Old 11-03-2014, 01:02 PM   #1
jackyl9999
jackyl9999's Avatar
LQ4 Exhaust Question
I am looking to get my exhaust setup on my 70 GMC done this week.
Currently the engine is stock.
I have a set of 1-7/8's doug thorley headers, I plan on running a x-pipe, true dual setup with dynomax bullets. I am planning on 3 inch pipe.
My plan in the future is a TBSS intake, a cam upgrade and stall.
Is the 3 inch pipe overkill or am I thinking correctly allowing for future upgrades? I have done research but have found conflicting info on 3 inch dual setups being overkill with the upgrades I am planning.
1970 Gmc Grande Sierra Swb 2wd LSX (LQ4/4L80e)
1990 K1500 Daily
jackyl9999 is offline   Reply With Quote
Old 11-03-2014, 03:00 PM   #2
littlevictories
Re: LQ4 Exhaust Question
it's noticeably louder for sure. i stick with the 2.5" stuff nowadays coz old.
also, in before brew loses his **** over "x-pipe, true dual"
littlevictories is offline   Reply With Quote
Old 11-03-2014, 03:40 PM   #3
Jon01
Jon01's Avatar
It'll be fine, don't think too much into it.
Jon01 is offline   Reply With Quote
Old 11-03-2014, 03:41 PM   #4
jackyl9999
jackyl9999's Avatar
Thanks for the replies.
I tend to over think things like this. The only thing worse than doing a exhaust system is doing it twice.
1990 K1500 Daily
Old 11-04-2014, 12:56 AM   #5
Andy4639
Old member
Andy4639's Avatar
Wink Re: LQ4 Exhaust Question
I was told to stay with 2.5" pipe with anything under 500HP.Take a look at the link for sizes of piping.
http://www.exhaustvideos.com/faq/how...pipe-diameter/
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 11-04-2014, 01:05 AM   #6
'68 Newtricks
'68 Newtricks's Avatar
Originally Posted by littlevictories View Post
"x-pipe, true dual"
thinking the same thing lol
2.5" is plenty
my 400sb runs 2.5" Y pipe into single 3". I can't recommend dual 3", that would be a lot regardless of what intake/cam/snake oil you run.
'68 C10 SWB
'85 K30 Blazer
'68 Newtricks is offline   Reply With Quote
Old 11-04-2014, 05:58 AM   #7
chuckmc8
It's alsways something.....
chuckmc8's Avatar
I have 2 LQ4's running 2 1/2" and they are fine. If your truck is lowered, (mine are 5" drop spring in rear) its tough clearing the panhard bar knuckle over the diff without it bumping.(if you are going past the rear end) Larger tube size doesn't always equal more HP or Torque-it may pay to research pipe size as you make up your mind. HTH
1968 RS Camaro 'Vert Matching number 327 and M21 Muncie
1968 C10 Black with red interior and orig paint. 5.3 / 4l60e,3:73 POSI 17" Torq Thrusts
1968 CST 514 Red with black interior. Buddy Buckets, Factory A/C, PS, PB- 20" AR custom shop TT, 5.3 and 4l60e
chuckmc8 is offline   Reply With Quote
Old 11-04-2014, 09:08 AM   #8
Hart_Rod
Hart_Rod's Avatar
I have 600+ to the wheels with 2.5" pipes to the rear.
Hart_Rod is offline   Reply With Quote
Old 11-04-2014, 11:42 AM   #9
jackyl9999
jackyl9999's Avatar
I have the parts for 3 inch. (mufflers,x-pipe, collectors)
Has anyone ever done a 3 inch system then down to smaller pipe after the crossmember to save space when dealing with the rear suspension?
1990 K1500 Daily
Old 11-04-2014, 12:29 PM   #10
DjS71
If you've got parts and are averse to using reducers (more leak points?) and NOT averse to loud, then 3" is the right choice for you. I'll be going 2.5" w/X with my LQ4 ( no headers).
