01-29-2013, 10:04 AM | #1 |
Porterbuilt extreme Dropmember and 2 piece drive shaft question???
Does anyone have any pictures of their 2 piece driveshaft installed in a PB extreme dropmember setup? Also, pictures and part numbers of the carrier bearing you are using would be great. TIA
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
01-29-2013, 11:02 AM | #2 |
Re: Porterbuilt extreme Dropmember and 2 piece drive shaft question???
Here is a Drtyrats thread: http://67-72chevytrucks.com/vboard/s...=406070&page=9
Also Del has a bunch of pics. We use the later model carrier bearing that has the mounting holes perpindicular to the drive-shaft. You can cross this part number from Carquest: HB88107A it has the 1.378 bore for the shaft. You will have to shim the carrier bearing up approx. 2"... when you get ready for install shoot me a text and I will call you to explain a couple details for an easy install. Nate
www.PorterbuiltFabrication.com Phone: 480-297-2621 E-mail: sales@pbfab.com Find us on FaceBook under Porterbuilt Fabrication Specializing in Chassis and Suspension Components for your Classic Chevrolet Truck. We offer components from the following manufacturers: Porterbuilt Accuair Ridetech (Air Ride Technologies) Air Lift Wilwood Intro Unisteer ECE Gotta Show Air Lift Borgeson CPP Supporting this forum since 2003! |
01-30-2013, 09:45 PM | #3 |
Great info, someday I might actually get to this stage
--------------------------------------------------------------- Jason. 68’ GMC shortbox https://67-72chevytrucks.com/vboard/...d.php?t=794201 72' 2WD Blazer http://67-72chevytrucks.com/vboard/s...d.php?t=425385 67' LongBox C-10 http://67-72chevytrucks.com/vboard/s...d.php?t=691845 InstaGram ybnorml67 |
01-30-2013, 10:20 PM | #4 | |
http://www.carquest.com/webapp/wcs/s...6816?acesApp=1 Thanks Nate. I'll give you a call when I get closer.
01-30-2013, 10:47 PM | #5 |
Don't want to hijack this thread from Rob but I will need this info after I install the Mild Rear Dropmember I just ordered. I'm guessing since it's not the extreme dropmember I won't have to raise my carrier bearing by 2 inches. I'm subscribing for future updates.
Keith 66 Suburban Burb Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=751361 IG: bennett68c10 |
01-30-2013, 10:56 PM | #6 | |
01-30-2013, 11:26 PM | #7 |
I hope so I would rather run a 1 piece driveshaft, but I doubt it with my luck.
01-31-2013, 12:11 AM | #8 |
I'm need this info also. I spoke with Del about building a 2pc drive shaft for this application. He quoted around $700 complete, I think.
Posted via Mobile Device |
01-31-2013, 12:35 AM | #9 |
How about the billet one CPP makes rob. A little shinny to match the headers...
I have one if you want to use it for mock up. Let me know. Posted via Mobile Device
68 BB burb build thread Scott's super slam front/rear http://67-72chevytrucks.com/vboard/s...d.php?t=378084 |
01-31-2013, 01:05 AM | #10 |
I'll get some new pics of the one I just stuck in Grey Goose. It came in at $680 from scratch.
01-31-2013, 09:13 AM | #11 |
Del I'm interested in the pics, also how much horsepower does this shaft handle. I have mild Big Block in mine but it still puts out over 400 hp. I don't want it to chew up a driveshaft.
04-15-2013, 04:27 PM | #12 |
Hey Del, any pictures yet? thanks
04-16-2013, 10:20 PM | #13 |
X2 as now I'm running the extreme rear dropmember and will need a 2pc driveshaft
04-30-2013, 11:23 PM | #14 |
X3 just thinking about drive shafts
My build thread http://67-72chevytrucks.com/vboard/s...d.php?t=563712 Instagram: http://instagram.com/rockylakekustoms Rocky Lake Kustoms Russ |
04-30-2013, 11:43 PM | #15 |
Yea it's time rob gets shafted...... Lol.
Ok I'm going to get back to watching other people build trucks. Lol Posted via Mobile Device
06-11-2013, 12:32 PM | #16 |
Still waiting for pictures and a write up on this.
06-15-2013, 06:57 AM | #17 |
bttt
06-23-2013, 09:09 PM | #18 | |
06-23-2013, 10:17 PM | #19 |
Holley LS accessory drive setup....check!
06-23-2013, 10:19 PM | #20 |
2010+ SS Camaro exhaust manifolds.....check!!
06-23-2013, 10:22 PM | #21 |
Hill's front wheel tubs...check!!!
06-23-2013, 10:25 PM | #22 |
2 piece drive shaft....HELP!!!!!
06-23-2013, 10:26 PM | #23 |
Looking good!!!
06-23-2013, 11:37 PM | #24 |
Sweeeeet...Jim
my build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=459839 Jimbo's long bed step build:http://67-72chevytrucks.com/vboard/s...t=464626<br /> |
06-24-2013, 10:35 AM | #25 |
Run a single driveshaft. Cut the Porterbuilt driveline hoop and make a new hoop that is taller.
You will love the Hills wheelwells. They fit like a glove. Posted via Mobile Device |
