09-08-2013, 11:17 PM | #1 |
upper trim attachment options
I'm certain this has come up before - but, what is the rhyme or reason to which type of upper belt trim attachment pieces were used by the factory. I "assumed" the factory always used metal clips, but, of course, I have 2 truck that have the original trim on them and they have the adhesive retainers (see part "D", two types - metal or plastic w/adhesive) http://www.lmctruck.com/icatalog/cb/full.aspx?Page=43
Am curious which you all use and which were original, etc etc. Seems it's easier to remove it from the plastic ones. Both my trucks used the plastic retainers in the middle and metal clips at the ends (I'm talking about on the long upper bed trim strips/belt molding). Wondering any advantages to either way. For the adhesive ones, are they simply placed in the trim then the trim pressed on, or are they placed on the bed and the trim snapped on over them once they are in place? I've always preferred clips, but, on a truck with aux tanks, it's about impossible to get behind the bedside and pinch the clips to get them removed. Anyone have any tricks as to how to remove the metal clips? Thanks all! |
09-10-2013, 04:04 PM | #2 |
Re: upper trim attachment options
I've read about guys using the broad side of a 2x4 to gently push down and pry out on the top of the trim and release the clips that way, but I've never tried it.
I added trim to a non-trim truck and used the adhesive clips along the upper bedside trim because it was easiest. I did use a bolt-in clip in the last spot because I could access that hole through the taillight hole.
Curt 1970 C/10, 250 L6 with Rochester BV carb, SM465 4 speed, 3.73 open rear |
09-10-2013, 04:16 PM | #3 |
Moderator
69-70 used all metal clips. 71-72 used a metal clip at the front, one at the back, and plastic in between.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man |
09-10-2013, 04:40 PM | #4 |
Roadtrip!
That sounds correct.
67 gmc custom lwb dakota truck. Sold...And bought back 69 swb 4x4 project (in progress) 70 c-10 lwb texas truck 70 4x4/BB/bkts/posi/tach(retired) 70 swb (wifes) 70 jimmy camper 71 K-5 factory 2wd 71 cheyenne 4x4/tach/posi/ plow rig 71 Cheyenne20 BB, buckets, tach, tilt, 4 speed 72 jimmy CST wyoming rig 72 jimmy Colorado rig 72 lifted texas 4x4 3/4 ton burb 65 fury conv. 383/auto 65 chrysler 300 "L" 413 auto |
09-10-2013, 08:54 PM | #5 |
great info gents, that's what I needed. This is for a 72, so will likely use the plastic in the middle. Thanks for the removal tip also Curt.
09-10-2013, 11:58 PM | #6 |
I approve this message.... My 72 was all original and that's the way it came.
72 Cheyenne super 10 08 3500 HD 4dr dually 12 ford flex (wifes ride) 76 Monte Carlo 83 Chevy short wide Silverado 96 Mazda Miata, 2000 Allegro Bus |
09-11-2013, 08:27 AM | #7 | |
United States Marine Corps 2000-2011 Iraq and Afghanistan veteran Just living life now and enjoying it and my wife, daughter and son |
09-21-2013, 12:59 AM | #8 |
that is how mine is also, that's why I was curious - the LMC catalog sells ALL the clip types, but their diagram showed using ONLY the plastic clip types, exclusively, along the upper belt molding (i.e. no metal clips on the ends).
I can't really get behind the forward upper belt clip (can BARELY get to the rear-most one via the tail light opening, ha!) so will have to look at how I put these on. I suppose I could use ALL plastic adhesive clips. This is semi-temporary, hoping to restore the truck completely someday, but in the meantime, needed to replace a bent piece of side trim. Thanks again for all the help and confirming factory config for the different years. |
09-21-2013, 06:30 PM | #9 |
Hmmmm
The plot thickens. The LMC plastic clips DO NOT STICK for crap... So, really don't want to drill holes all over the side of the bed and use earlier clips. This is old paint - not the shiniest - so that may be part of the problem. But it's a very smooth, polished surface that has been cleaned with degreaser, etc before sticking. They will "stick" but as soon as I try to attach the trim, it easily pops them off. Thoughts? Also - NO way I can find to get behind the forward mounting screw hole to hold the nut. Any ideas? Only possible if the aux tank is removed?? Cripes. If it wasn't so frustrating, it'd be funny. |
09-21-2013, 07:16 PM | #10 |
Moderator
Scrape off the crappy tape that came on the clips. Use 3M outdoor adhesive or automotive grade double sided tape (red color backing) you will have to cut it to fit as it comes in a roll. It is thinner, much stronger, and will snug the trim closer to the body. This is what I did when reattaching the old trim on my blue truck and it worked great.
09-21-2013, 07:41 PM | #11 | |||
09-21-2013, 07:46 PM | #12 |
thanks scott and ray, excellent advice. ray, both my trucks had the original trim on them and had the clip at the rear (push-in type) and the stud (nut on back) on the forward attach point. I tried to use the push-in type, but, the factory hole is so close to the edge that there is no room for the push-in (with hold-in bendable clip to snug it-type) that close to the end.
09-21-2013, 08:32 PM | #13 | |
You might be able to use a "barrel clip" in place of the nut. The "ears" on them are smaller than on the snap-in type clips so they should fit okay even up close to the edge. The only problem might be the hole diameter ... I think it might be a bit too large in relation to the stud diameter for a barrel clip to have the snug fit it needs to hold. Another option would be to use another plastic stick-on clip at the front. Or even 2 or 3 plastic clips right next to each other to give some added surface area so you can use a longer section of 3M tape for added strength just to be on the safe side. |
10-28-2013, 12:12 AM | #14 |
Moderator
Just got done installing a trim piece tonight using two pushin clips at either end and the adhesive style in between. It seats perfectly flush. The key is replacing the thick foam tape with 3M outdoor adhesive tape (half the thickness with way more gripping power), and making sure the surface is free of wax or any other contaminants that hinder adhesion. The metal clips are needed at the ends to make a tight connection so the trim hugs the body. I find that it helps to "bow" them slightly outward (as pictured below) to get the barbs to stick out further and grab the backside. As you push the trim in, it bends back to shape and pulls tight.
10-28-2013, 12:15 AM | #15 |
Moderator
Push in clip bowed to give more room for the barbs to attach
10-28-2013, 12:17 AM | #16 |
Moderator
Installed
10-28-2013, 12:22 AM | #17 |
Moderator
Looking straight down...tight and flush with no gap between trim and bed panel.
10-28-2013, 12:34 AM | #18 |
looks great Scott - I ended up doing exactly as you describe. I used 3M 2-sided trim tape and it worked great. The old sticky stuff peels right off of the new clips and I put the 3M stuff on it's place. MUCH betta. Your truck's looking great. I finally got your door on the 71 today... Ha!
11-13-2017, 11:40 AM | #19 |
Old thread I know, but do you have any good shots of the tip of the front spear? Just curious on how close it is on the front of the fender. TIA
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
11-13-2017, 10:47 PM | #20 |
I used the 3m tape also on my new trim, worked great!
11-14-2017, 02:15 PM | #21 |
Moderator
Just saw this. Will try and get a pic when I get home from work late tonight.
11-14-2017, 03:03 PM | #22 |
I just did this last month. Used 3m tape - works awesome and holds strong.
