Old 10-10-2009, 11:28 PM   #326
brn agn
brn agn's Avatar
Re: 1970 VA Longbed Project
Originally Posted by VA72C10 View Post
And guess why Jason added this dormer in the roof of his shop????
Lift?
1969 C10 SWB Project Charity Case AKA "Roscoe"
1971 Cheyenne Super A Combined Effort
The Service Station-A practical ministry for those in need
brn agn is offline   Reply With Quote
Old 10-11-2009, 12:16 AM   #327
VA72C10
VA72C10
VA72C10's Avatar
Originally Posted by brn agn View Post
Lift?
Winner!
Yep, he's getting a used but very nice assymetrical lift tomorrow. I will be going by to help him after Church. It is going to help a ton with setting the cab and bed back on the chassis and doing exhaust, etc....
Looking for a 67-72 swb or blazer project in or around VA.
VA72C10 is offline   Reply With Quote
Old 10-11-2009, 12:20 AM   #328
VA72C10
VA72C10
VA72C10's Avatar
Well, I am still smiling from a sense of accomplishment today. It was my first time messing with a rear at all and was easier than expected. I asked Jason some questions to make sure I didn't mess anything up, but it was not bad at all. Jason has really been a great help through this and I wouldn't be nearly this far without his help and help from many on this board.
I got good at taking axles out and putting them in...I put the cart before the horse so to speak and forgot to put the brake brackets on before the axles. So I pulled them again and installed them again. Second time was like 2 minutes to pull and reinstall max.
Old 10-11-2009, 12:24 AM   #329
VA72C10
VA72C10
VA72C10's Avatar
Well, here are more pictures from today's festivities
Parts I finished painting the other day after their second coat....purdy
Getting the axles out
Tape is to label drivers and passengers in case there were wear marks...Jason recommended it an I figured better safe than sorry.
Old 10-11-2009, 12:25 AM   #330
VA72C10
VA72C10
VA72C10's Avatar
Then I started cleaning it up
Found a bunch of numbers buried in the gunk
Old 10-11-2009, 12:28 AM   #331
VA72C10
VA72C10
VA72C10's Avatar
A note of caution....when the wire wheel gets overly used....stop using it It started flinging projectiles my way and I didn't want to leave to pick up another one so I used it till basically only the cup was left. However, when I stopped to scratch an itch on my leg, I found it wasn't an itch....It was some of the metal from the wire wheel imbedded in my thigh. I had about 20 pieces in me.
This one went through my jean shorts and well into my skin
Black specs are undercoating/gunk coming off the rear and it didn't all come off even after two showers/scrubbing...
Red lines are blood from imbedded metal
Old 10-11-2009, 12:40 AM   #332
VA72C10
VA72C10
VA72C10's Avatar
Here is a prime example why i spray and don't powdercoat.
These brackets were coated and after only being mocked up..never driven on....they have peeled away and exposed bare metal to rust....
I used a scotchbright pad and scuffed them up, installed them on the rear, installed the axles for the last time I painted the end of the axle befrore I put the brackets on so the metal would be protected.
For those who haven't messed with the rear axles before, here's what I learned....lust loosen the one 1/2" bolt that holds the silver pin in place.
Remove that bolt and the silver pin. Then push the axles (one at a time) in towards the center and the little C-clip will be easy to pull out. Once you pull the C-clip out, slide the axle out. Then repeat on the opposite side.
The tip Jason added was to re-install that center pin and bolt to make sure if you bump the yoke and spin the gears, they won't be able to come loose or shims come out. Sounded like good insurance to me since I halfway dropped the rear off the jack
To re-install....take out that bolt and large silver pin again, slide the axle back in. (you will get almost all the way in and then by feel you have to angle it up and spin it slightly until it fits into the gears) Once the axle has slid as far as it will go, you will see the groove for the C-clip. Insert the clip then pull back out on the axles. This seats the C-clip and won't let it fall out. Duplicate on the other side and then re-install the silver pin and 1/2" bolt. (1/2"X2" or so)
To many of you, I guess this post is a waste and child's play, but hopefully it will help someone in the future.
One other note is I found it easier to rotate the yoke to get better access to the bolt or to be able to slide the pin out. Just do it slowly to not disturb the other gears with the pin out.
Old 10-11-2009, 12:42 AM   #333
VA72C10
VA72C10
VA72C10's Avatar
Okay, and now.....the Money shots
Old 10-11-2009, 11:45 AM   #334
brian69longbed
brian69longbed's Avatar
yeah i have done this too! it went into my forearm. that doesn't feel good
69' 1/2 ton
LONGBED__
_______ |__\__
|__(O)______(O)]
My build thread:
http://www.67-72chevytrucks.com/vboa...d.php?t=354115
brian69longbed is offline   Reply With Quote
Old 10-11-2009, 11:46 AM   #335
brian69longbed
i don't think you need that rear end.. you should just give it to me...
ha ha looks awesome man
69' 1/2 ton
LONGBED__
_______ |__\__
|__(O)______(O)]
My build thread:
Old 10-11-2009, 12:45 PM   #336
fletch4x4
fletch4x4's Avatar
i want rear discs...
