68 burban
looking to lower my burban but i cant afford bags as of yet. What would be the best way to go about this?
The Older Generation
Re: 68 burban
Lowering springs I would say. I don't know a lot about them or what to tell you to buy though. LockDoc
Re: 68 burban
cool ty.
Ridin' Dirty
Re: 68 burban
or just cut a loop off your current coils. Should bring it down 3" or so.. You might want to grab a few coils from the wreckers to experiment with, or you may end up quoting my signature..
1978 C3500 Crewcab (Project) 1979 C2500 Crewcab (Driver/project) 1988 R2500 Crewcab (Driver) 1988 V3500 Crewcab 1988 R2500 Crewcab (Mint, Ex Fire Dept) 1968 Chev Suburban (4x4 conversion) LINK 1970 Chev C20 Suburban (driver/cruiser)LINK 2005 Impala (Incognito vehicle) 2004 Yukon XL Denali (Kid hauler) 1947 Case tractor Facebook Page(1000's of pictures of GM cars and trucks organized into albums) YouTube Channel |
Re: 68 burban
sweet thanks. I have been looking at drop spindals but i need to change out the front end to disk. I want to have it on the road for the summer. Cutting the ciol is a great idea ty
Re: 68 burban
Take special care cutting the coils...... The tops of the coils are wound smaller into a "D" shape that fits the top pocket in a specific "clock" orientation and the pocket in the lower "A" arm also has a specific clock orientation where the cut end of the coil goes, so you wanna make your cut from the bottom of the coil and have it correspond with the lower pocket when it is properly located at the top. I'm not sure one coil loop will equal 3 inches drop, but if you cut two coils, you'll probably have no suspension left (not reccommended!)
Measuring coil loops center to center of one above the other with the coils loaded should give you a ballpark minimum drop.... it will actually be a little lower. Also, if you dont want it to creak and groan when the suspension works, you'll want to slip a piece of hose over the cut end to insulate the metal-to-metal twisting in the pocket Last edited by AzDon; 01-30-2012 at 10:15 AM. |
Re: 68 burban
Thanks Don, this is my first rodeo so all the specific info is very helpful. Is yours
bags? Posted via Mobile Device |
Restoration Virgin!
Re: 68 burban
I'd do spindles up front first if you can afford them....if not, cutting the spring is your cheapest route....and springs in the back....To get discs up front, you can use the complete front crossmember out of a 73-87 truck...may have to drill a couple holes to make it work, but many folks have done it....grab the booster and mastercylinder too from the donor truck if you go that route....read more here
Geoff with a G 1968 Chevy C10 SWB The Mistress 1972 Custom Deluxe C20 Suburban A Suburban Named Isabella 1966 Ford Mustang Mama's High School Graduation Present |
Ridin' Dirty
Re: 68 burban
Wow! awesome links!
Re: 68 burban
Mine is lowered with 2.5" lowered spindles, one round of coil cut off and carefully sized 15" tires. I am not bagged!
IMO, You will be money ahead if you get the disc brake/lowered spindle complete kit from CPP, McGaughy, or MP brakes. These kits give you a choice of five or six lug rotors, all bearings, seals, calipers, hoses and a set of lowered spindles that are drilled to fit your stock ball joints and rod ends, all for less than $700. It's a lot less work than a complete crossmember swap, and you get new stuff and a lowered result at a price you arent gonna beat by starting with JY stuff. Somebody had already done a 71-72 crossmember swap on mine, so I already had used five-lug disc-brake stuff, but still needed to buy the dropped spindles. In the rear, I used 2" CPP lowering blocks and adjustable track bar (to properly center the lowered axle). My burb is almost too low in front, so I could raise it some by putting on taller wheels and tires IF I THOUGHT THEY LOOK GOOD! Last edited by AzDon; 01-30-2012 at 10:24 PM. |
Re: 68 burban
Ok thanks man, yours is for sure sweet. I think I might go that rout. Little more money but worth it in the long run.
