03-03-2016, 09:57 AM | #1 |
LS3 parts Cam, pushrods, valve springs
I have a set of LS3 factory pushrods (7.4) and valve springs with less than 150 miles on them. I also have a L99 factory cam with less 150 miles on it. I replaced the parts when I went with a bigger cam. I will take $100 a set for the valve springs and pushrods and $100 for the cam. Let me know if you have any questions.
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
03-04-2016, 03:45 PM | #2 |
Re: LS3 parts Cam, pushrods, valve springs
Hey rob,
How would this Cam do in a 5.3 LC9 Gen IV? the stock cam spec's are .467/.479-196/201 at .05 not sure the Lobe separation...
1956 Chevy Bel Air 2 door 1956 Chevy 210 4 Door 1970 K20 LWB project the Hulk build w/Supercharged 4.8L-ly2/4L60E HULK BUILD 1970 C10 Yellow/White Deluxe LWB w/ 5.3L-LC9/6L80E 1968 K10 LWB Dark green my son calls it "THE HULK Jr"HULK JR *SOLD* GO GO!!! |
03-04-2016, 03:50 PM | #3 |
I'm not really sure. Does it have VVT and DOD?
03-04-2016, 03:53 PM | #4 |
its a 2011 with DOD no VVT. It also has the 6L80E trans all currently stock
1956 Chevy Bel Air 2 door 1956 Chevy 210 4 Door 1970 K20 LWB project the Hulk build w/Supercharged 4.8L-ly2/4L60E HULK BUILD 1970 C10 Yellow/White Deluxe LWB w/ 5.3L-LC9/6L80E 1968 K10 LWB Dark green my son calls it "THE HULK Jr"HULK JR *SOLD* GO GO!!! Last edited by First c10; 03-04-2016 at 04:19 PM. |
03-04-2016, 05:17 PM | #5 |
looks promising rob. will this set up work in my 03 yukon 5.3 set up 4l60 dbw?
1967custom |
03-08-2016, 10:14 PM | #6 | |
Michael - your motor has a 3 bolt cam, so this won't wok on your motor.
03-09-2016, 12:06 AM | #7 |
I am not sure on the 2011 LC9 but on the 4.8 I had to replace the sprocket to 3 bolt because the comp cam was a 3 bolt. So I have a singe bolt sprocket. I need to check lift and make sure it wont bring up any problems because the truck runs great just would like a little bigger cam.
03-09-2016, 08:50 AM | #8 | |
07-20-2016, 03:14 PM | #9 |
How was the idle with this cam? Noticeable chop or smooth? I need to check my sons truck but he has a GM reman 5.3 that he wants to swap the cam in. His truck is a 2006. If I can determine that it will work for him he would take all of it.
Born and proudly residing in a Red State ! |
07-20-2016, 03:52 PM | #10 |
lmk!
07-23-2016, 10:56 AM | #11 |
My son says he needs a different cam so we will pass.
05-02-2018, 08:54 AM | #12 |
bump