Bagged/Turbo 1970 GMC C-10
Crew Cab 1984 Chevy R-20
fletch4x4 is offline   Reply With Quote
Old 10-11-2009, 01:32 PM   #337
VA72C10
VA72C10
VA72C10's Avatar
It didn't but the funny thing was, I pulled about 20 of them out and hadn't even noticed them until that one....
Sure, you trade me cabs and I'll give you the rear
I wanted them too but thought they were out of reach. Mike (camtoys1) gave me a deal I couldn't pass up and now that the rear is painted and the brakes are on I am STOKED!!!
Old 10-11-2009, 01:44 PM   #338
Hart_Rod
Hart_Rod's Avatar
What high temp paint did you use on the calipers? Also, if you plan on running a super track bar, I would recommend cutting off the mount where the original track bar bolts to. This will give you some much need clearance if you plan on taking the exhaust over the axles.
Hart_Rod is offline   Reply With Quote
Old 10-11-2009, 06:31 PM   #339
gcburdic
Restoration Virgin!
gcburdic's Avatar
Jonathan,
did you change the rear axle seals and bearings as well???
Geoff with a G
1968 Chevy C10 SWB The Mistress
1972 Custom Deluxe C20 Suburban A Suburban Named Isabella
1966 Ford Mustang Mama's High School Graduation Present
gcburdic is offline   Reply With Quote
Old 10-11-2009, 08:47 PM   #340
VA72C10
VA72C10
VA72C10's Avatar
They are actually powdercoated black. I am going to dump the exhaust before the rear. Good advice for someone running it all the way back though.
Originally Posted by gcburdic View Post
Jonathan,
Mike did before he sold it to me
Old 10-11-2009, 09:05 PM   #341
VA72C10
VA72C10
VA72C10's Avatar
I'll have the pictures later....uploading them to photobucket and watching a movie with my wife first.
Old 10-11-2009, 10:00 PM   #342
VA72C10
VA72C10
VA72C10's Avatar
Intermission.....
Had another productive day today. Jason had the lift up when I got there after church. Helped very little with getting some details done. He tested it with his chevy shortbed and all works well.
Old 10-11-2009, 10:46 PM   #343
VA72C10
VA72C10
VA72C10's Avatar
Took off all the E-brake lines since I won't be running one in the rear. Cleaned up where they went and painted it up. So I decided that I wanted another coat or three on the frame. Went ahead and painted two to three coats on top of the three or four for a nice thick hammered finish and repaired a few areas I had damaged. Came out even deeper black and more sheen which I like.
Then started painting the last few components so I could put the rear together.
Old 10-11-2009, 11:44 PM   #344
VA72C10
VA72C10
VA72C10's Avatar
For future reference, I got 5" 3/4" bolts for the trailing arms. I thought they would be too long, but with the two flat washers and the lock washer, they work fine.
Then I mocked up the brackets for the ECE super trac bar
And mocked up the bar itself...make sure the angle of the bar lines up with the arms. It's a bear to get in and out of the mount. I used a screwdriver to make sure the bushing was centered in the hole and the bolt would go through.
Old 10-11-2009, 11:46 PM   #345
VA72C10
VA72C10
VA72C10's Avatar
Started assembling the rear....
At this point I hadn't started centering the rear...
Getting it centered
Driver's side with the trac bar
Pass side
Old 10-11-2009, 11:47 PM   #346
VA72C10
VA72C10
VA72C10's Avatar
Looking good
Started moving it up and then.....uh oh.....
Old 10-11-2009, 11:52 PM   #347
VA72C10
VA72C10
VA72C10's Avatar
The U-bolt is hitting the front of the C-notch. I thought this might be an issue because of the 2" lowering blocks and the 1/4" the ECE Super trac bar brackets space it up.
Passenger side has a tiny amount of room but not enough to make a difference once I go to center the rear, both sides will hit before the rear goes all the way up.
Old 10-11-2009, 11:59 PM   #348
VA72C10
VA72C10
VA72C10's Avatar
I will center the rear up tomorrow or Tuesday when I get back over there with some rims. That will tell me more about how much clearance I will need.
The plan to fix this is to move the trailing arm crossmember forward...but first, we are going to mock up the driveshaft and see how the carrier bearing will be affected.
I think we can shift it forward a bit and if not we can modify that carrier bearing mount. Moving the trailing arm crossmember will also allow us to have the wheels centered in the rear wheel wells when the truck is lowered to ride height so we will work from that setting. Going to take a little mock up and a little work and some touch up painting, but it will be worth the end result. The other option is to shim out the mounts for the trailing arms on the crossmember. I will take a look at all the options and try to come up with the best overall solution.
Old 10-12-2009, 12:05 AM   #349
VA72C10
VA72C10
VA72C10's Avatar
Even though I ran into a small snag, it was still a productive day. I also got the front crossmember back in. Had leftover grade 8 bolts from the C-notches that we welded in and those work great for the crossmember. That's good money saved because I just spent almost 60 on bolts for the bags and bag brackets.
Here's the frame with the crossmember
And the money shot from today
Old 10-12-2009, 12:19 AM   #350
VA72C10
VA72C10
VA72C10's Avatar
Forgot that I also put the shock relocator brackets on..... Backwards the first time
Thread Tools
Display Modes
