.
02-28-2018, 09:25 AM | #68 |
Looking good Buck!
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
02-28-2018, 06:59 PM | #69 |
Thanks bruh!
Pic from last Saturday at Pensacola Cars& Coffee.
02-28-2018, 11:52 PM | #70 | |
Jesse James 1967 C10 SWB Stepside: 350/700R4/3.73 1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc 1968 Pontiac Firebird: Project Fire Chicken! 2015 Silverado Double Cab 5.3L Z71 2001 Jeep Wrangler Sport 4.0L 5spd 2020 Chevrolet Equinox Premium 2.0L Turbo 2011 Mustang V6 ~ Wife's ride American Born, Country by the Grace of God 1967 CST Shop Truck Rebuild! My 1967 C-10 Build Thread My Vintage Air A/C Install Project "On a Dime" Trying my hand at Home Renovation! 1965 Mustang Modifications! |
03-10-2018, 11:47 PM | #71 |
Took the old girl out to a show in Panama City Beach today, a lot of attention. People really like the stock/old school look.
03-10-2018, 11:55 PM | #72 |
We received our Billet Specialties Speedway wheels. I think we'll need prettier brakes...
Now we need to figure out tires. I'm trying to decide between 255/40R20 all the way around or 255/40R20 (28" tall) front and 255/50R20 (30" tall). Ether way the tires are the same width but in the second scenario the rears are 2" taller. these are basically the same heights I ran on my green step side. Running the square set up gives the advantage of rotating them front to rear but the staggered set up helps with rpm on the highway. What do y'all think, square or staggered?
03-11-2018, 12:47 AM | #73 |
them's purdy ...
03-11-2018, 10:21 AM | #74 |
What trans & gear ratio does the truck have? That’ll help calculate the highway speed rpm’s.
Edit: just need to know the rearend gear ratio... I went back & now know it’s a 700r4 so 0.70 for the tranny. Last edited by nlped; 03-11-2018 at 10:28 AM. |
03-11-2018, 11:59 AM | #75 |
I'm pretty sure it's a 3.73, I'll find out for sure when I pull the axles for the disc brake swap.
