08-16-2017, 10:22 PM | #1 |
hydro blasting? pro and cons
is hydro blasting safe to use on the sheet metal of my 47 3100, is warp age an issue with hydro blasting?
08-18-2017, 12:36 PM | #2 |
Re: hydro blasting? pro and cons
I had some body parts hydro blasted with no issues.
Project Engine Stand 1972 SWB conversion: http://67-72chevytrucks.com/vboard/s...d.php?t=673914 1970 Nova: http://67-72chevytrucks.com/vboard/s...d.php?t=708161 |
08-19-2017, 10:29 AM | #3 |
Lost amongst the CORN
Damage to sheet metal is NOT Ill repeat NOT related to heat. So if your potential hydro blaster is touting his services will prevent damage, run cause the guy is a fool or a liar.
Warpage is caused by the media acting like thousands upon thousands of little hammers penning the metal stretching it out as they hit the surface. You can take a themo heat gun and the measure the before and after blasting temps can you won't see a darn bit of difference in metal temp. How do you warp metal via heat if the metal never changes temp???
Currently working on How To Videos and custom metal 70 Chevelle gettin Sliced and Diced Anything But STOCK 70 Chevelle SS455 not a typo its a BUICK BABY 49 and 72 Chevy Trucks restored to original...close to it Drommer Stor....Norwegian for Dream Big http://s969.photobucket.com/albums/a...lle/?start=all https://www.flickr.com/photos/47922830@N03/ Pictures of my work and projects |
08-20-2017, 09:28 PM | #4 | |
It wasn't heat I was worried about, really just looking for input if people have tried the process with success, I'm more or less talking about the small hydro blasting kit that can be used at home, if it work ok, I know its alot of work and will take a lot of time but I like the idea of dustless blasting, and there no one in my local area media blasting |
08-21-2017, 03:19 PM | #5 |
Make sure to clean out EVERY last square inch while its still wet with a pressure washer. Wet media packs tightly and doesn't come out easily once it's dried. I'd rather use a traditional method as the water/media mix carries more momentum than dry media, so the warping could potentially be much worse.
Project Goldilocks '66 C10 Short Fleet BBW Build '65 C10 Highly Detailed Stock Restoration Thread '78 Camaro Targa Roof Build '55 International Metal/Body/Paint Work '66 F100 Full Rotisserie Restoration '40 Packard 120 Convertible Coupe Restoration How To Restore and Detail an Original Gauge Cluster How To Detail Sand Body Panels, Edges, Corners, Etc |
