Old 11-06-2023, 01:52 PM   #1
colliseumj
issue with traction
OK, I seem to have a serious issue with traction(actually the lack of it) on my friend 68. It's lowered 4.5/6.75 and never adjusted the pinion angle. Would the correct angle help with traction? if so, what angle do we need to shoot for?
colliseumj is offline   Reply With Quote
Old 11-06-2023, 02:28 PM   #2
Keith Seymore
Keith Seymore's Avatar
Re: issue with traction
No.
Pinion angle has nothing to do with traction.
You do, however, want the rear pinion working angle to be 3 degrees for u joint life and smoothness. Equal and opposite to the front joint would be ideal.
K
Chevrolet Flint Assembly
1979-1986
1986 - 2019
Keith Seymore is online now   Reply With Quote
Old 11-06-2023, 04:28 PM   #3
Ziegelsteinfaust
Do you have leafs or truck arms
Ziegelsteinfaust is offline   Reply With Quote
Old 11-11-2023, 04:10 PM   #4
theastronaut
theastronaut's Avatar
If it has trailing arms you'll need to raise the front pivot points up, preferably above the axle tube height for the most effective increase in traction. You can buy brackets to replace the originals that have multiple holes for tuning the pivot height, or you can remove the stock brackets and flip the over.
theastronaut is offline   Reply With Quote
