Old 07-08-2015, 12:57 AM   #1
profe56
FM & USB not bad
I found this today, cheap I think.
The only think I don't like is: when the electric fan turns on, the sound makes a noise.
Tell me if there is something to take away noise.
Also there is no AM stations but for 30bucks what can I expect.
profe56 is offline   Reply With Quote
Old 07-08-2015, 06:41 AM   #2
swamp rat
swamp rat's Avatar
Re: FM & USB not bad
Are you saying that when you turn the key on the electric radiator fan turns on and you get a buzzing noise out the speaker? or do you mean the heater fan? or is there a fan inside the radio? never seen nothing like that before.
Try replacing the plugs and wires with resistor units to keep speaker noise at bay
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline   Reply With Quote
Old 07-08-2015, 08:44 AM   #3
leftybass209
leftybass209's Avatar
That stereo would make a nice AM project. Gut an AM radio and adapt the internals of this to it.... now the wheels are spinning. Not much of a radio though, it's hardly a faceplate even!
leftybass209 is offline   Reply With Quote
Old 07-08-2015, 09:04 AM   #4
Jason Banks
Jason Banks's Avatar
That's pretty cool. I was looking online to see if it could be purchased and it looks like a Mexico only item. Did you get it at a swap meet or something?
I think if you tried to transplant the guts into an AM....you would have an issue with the Display.
It would be nice if it was FM and Bluetooth...
For your noise problem. It could be that you need a power line or antenna line filter. Or maybe try changing where you are getting the 12v for the radio from in the fusebox.
Jason Banks is offline   Reply With Quote
Old 07-08-2015, 10:14 AM   #5
Hart_Rod
Hart_Rod's Avatar
+1
Hart_Rod is offline   Reply With Quote
Old 07-08-2015, 10:15 AM   #6
profe56
Thank you swamp rat: yes electric fan radiator
I'll post more pictures and the box package tonight when I get home, for me sounds good is not a great system but sounds good and also we don't need to cut nothing
Old 07-08-2015, 10:46 AM   #7
michael bustamante
michael bustamante's Avatar
youll need to put a noise suppressor on the positive wire (red). you see them on the kewoods and such
1967custom
michael bustamante is offline   Reply With Quote
Old 07-08-2015, 10:57 AM   #8
I see it also has an SD card slot. I always took the stock radios out to put good stereos in anyway. I'd rather listen to good sounding music than look at a stock radio face.
Old 07-08-2015, 11:27 AM   #9
profe56
Thank you Michael. Now I think I could find the noise supressor at Radio Shak
Old 07-08-2015, 11:57 AM   #10
Nitis
Nitis's Avatar
I'm interested for sure. Id like to get my hands on one. Am would be nice but I mostly use pandora
Nitis is offline   Reply With Quote
Old 07-08-2015, 12:15 PM   #11
berch 69GMC
berch 69GMC's Avatar
This old post may interest you guys. I have used these directions and the hardest thing about it was finding a radio shack still in business. Search:
AUX input jack for 67-72 AM radio
berch 69GMC is offline   Reply With Quote
Old 07-08-2015, 02:50 PM   #12
swamp rat
swamp rat's Avatar
This one?
http://67-72chevytrucks.com/vboard/s...d.php?t=502427
Mike.
72 3/4T 4X4
4" BDS Lift
33" BFG's
Old 07-08-2015, 04:19 PM   #13
berch 69GMC
yes sir. I used those instructions, two 4in speakers from wall mart. cut the original truck speaker out, lined it with black felt and screwed the speakers to it. Works flawlessly.
Old 07-08-2015, 04:41 PM   #14
boraxman
Keepin an eye out
boraxman's Avatar
Where did you get that stereo? A quick search found them sold out at one vendor for $37
1970 Chevy C10 SWB 5.3
1996 Toyota Tacoma SR5 4x4
2007 Vespa GTS 250 Scooter
ZIP 91351
boraxman is offline   Reply With Quote
Old 07-08-2015, 05:42 PM   #15
fartblossom
fartblossom's Avatar
Extreme Active Wear?
I guess they make radios AND clothes for X-games competitors.
If the volume is those two little buttons, do the knobs do anything?
fartblossom is offline   Reply With Quote
Old 07-08-2015, 11:47 PM   #16
profe56
Hi folks: finally I got back home,I've seen your replys during day
Now you can see the package box with more informatio. See it and I have more questions and yes if can I share one with you I'll be more than happy
This is the way looks installed.
Old 07-09-2015, 12:04 AM   #17
Nitis
Nitis's Avatar
where did you get it?
Old 07-09-2015, 12:25 AM   #18
profe56
This is the answer:
Everyting begins when I went to a electric parts in Tijuana because I did need to fix the or replace the temperature fan switch, when I saw this radio that took my attention and asked the cost.
I understand this forum has rules and I don't pretend make bussines but if one of you would like to have one I could help you.
I told the clerk that I went to upload this information at this forum and may be someone would like to have one. The only thing this was the last one but He said they can ask for more in stock
Old 07-09-2015, 07:10 AM   #19
They also make very comfortable jock straps
