03-05-2017, 03:02 PM | #1 |
No Way This Is Stock
I just replaced the window inner felt strip and outer rubber "seal"(?) strip. Since getting this ride I always thought the gap was huge, because of the original worn-out felt and outer rubber. With the new inner and outer installed the gap between the glass and the outer rubber seal is still huge!
Is there anything else that I can do to seal the window?? |
03-05-2017, 03:05 PM | #2 |
03-05-2017, 03:21 PM | #3 |
Re: No Way This Is Stock
I have the same problem. If it is a 72 door the attempted to solve this problem by putting a screw in the door just below the vent window.
If anyone has some insight into a permanent solution I would like to know also. |
03-05-2017, 03:34 PM | #4 |
Florida Edition
There is a metal strap that holds the two sides together. These are often broken and need tack welded back together. That's why they added the screw in 1972, to keep that from happening.
70 GMC Short Stepside "Rose"-An American Beauty: Factory 402/TH400, AM/FM, AC, Tilt, Tach, Buckets, Posi, PS, PB, 3-5 Drop, Complete Resto-Rod 67 C-20 Slant Back Wrecker "Mad Max" 67 C-10 Ratrod "Step-N-Wolf" 71 Serro Scotty Sportsman camper "Scotty" 97 LT1 Z28 "The Hornet" Link to more pics of "Rose" http://67-72chevytrucks.com/vboard/a...p?albumid=1684 Check out my "Cheap Tricks" thread and add to it if you can, lots of good info there. http://67-72chevytrucks.com/vboard/s...d.php?t=489394 |
03-05-2017, 04:18 PM | #5 |
Before and after I changed mine, it was a pretty big gap too. I think the design is just bad
03-05-2017, 04:44 PM | #6 |
x2,there is no way of fixing your door without welding the strap and that will screw up your paint
03-06-2017, 01:08 AM | #7 |
The Older Generation
I posted some pictures of the brace/bracket/strap inside the door in this thread. http://67-72chevytrucks.com/vboard/s...d.php?t=633866 LockDoc
03-06-2017, 11:45 AM | #8 |
The doors have a tendency to separate due to pulling on the door handle (poor design), try squeezing it back together.
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
03-06-2017, 04:04 PM | #9 |
I was able to tack weld mine back up without damage to the paint. Mine was broken all the way where LockDoc's is only partially cracked. I taped the area off with duct tape and clamped the sides in position. By tacking one spot and then cooling it with a wet rag and slowly working from one end to the other I was able to repair the crack without causing any visible damage. Cleaned it, painted it and so far so good.
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
03-06-2017, 07:08 PM | #10 |
Thanks Fellas' - Mine is a '69 and am I reading things right in that the brace/bracket/strap is only for a '72?
Thanks again - |
03-06-2017, 07:10 PM | #11 |
03-06-2017, 09:08 PM | #12 |
My 67 has the straps and I believe that all the rest of the years do. The difference on a 72 is they have a screw that goes through a dimple on the inside the of the door and threads into the speed nut on the outside part of the strap (you can see it in the photos LockDoc posted) thus pulling the two sides together. If I have to pull my wing window for some reason I will add the screw to mine. It won't have the correct dimple to countersink the screw but it won't have the gap either. I wish I had known about the screws earlier. GM must have too many problems and came up with the screw as a one year hold over solution till the square bodies came out next year
03-06-2017, 11:35 PM | #13 | |
All '67-'72 Chevy and GMC truck doors have the support strap and like HO455 said only the '72's had the screw.... LockDoc
03-07-2017, 12:24 AM | #14 | |
A husband can be right...or...A husband can be happy. 67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk. 1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc JOHN 17:3...The better side of "LIFE" Remember: Everyday is a good day...Some are just gooder! |
03-07-2017, 11:37 PM | #15 |
03-07-2017, 11:45 PM | #16 |
Would it be possible to add a screw (pre-'72) straight down thru the tabs instead of welding them? Or is it just as likely that one or the other has broken off the door instead of each other where they overlap? I'm sure I'll need to fix mine at some point soon.
'68 Panel Project Boogie Chillin' '68 C-10 Ol' Green |
03-07-2017, 11:58 PM | #17 |
Speaking from the experience I gained from the 3 doors on my Burban. Yes, if the spot welds had failed you could do that. However on mine, none of the spot welds had failed, the metal had cracked along the 90 degree bends. Basically the metal flexes at that point and over time it work hardens and then cracks.
03-08-2017, 12:21 AM | #18 |
If you look at the 69 71 blazers they have factory pieces that cab be used on the trucks to support the doors. This is what they look like. The screw goes in the same spot as the 72 doors. This tightens the gap a bit.
03-20-2017, 06:29 PM | #19 |
My straps are not broken and my "4th" door has this huge gap too, I thought this was about the 3/4th doors
03-21-2017, 07:34 AM | #20 |
Anyone have the measurement for what that gap is supposed to be at the strap and the rest of the channel. ?
03-21-2017, 06:15 PM | #21 |
70+ ( Old Skool Club )
Just learned something new about the trucks today. Now I know why the screw is just on the 72 doors.
1972 C10 Custom/Deluxe 613 Highlander 406/700R4 1999 White Tahoe LS 4x2 with Z56 Police Package 1992 K1500 GMC Suburban Members I have personally met: MusicMan70 - HeavyD - ChewyChevy67 - StingRay -71SWB4x4 - 67 Burb - DeadheadNM - too much stuff - bc65 - das601 " Circumsatances Do Not Change Responsibility " " The Sky is not the Limit, Your Mind is." Marilyn Monroe .. RIP Charlie Watts 1941 - 2021 |
03-22-2017, 09:06 AM | #22 | |
Thanks again for the push in the right direction! |