1971 C10 Short/Fleet 307-2BBL/3OTT
1999 Silverado 2500 ECSB 6.0/4L80
DjS71 is offline   Reply With Quote
Old 11-04-2014, 02:24 PM   #11
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
..and yet they never learn
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 11-05-2014, 02:20 PM   #12
69gmcc10
69gmcc10's Avatar
I have a computer program (PipeMax Pro) and based on engine specs it will calculate your ideal exhaust system specs. Based on stock engine secs an LQ4 should have a 2.606" dual exhaust system. That being said, that is based on a peak HP output around 5200 rpm. If you go down to 2.5", in "theory" it should give you better throttle response and move the curve lower and would be better for daily driving.
69 GMC C10 build thread- http://67-72chevytrucks.com/vboard/s...d.php?t=501676
03 Silverado build thread-http://67-72chevytrucks.com/vboard/s...d.php?t=591582
69gmcc10 is offline   Reply With Quote
Old 11-05-2014, 02:45 PM   #13
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
....does that take into account a dual exhaust? Pipe volume and scavenging will change drastically on a dual exhaust when changing diameter. Much more so than a combined or "single" exh.
Old 11-05-2014, 05:51 PM   #14
69gmcc10
69gmcc10's Avatar
Sorry, I should clarify more!
The 2.606" diameter a dual system that is for shorty headers 1.54" in diameter that are 17.9" to 20.4" in length and merging into a 2.606" collector tube that has an H in the system at 10.4", and continues to 20.9" or 41.7" from the collector into a "resonation" chamber or chambered muffler. That should meet all the volumetric efficiency and harmonics requirements in the system perfectly, but we don't live in a perfect world and I have found it better to go down to keep the exhaust velocities up than go large and create loud drones and scavenging issues. I use the shorty header specs when considering manifolds because it is as close a to a manifold as the program can get.
Interestingly there is a dual exhaust with Tri-Y headers system calculation as well. Tri-Y specs are primaries of 1.668" that are 17"-18.4" long merging into 1.793" the secondary Y of again 17" to 18.4" in length. The secondary Y should merge into a 2.606" to 2.856" collector tube that is 20.9" long where it flows into a "resonation" chamber with an H pipe again at 10.4" behind the meeting pint of the second Y and in front of the Resonator.
In both cases the distance for an H-pipe to be installed in an LQ4 was nearly 7 feet back of the header merge point, before the resonation chamber and in my opinion at that distance packaging would become an issue and this system would be more work than benefit. If one was so inclined to still use an X I would install it around the distance of the 3rd or 4th harmonic (20.9" or 41.7").
Resonation chambers are supposed to be 2x the c.i.d. of the engine, so if you are using a dual system as we are there should be a resonation chamber on each side equivalent to the c.i.d of the engine. In this case you should be running a Flowmasters, Super Turbos or any "chambered" mufflers (no glass-packs or Magnaflows) on each side that has a internal volume of 364 cubic inches or more. To the exhaust gasses the chamber represents enough atmosphere that most any harmonics or scavenging down stream of the chamber has almost no factor in performance as long as the pipe is large enough to exhaust the gasses of the engine. It is at this point that sound, noise and drone will become a factor. Allot of successful systems will add another muffler (glass-packs and magnaflows usually) down stream to keep noise to a minimum and sound smooth. That being said over sized pipes will have a higher chance of being loud or causing a drone so tail pipe length will become a factor. Drone can be canceled out with a J pipe, but that gets to be tedious and technical.
Old 11-05-2014, 06:44 PM   #15
aknovaman
Why do you say j pipes are tedious and technical?
I have described here how to simple eliminate any drone.
http://ls1tech.com/forums/conversion...ps-solved.html
Current project 1959 Willys = GEZR TRUK
Geezer is a Latin compound word made up of two roots.
Gee meaning Urine Stain and Zer meaning your pants are open!
FMCDH GBU and GBA
http://www.youtube.com/user/aknovaman/videos
aknovaman is offline   Reply With Quote
Old 11-05-2014, 07:04 PM   #16
69gmcc10
69gmcc10's Avatar
Thanks for posting that. It isn't that it is that difficult, I just didn't want to write an explanation about it. nice write up!
Old 11-06-2014, 09:17 AM   #17
jackyl9999
jackyl9999's Avatar
Thanks for the info guys. Very informative.
1990 K1500 Daily
