![]() Join Date: Apr 2005
I was reading online that the E38 computer uses the brake switch to control TC lockup different than older computers - it received power when the brake lights receive power unlike the older systems that were opposite. Can anyone confirm this? Thanks,
Rob
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
Re: Torque Converter lock up
Ok, apparently they are opposite....@#$%^&*()%$%^&*(......this probably explains the issues I was having the weekend with it not wanting to idle when put in gear....2 days worth of tuning down the drain.....
meowMEOWmeowMEOW
So THATS what you meant in your text. I thought you meant it was wired backwards (happened to me).
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING ![]() |
#4 | |
![]() Join Date: Mar 2011
I've never texted and don't want to learn (I'm old)...Jim
my build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=459839 Jimbo's long bed step build:http://67-72chevytrucks.com/vboard/s...t=464626<br /> |
#6 | |
Oh Crap!! I might have done mine wrong, here is what I did from LT1swa.com
Here is how I hooked my relay up, is it correct?
If your computer is a E38 like mine (and I'm pretty sure it is), that's the wrong way. The new computers want power when the brake pedal is pressed, not when it is not being pressed.
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 Last edited by Hart_Rod; 11-13-2013 at 12:39 AM. |
Wire it like this:
#10 | |
Hart Rod, isn't that the same one I put up that you just told me was incorrect?? Here is how I have mine set up:
My relay is set up just like the picture above with #85 on the relay connected to the wire on the brake pedal that when pushed the brake lights come on. So when the brakes are hit the relay gets power. There were two wires to the brake switch an orange one and white one. The orange is "hot" at all times, the white is only "hot" when I push on the brake and that is the one I tapped into. So when you stated Quote:
#11 | |
I just bought a 2 way switch so it is wired up normal for the brakes but the other side is hot when the brake pedal is up then it "breaks" the circuit when the brakes are applied. I don't know the part number but anything with Cruise works the same way. I will dig to see what I did if you need me too. I didnt need or use any relays for the switching.
I did my swap about 8 or 9 years ago before they were all being done so I had to do alot of digging to get all the right pieces. Dave
Dave 1968 Custom Chevy with turbo charged 5.3 gen III 4l80e swap 1967-71 GMC 3/4 ton long step 4x4 (not sure what year exactly?) "A good friend will bail you out of jail...but a true friend will be sitting next to you saying "that was frekin awesome". "If it doesn't fit force it...If it breaks then it needed to be replaced anyway!" |
#13 | |
#14 |
Hart Rod, Yup, I missed that, well the good news for me (maybe) is I used a 4 pin realy and not a 5 which hooks it up to #87. Is this good Hart Rod, or do I need to use a 5 pin relay??
Thanks for all your help!!!!!!!! |
#15 |
You should be good. I would just double check that you have power going to the TC when the pedal is pushed and no power when you release the pedal.
#16 |
Ok hart! You may have just figured out something that I didn't know. My only understanding on the e38 was that early e38 didn't tell the TCC to lock up, they got a signal from the brake switch. Later e38 told the TCC to lock up directly. I used the cruise brake switch on mine, so mine may be wired backwards. So if it is, do you think that is possibly why my dyno numbers felt low and the ECM is giving me the p0606 code? Would explain why the engine feels a little boggy sometimes.
1972 C20 Suburban- Big Blue Betty '56 Chevy Bel Air Sedan- Frame up Restoration -What would you attempt to achieve if you knew you could not fail?- -I Refuse To Tiptoe Through Life, Only To Arrive Safely At Death's Door- R.I.P. EAST SIDE LOW LIFE |
#17 | |
http://forums.trailvoy.com/showthread.php?t=60767 http://forum.efilive.com/showthread....ody-inop/page2 http://forum.efilive.com/showthread....and-tbody-inop
#18 |
Rob,
Where did you read about the ECM wanting 12 volts for TCC lock up? I can't seem to find that info anywhere and the alldata doesn't seem to show very clearly that the ECM receives 12 volts for lock up. At least not where I can see. Please direct me so I can figure mine out.
#19 |
Hi Rob, on the wiring of the relay #85 should go to ground and #86 go to 12volts +. This is following DIN wiring guidelines. By switching them around the relay still works, but won't potentially have a voltage spike put on line. Years ago some relays used a voltage spike protection diode in them and if wired as you showed with #85 going to + and #86 to - i have glitche captured as high as 60 volts induced on-line when a relay turns off if the diode was defective or wired incorrectly. I believe all newer relays use a resistor across 85/86 so polarity doesn't matter. If you use a good volt meter do a diode test on the 85/86 relay terminals with it out of the circuit and in your hands. Put the red and black leads on way, note reading, flip the leads and note the reading and if the same it's resistor equipped, if not it's diode equipped. Think of it as an ignition coil, and you saturate the windings with electricity and when you open the circuit the electricity will go some where. That voltage spike can ruin expensive equipment! Just trying to be helpful to others, not finding fault! I feel if i can share some of my prior career and make their job go easier and learn something along the way GREAT! Good luck, Brian F.
#20 | ||
http://www.hptuners.com/forum/showth...a-break-signal Hope this helps.
#21 |
Ok Rob! I may just owe you one! I redid the wires using a relay and the diagram you provided. The truck seems to run differently. Seems to run much better. Better off the line and mid throttle response. May be my imagination, but.... The most important thing is I haven't had the p0606 code again. I did everything that I normally do to make it happen, but it hasn't occurred. Could be coincidence, but I hope not. Keep your fingers crossed!
Shawn
#22 | |
#23 | |
#24 |
Unfortunately the code came back. But the truck definitely drives different, better.
#25 | |
http://engine-codes.com/p0606_chevrolet.html
