Instant center location
51 chevy truck, mustang ii , 2” drop spindles, triangulated four link, Been reading about instant center, anti squat line, center of gravity etc...question is, based on your previous experience, when installing the four link, lower bar is parallel with ground...what degree down (towards front) should the upper bar be to get an IC at or slightly below the squat line, or what has worked well for you? Not looking for a drag setup, more street and fun curve driving, think autocross.. i ran across an article i think art morrison engineer, suggested 6-7 degrees down..opinions?
Post Whore
![]() ![]() Join Date: May 2015
Re: Instant center location
It's hard to say what your truck will need...every one differs some....
On most street 4links, a parallel bar setup works good... If you have the mount plates with multiple hole your limited by whatever the hole pattern will get you If you've never read this it's some good info.....http://www.ronsuttonracetechnology.com
Mongo...aka Greg RIP Dad RIP Jesse 1981 C30 LQ9 NV4500..http://67-72chevytrucks.com/vboard/s...d.php?t=753598 Mongos AD- LS3 TR6060...http://67-72chevytrucks.com/vboard/s...34#post8522334 Columbus..the 1957 IH 4x4...http://67-72chevytrucks.com/vboard/s...63#post8082563 2023 Chevy Z71..daily driver Last edited by mongocanfly; 11-17-2019 at 09:01 PM. |
![]() Join Date: Jan 2011
Depends on lots of things. What the truck will want as far as instant center and what you can get with the kit that you have may not line up. Until you see what the weight split looks like the amount of power you have when done and the total weight of the truck it will be hard to determine. You can map the four link out on paper and look at all the available combinations to see what the kit has. We would do this on the drag cars and shift the front bracket up and down to see where it needed to go to get us the range we wanted and then weld the brackets in the car. Then the chart we made with the map we drew was used to tune the car when we were done. There are programs out there that will do the work for you.
Jimmy
60 to 66 Chevy and GMC window decals http://67-72chevytrucks.com/vboard/s...d.php?t=661131 Good friends, good food and a hotrod what else do you need? 1966 BBW long fleet Daily driver 1965 BBW short fleet Sold and going to a good home 1965 Suburban 2003 3500 Duramax 2005 Ultra Classic |
![]() Join Date: Jul 2010
With the lower bar level, you can set some general rules. A steeper angle on the top bar (down in front) will move the IC closer to the rear axle. A flatter angle (closer to ) but still down in front) will move the IC towards, or past, the front CL. * A flat ) angle top bar will be parallel with the lower bar and thus have NO weight transfer. - but is good for burnouts. Starting in the 5 to 7 degree range will get you somewhere close for these trucks.
GoodGuys 2012 Pro-Truck Champion ![]() 2012 Truckin' Throwdown Champion GoodGuys 2011 National Champion ![]() 2011 Truckin' Throwdown Champion GoodGuys 2010 National Champion ![]() Proud to put our products up against all others! |
#5 | |
Here's a really detailed post about setting 3/4 link bar angles.
https://www.pro-touring.com/threads/...85#post1009285
Project Goldilocks '66 C10 Short Fleet BBW Build '65 C10 Highly Detailed Stock Restoration Thread '78 Camaro Targa Roof Build '55 International Metal/Body/Paint Work '66 F100 Full Rotisserie Restoration '40 Packard 120 Convertible Coupe Restoration How To Restore and Detail an Original Gauge Cluster How To Detail Sand Body Panels, Edges, Corners, Etc |
Post Whore
That's a good link John...one I hadn't seen before..although alot of this is the same info found elsewhere..got it saved with my others though...never can have to much..
Thanks for the help, heres what i ended up with....
