Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > The 1960-1966 Chevrolet & GMC Pickups Parts Board
Old 03-22-2009, 11:47 AM   #1
Captainfab
60-66 Nut
Rear Disc Brake Brackets
These brackets are for putting disc brakes on your 10 or 12 bolt pickup rear differential with the 5 on 5 bolt pattern. They are designed to use the '78 and up metric passenger car calipers and Lincoln Mark IV rotors. A list of part numbers will be provided. The brackets are powder coated in gray hammertone and come with grade 8 fasteners. Price is $70.00 shipped to your door in 2 to 3 days. I have 3 sets of these available.
Old 03-22-2009, 11:52 AM   #2
Hart_Rod
Hart_Rod's Avatar
Re: Rear Disc Brake Brackets
Pictures of the the complete setup mounted would be cool.
Hart_Rod is offline   Reply With Quote
Old 03-22-2009, 11:59 AM   #3
ksbrktracer
TNT-MOTORSPORTS
ksbrktracer's Avatar
I am interested in these also, I would be interested in seeing an assembled picture also
Tommy
ksbrktracer is offline   Reply With Quote
Old 03-22-2009, 12:16 PM   #4
Captainfab
60-66 Nut
I'll get some installed pics later today.....thanks for the interest.
Old 03-22-2009, 02:49 PM   #5
ksbrktracer
TNT-MOTORSPORTS
Sounds good
Old 03-22-2009, 10:31 PM   #6
joe231
joe231's Avatar
very cool John!
I assume you build these?
I want some, but ain't ready for 'em yet
CHEVY ONLY
Old 03-22-2009, 11:10 PM   #7
Captainfab
60-66 Nut
Originally Posted by joe231 View Post
very cool John!
Thanks Joe, Yeah I made these about 8 or 10 years ago, they just don't seem to sell around here. I thought I'd try and sell what I have left on here, and if there seems to be continued interest, I'll make some more. Let me know when you're ready and I can set you up with this style or a different one.
Old 03-22-2009, 11:40 PM   #8
Captainfab
60-66 Nut
Ok here are some installed pics of the brackets. One thing I forgot to mention in the first post is that when using this setup you will most likely need to have the flanges of your axles machined down to 6.250" OD. This is needed to accomodate the lincoln rotors. If you have aftermarket axles, I would check them first before assuming it needs to be done. If you don't have a way to get them machined in a lathe, this can be done with an angle grinder, a good hard wheel and some patience. Typically you will need to take off .250" (1/4") of the diameter or .125" (1/8") around the circumference.
Upon setting up this assembly to take pictures today, I discovered a small issue with a reman caliper I picked up today. As I have read in the last couple of years, the castings of the reman calipers can vary from mfg to mfg. This became apparent with the newest caliper having 3 bosses that were interfering with the caliper bracket. This was easily taken care of with a flap disc on a grinder, providing a bit of clearance. Back when I originally made these brackets, I had not run into this issue. As a comparison I have included a pic of an OEM 3rd Gen F- body e-brake caliper.
Let me know if you have any further questions, or if you need to see something not shown in these pics.
Old 03-22-2009, 11:45 PM   #9
Captainfab
60-66 Nut
Here's a pic of the clearancing done on the reman caliper.
Old 03-23-2009, 05:02 AM   #10
BIGPIMP
PIMPING RIDES
BIGPIMP's Avatar
i think this is great production from a stand up guy .i have a set on the way .i will post when they arrive .he provides instant tracking number .very professional.thanks captainfab .a nice way to keep our trucks looking the same but driving and feeling better .
1964 CHEVY 1/2 C/10 FLEET
1981 CHEVY 1/2 C/10 FLEET
1995 DODGE 1500 V6 FLEET
EAST
http://www.flickr.com/photos/bigasspimp/?saved=1
BIGPIMP is offline   Reply With Quote
Old 03-23-2009, 08:12 AM   #11
joe231
joe231's Avatar
Cool!!
Thanks John!!
so with the these calipers, only one has an e-brake?
CHEVY ONLY
Old 03-23-2009, 01:06 PM   #12
Captainfab
60-66 Nut
Cool!!
Thanks John!!
No, I was just showing the two different calipers for comparison. You would have either no e-brakes using the front calipers or both calipers having e-brakes when using rear calipers such as the 3rd Gen F-body or the '83-'87 Eldorado, Riviera, Toronado rear calipers.
Old 03-23-2009, 01:19 PM   #13
joe231
joe231's Avatar
ok, got ya.......
CHEVY ONLY
Old 03-23-2009, 01:19 PM   #14
Captainfab
60-66 Nut
Thanks Larry
Old 03-23-2009, 05:23 PM   #15
BIGPIMP
PIMPING RIDES
BIGPIMP's Avatar
got them just like promised,thanx
EAST
Old 03-23-2009, 11:21 PM   #16
Captainfab
60-66 Nut
Post up some pics when you get them on......
Old 03-24-2009, 08:34 PM   #17
joe231
joe231's Avatar
Yes, please do!!
CHEVY ONLY
Old 04-03-2009, 11:33 PM   #18
Captainfab
60-66 Nut
TTT
Old 04-15-2009, 12:15 PM   #19
Captainfab
60-66 Nut
Bump.....
Old 06-29-2009, 03:01 PM   #20
JohnC
JohnC's Avatar
BigPimp - Do you have these installed yet?
Captainfab - Are the lincoln rotors the only ones that work, or can you use the actual truck rotors?
JohnC is offline   Reply With Quote
Old 06-29-2009, 05:58 PM   #21
joe231
joe231's Avatar
the truck front rotors won't work, they have a hub built in.....
CHEVY ONLY
Old 06-29-2009, 10:21 PM   #22
Captainfab
60-66 Nut
BigPimp didn't purchase these brackets, he bought the Implala SS ones that I also sell
Yes these brackets are designed for the Lincoln rotors. And as Joe stated you can't use the pickup front rotors since the hub is part of rhe rotor
Old 07-03-2009, 10:22 AM   #23
jbarnes67
captain fab do you still have any of these brackets available. I am in need of a set.
jbarnes67 is offline   Reply With Quote
Old 07-03-2009, 01:02 PM   #24
Outlaw72
Hay Team!!
Outlaw72's Avatar
Nice job on those brackets Capt...
1972 Chevrolet Cheyenne LWB "Orange and White" 8)
Outlaw72 is offline   Reply With Quote
Old 07-03-2009, 10:52 PM   #25
Captainfab
60-66 Nut
Yes I do still have them. Let me know if you want a set.
Thanks Jerry. Your Impala disc brake brackets are on their way. Thanks
