need help/suggestions
Hey guys I am really needing some advice. I am working on a 66 c10 and have spent a ton of time on bodyworking the doors and fenders.I repaired rust in the lower fenders and installed new skins on the doors.The problem I am having is that both the doors and fenders tend to roll inward at the edges,I had them both straight and blocked out multiple times so much so that the edges of the fender and door had probably 1/8 inch of filler and primer, it was noticeable.I attached pics of the door and fender fittment but am really at a loss as how to correct the problem.I am almost ready to scrap them and buy new fenders and doors but I am sure they have their share of problems as well.Any way thanks for the help in advance.
check out SANFORD build thread http://67-72chevytrucks.com/vboard/s...d.php?t=522019 |
Re: need help/suggestions
I have a few more of the drivers side, it is not quite as bad as the pass. side.Thanks.
![]() Join Date: Jun 2006
Have either the doors or fenders been removed? Its all about adjustments to both. Do the doors first, equalize the gaps of the door then do the fenders and keep the edges of both thin so your not smacking together cracking your filler.
Custom Painter/Restoration Specialist 1965 GMC 3/4 Ton LB SOLD? 1964 Chevy El Camino in full restoration 1991 Chevy S10 288K+ miles 2nd Owner SOLD 2020 RAM 1500 Warlock |
yes I have had them both off multiple times, the door and fender edges roll inward at the edges and I dont know how to pull those out or if these trucks all roll inward.
I have a '63, I personally have never pulled mine off but at sometime in its life I'm sure they were removed. Anyways, mine roll in as well. I just assumed they were made this way for clearance purposes. I could be wrong, just my $.02
I'll post pics of the tip I made to pull door edges, it bolts to a slide hammer. You might have to make relief cuts where it rolls at the body line. All of them roll in at the front edges though, another set of doors won't fix it.
Project Goldilocks '66 C10 Short Fleet BBW Build '65 C10 Highly Detailed Stock Restoration Thread '78 Camaro Targa Roof Build '55 International Metal/Body/Paint Work '66 F100 Full Rotisserie Restoration '40 Packard 120 Convertible Coupe Restoration How To Restore and Detail an Original Gauge Cluster How To Detail Sand Body Panels, Edges, Corners, Etc Last edited by theastronaut; 01-20-2014 at 01:31 PM. |
Project Goldilocks '66 C10 Short Fleet BBW Build '65 C10 Highly Detailed Stock Restoration Thread '78 Camaro Targa Roof Build '55 International Metal/Body/Paint Work '66 F100 Full Rotisserie Restoration '40 Packard 120 Convertible Coupe Restoration How To Restore and Detail an Original Gauge Cluster How To Detail Sand Body Panels, Edges, Corners, Etc |
well I decided to try and take care of these door issues this morning but things did not go so well. I have included pics of what I tried to do, so when I made the cuts to the door I was able to pull the edge of the door out flush with my straight edge but it created a dip behind the cuts on the door.I made another cut to try and relieve the dip but I didnt do anything other than make a real mess of things.To make matters worse I installed sound deadener before I put the door skins on and it doesnt weld very well and there is no way to remove it without cutting the door skin off.At this point I am not sure what I will do as I become really discouraged with the way things are turning out.Any way I really appreciate all those who responded with suggetions. I have included pics of the mess I made.
![]() Join Date: Jul 2013
I think a new door is in store for you. I know my doors both have a slight
3/16"- 1/4" curve inward. the PS has more than the DS. I presume it is to clear the fenders when part open.
Mark Jesus is the Way! 2003 2500HD CCLB Duramax/Ali (Clifford) 2014 2SS/RS black on black Camaro (Betty) 2006 Pontiac SOLSTICE silver/black (Lula-Bell) 1970 C/10 Short Wide (Peggy) 1964 C/10 Short Step (Hambone) RIP Jimmy Hamilton Thank you for the trucks |
#13 |
they are designed to have the tuck in them. If you want it perfectly straight, its gonna take some work.
Mike Redpath |
