Old 10-14-2011, 07:45 PM   #1
Hart_Rod
Hart_Rod's Avatar
Question 4 x 4 wheels
Dumb question, but I'll ask any way.....Will a 6 lug 2 wheel drive wheel bolt on the front of a 6 lug 4 x 4 (it's a 1967 K-10)?
Hart_Rod is offline   Reply With Quote
Old 10-14-2011, 08:55 PM   #2
Redcap
Re: 4 x 4 wheels
6 on 5.5" is 6 on 5.5".
Redcap is offline   Reply With Quote
Old 10-14-2011, 09:21 PM   #3
Hart_Rod
Hart_Rod's Avatar
Re: 4 x 4 wheels
I know, but the hub size is different on on some wheels...
Old 10-14-2011, 10:25 PM   #4
onebadbowtie
onebadbowtie's Avatar
Re: 4 x 4 wheels
they would just need to be hub centric. which is about a 3.5" diameter hole i think
James
94' Chevy K1500 Extended Cab 4x4 5.7
72' Chevy LWB K10, 350, SM465, NP205 Project "Daily Driver"
onebadbowtie is offline   Reply With Quote
Old 10-15-2011, 07:57 AM   #5
Re: 4 x 4 wheels
Drum brake to drum brake,yes. Disc brake 4wd wheels to drum brake,probably not. At least I know they "all" don't interchange (and believe none do). Basically,when they started using disc brakes the wheels needed changing. So,disc brake 4wd wheels fit any 6 on 5.5 and not the other way around.
