04-28-2013, 04:41 PM | #1 |
C10 CLUB Y QUE!
pinion angle @ ride height
I get a vibration after 50.
I have dropmember installed and my angles are Starting from the tranny Tranny 4 Shaft. 3 Bearing. 0 Shaft. 6 Differential. 0 This was at ride height 5in I have a 2 inch block under the bearing. Any info would be gratefully Posted via Mobile Device |
04-28-2013, 06:39 PM | #2 |
Re: pinion angle @ ride hight
Im assuming that your tranny is down 4* and your pinion is at zero! if this is correct then it sound like you need a 2* shim under your rearend! to be equal and opposite tranny would be down 4* and pinion up 4* but it is recommended that your pinion be 2* down so the pinion can climb under tq so a 2* shim would put it 2* up. witch is 2 down from tranny. hope that makes sense!
The Ghost 67 short wide full custom. 550 hp LSX, 4l80E, narrowed 9". Body dropped w/air ride! ........................ ___ .........________//__{\_____ ,,,,,,,/__(⊙)___//___/__(O)_/ @disciple2.rc 💪instagram💪 LED TAILS |
04-28-2013, 06:50 PM | #3 |
C10 CLUB Y QUE!
Tranny down 4 First shaft. Down 3 Center bearing 0 Second shaft up 6 Differential. 0 Posted via Mobile Device |
04-28-2013, 07:06 PM | #4 |
C10 CLUB Y QUE!
Wouldn't that bring my shaft at 8 well the rear shafy
04-28-2013, 09:03 PM | #5 |
I just relized that you had a two piece drive shaft so my suggestion is probably not correct. I do know that you want to keep the u joints with in a 2* operating range and that its best to have the angles at each end equal and opposite. I would think that you would need to take an measurement of the face of the carrier bearing to see if it is tilted and then adjust according to that so if the tranny is down 4 the front side of the bearing should be tilted up 2 meaning the back would be down two and the pinion should be 0 but maybe someone else will chime in. my self I think I would convert over to a one piece shaft and eliminate balance issues and bearing issues. also if im not mistaken I think that if the u joints are replace in either shaft they have to be clocked correct for the driveline to run the way it was balanced. maybe someone with more 2 piece knowledge will chime in. sorry for the confusion. the actual angle of the shafts is not as important as the angles on either end!
04-28-2013, 09:06 PM | #6 | |
04-28-2013, 11:23 PM | #7 |
Do a search for 2 piece drive shaft angle help think I read something on there before.
04-29-2013, 09:59 AM | #8 |
C10 CLUB Y QUE!
Thanks Dan
I was thinking of giving dave from PB call Posted via Mobile Device |
04-30-2013, 09:22 PM | #9 |
Re: pinion angle @ ride height
Can u post pics of your setup?
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
04-30-2013, 09:33 PM | #10 |
Look here: http://www2.dana.com/pdf/J3311-1-DSSP.pdf , you can print it for your future use. Great information.
04-30-2013, 10:44 PM | #11 |
C10 CLUB Y QUE!
Check out my thread
05-01-2013, 01:49 PM | #12 |
C10 CLUB Y QUE!
Nate need your help......
05-01-2013, 03:28 PM | #13 |
Drives train angles should have a 1* to 2* relationship with the adjoining drive train part to prevent excess wear in the universal joint. As you accelerate a leaf spring vehicles pinion can move as much as 2 deg, a trailing arm vehicle will move .5 deg. Your first drive shaft and the pinion should be on the same plane meaning that you need a pinion angle of 4 degrees. This will also keep all of your angles within 2 deg of each other. There is adjustment on your PB drop member where the trailing arms bolt and if you still have them mounted in the bottom hoes like in you build thread they need to come all of the way up to the top mounting holes in hopes that this will get you the 4 deg pinion angle you are looking for.
Good luck
69 GMC C10 build thread- http://67-72chevytrucks.com/vboard/s...d.php?t=501676 03 Silverado build thread-http://67-72chevytrucks.com/vboard/s...d.php?t=591582 |
05-01-2013, 03:41 PM | #14 |
C10 CLUB Y QUE!
Let make sure I have it right. The tranny and the first shaft are cool. I need to move the differential and the the second shaft. And moving the trailing arms up would move my second shaft to 4. But wont my differential move out of 0
05-01-2013, 03:53 PM | #15 |
OOPS! I mean 3 deg on the pinion angle, sorry. Engine/trans and first drive shaft seem fine to me. From what I can tell all you need to do is adjust the pinion angle to 3 deg by raising the mounting pint on the cross member and the second drive shaft will be fine.
05-01-2013, 04:05 PM | #16 |
C10 CLUB Y QUE!
But will there be a problem with the differential change of pinion angle Posted via Mobile Device |
05-01-2013, 04:21 PM | #17 |
Well im no 2 piece expert but i would think the two lines would be set seperate from each other usually the front shaft is near level and the rear drops meaning they have way different angles. On the rear if the pinion is zero and bearing is zero and the shaft is at an angle they are equal and opposite therefore happy! I think the problem is in the front my self! Also leafs can wrap up to 7* depending on power and trailing arms and ladders etc usually less than 2 but it is the common practice to set the pinion down 2* for wrap up on race cars they go alot more. My guess it that if the tranny is 4 d and shaft is 3 and bearing is 0 then a shim under the tranny would bring the problem to a min. But thats just my .02
05-01-2013, 04:28 PM | #18 | |
05-01-2013, 09:53 PM | #19 |
For your consideration, the pinion doesn't really "climb" under torque in these trucks because of the trailing arm suspension design. Unlike leaf sprung rear ends, the axles in our '60-72 C10s are positively mounted to the trailing arms. They cannot twist or wrap up like leaf sprung axles. The only pinion angle changes that occur is under normal suspension travel, but due to the inherently long trailing arms, the angle change is, again, minimal.
All said, I like to set mine up close to 0 or 1 degrees (no more than that) in these trucks. Smooth as buttah! |
05-01-2013, 11:39 PM | #20 | |
05-02-2013, 12:19 AM | #21 |
Call us at the shop tomorrow. Dave should be able to help you out, but you can leave a message for me to call you back if you would like.
Nate Posted via Mobile Device
www.PorterbuiltFabrication.com Phone: 480-297-2621 E-mail: sales@pbfab.com Find us on FaceBook under Porterbuilt Fabrication Specializing in Chassis and Suspension Components for your Classic Chevrolet Truck. We offer components from the following manufacturers: Porterbuilt Accuair Ridetech (Air Ride Technologies) Air Lift Wilwood Intro Unisteer ECE Gotta Show Air Lift Borgeson CPP Supporting this forum since 2003! |
05-02-2013, 07:35 AM | #22 |
C10 CLUB Y QUE!
Dont matter just need it fix. Ive emailed and left a msg tuesday I believe. Ill call back today around 1030
05-03-2013, 09:27 AM | #23 | |
Check here, page 13 for setting up 2 piece driveshaft. No debate. Just follow the light...http://www2.dana.com/pdf/J3311-1-DSSP.pdf The truth will set you free..
05-03-2013, 10:16 AM | #24 | |
05-03-2013, 11:23 AM | #25 |
C10 CLUB Y QUE!
I moved the center bearing around half and inch. Vibration is still there but not as bad.
