10-07-2009, 01:18 AM | #1 |
Built not bought!!!!
Project 1970 Step side C10
I picked up this truck a few weeks ago in pieces. I am getting a good start on in now. Motor is ready to run, body work is getting there. Any comments are appreciated. This is my second truck that I have restored, so I am not an experience builder yet.
10-07-2009, 08:28 PM | #2 |
Re: Project 1970 Step side C10
looking good. the rear springs look like they could use some help...lol, im doing a 72 prostreet step side. i will start a build thread soon on it. looks good. keep us up to date on it....
10-07-2009, 08:32 PM | #3 |
I wish mine looked that nice I am not really sure how to get mine all apart by myself You have a few buddies to help you out with the heavy liftin?
10-07-2009, 10:07 PM | #4 |
Still Learning
Very nice truck! doesn't look like there is any rust in the pics. Keep up the good work!
10-08-2009, 12:51 AM | #5 |
I had help removing the box, but everything else can be done by myself and a cherry picker.
I would like to replace the rear springs due to the way someone just heated them up to lower the truck. The truck only has a little cancer on the cab just inside the doors, I don't think there is enough to put new floor pans in it though, I'll just fab up some patch pannels I think. Well I got the motor running tonight finaly!!! Runs real good. It took a while to figure out the wiring harness though. I still have no idea what some of the wires are for. If someone has a link I could go to, and find a wiring diagram that I could print off, that would be great. My chilton book doesn't help for a 1970 that much. |
10-08-2009, 01:15 AM | #6 |
the springs are tost, i replaced mine with air bags. easy to do. only about 100 bucks. rides real good. have done it on two of my trucks.
10-08-2009, 10:34 AM | #7 |
looks real good!
10-08-2009, 11:24 AM | #8 |
Good looking truck, should be a great build. What are your plans for the truck?
10-08-2009, 01:15 PM | #9 |
Now what??
Looks good...
69 Long Fleet - Project 06 Ram 1ton Cummins 4x4-DD 01 Tahoe- wifes "The quality of a persons life is in direct proportion to their commitment to excellence, regardless of their chosen field of endeavor." ~ Vince Lombardi "A dream doesn't become reality through magic, it takes sweat, determination and hard work." ~ Colin Powell my, um, build USMC OIF Veteran SEMPER FI!
10-08-2009, 06:28 PM | #10 |
aford78, how many pounds is your cherry picker rated for? I need to go shopping for one soon when I need to take my engine out and get it on a stand.
10-08-2009, 07:34 PM | #11 |
Redefining LowBudget
10-08-2009, 08:49 PM | #12 |
I think most cherry pickers are rated for 2 tons.
Thank you for the wiring diagram link, it will help out. |
10-10-2009, 01:42 AM | #13 |
I got a little more of the body work done tonight. I started putting antifreeze in the radiator when I noticed a leak. So I had to drain the system and re-solider the lower hose port. All good now.
10-10-2009, 08:22 AM | #14 |
dam your beating that old girl into shape real quick like ...I bet you have a milk crate in her and are doing hot laps by the end of the day tomorrow
1970 C10 CST fleetside 472 ....big dreams little cash... SunShine Syndicate.. Mikes Sandwich Fair Run OCT 8th 2011
10-11-2009, 12:38 PM | #15 |
LOL... The thought did cross my mind already!
10-11-2009, 12:44 PM | #16 |
mini truck racer
What did you use to paint the frame and firewall with ?
1949 5-window 1969 Camaro 1976 Chevy Luv yellow 1978 Chevy Luv Blue 1976 Chevy Luv Black 1979 Firebird Flooded in Harvey 1999 F350 Dually 2005 GMC Sierra 4.8 RCSB 2014 Explorer (wifes) My build :http://67-72chevytrucks.com/vboard/s...d.php?t=399148 Build #2: http://67-72chevytrucks.com/vboard/s...d.php?t=653583 |
10-11-2009, 03:20 PM | #17 |
Implement paint for farm tractors on the frame, and rustoleum on the firewall. I think that I am going to pull the motor back out and block off the heater hole in the fire wall and do a little more clean up work on it. I just don't know if all that extra work is worth it?
10-11-2009, 03:24 PM | #18 |
Why can't I get my avatar to show up below my name???
10-11-2009, 03:26 PM | #19 |
I figured it out!!!!
10-11-2009, 07:19 PM | #20 | |
Hmmmm Michigan in May,June, sept Oct, Nov...yea I would get rid of the heater.......Duhhhhhhh Plan on driving it any of these months??? read with sarcastic voice in your head..... |
10-11-2009, 08:27 PM | #21 |
I don't plan on driving the truck when the weather turns cold or in the rain, just when its nice enough to drive. It is alot cleaner look blocked off I think.
10-11-2009, 08:35 PM | #22 |
sorry if I wake up its a good enough day to drive it.. not haveing defrost or heat doesn't seem worth it..there are alot of nice days ( like today) that its in the 50's or 60s where it just to nice a day to either be cold driving around or not to use it...
just my $.02
10-11-2009, 09:08 PM | #23 |
Is there a heater cover that doesn't look so bulky or maybe I could fab up something?? hmmmmm just a thought
10-11-2009, 10:15 PM | #24 |
67-72 parts collector,…
Vintage Air makes a heater/defrost only set up.
http://www.streetrodderweb.com/hotne...ter/index.html
Keith Convert to disc brakes. http://67-72chevytrucks.com/vboard/s...d.php?t=444823 Last edited by lolife99; 10-11-2009 at 11:21 PM. |
10-11-2009, 11:11 PM | #25 |
Thanks for the help, I'll have to see about cost though
