Old 11-29-2009, 07:05 PM   #1
steinepstein
Project Burro Viejo
I've been a loyal follower of this site for many years now and have learned a ton from the followers and contributors and feel like its time for me to give a little back and share my project. This was originally a NM truck that had an Olds 455 in it. Most of the exterior trim and marker lights were shaved and it was lowered about 2 inches in the front. The truck was very cool looking when I bought it, but the more I started tearing into it the more problems it had. I decided it was time to go completely through it and update things, and have some fun. In the last two months I have moved the truck from NM to Chicago.
Exterior shot on the trailer
steinepstein is offline   Reply With Quote
Old 11-29-2009, 07:07 PM   #2
steinepstein
Re: Project Burro Viejo
The motor is a 383 sbc with vortec heads and a Holley 950 commander. Instead of using the Holley computer I wanted to go with a Motec M48 because I have some previous experience with these and they are very adaptable. The trans is a 700r4 with all the goodies.
Old 11-29-2009, 07:09 PM   #3
steinepstein
Many changes to come, but for now my main goal is to get the engine running, which is not easy. There are a ton of fittings and parts that need to be created to adapt.
Old 11-29-2009, 07:27 PM   #4
Puropedo
Sweet project! I like the project's name, is your truck a GMC?
Puropedo is offline   Reply With Quote
Old 11-29-2009, 07:40 PM   #5
steinepstein
Yea, 1968 GMC 1/2 ton. That blue on the fenders is the color when I purchased it 15 years ago. It's still a great color, but I feel myself leaning toward something else, maybe a Porsche gray.....
Old 11-29-2009, 07:47 PM   #6
GASWAGON
AMERICAN IRON ADDICT
Nice truck! I like the welds. Is that a GM performance parts acc. drive set-up on the front of the engine?
GASWAGON is offline   Reply With Quote
Old 11-29-2009, 07:51 PM   #7
big_al_71
big_al_71's Avatar
One of the Favorite parts of it so far is the name of the project....
Keep the picts coming.....
Get your facts first, and then you can distort them as much as you please!!!!!.
Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild
big_al_71 is offline   Reply With Quote
Old 11-29-2009, 07:57 PM   #8
steinepstein
Yea, GM deluxe serpentine kit on there. I'm going to have to figure out how to adapt that AC unit to a Vintage Air setup.
Hooker headers with ceramic coating. I was originally going to go with a carb setup and had exhaust scavengers welded in there. Those will have to get capped off.
Old 11-29-2009, 11:39 PM   #9
mcbassin
Still Learning
mcbassin's Avatar
Project Burro Viejo? Please translate for me? It's not a donkey? Looks like a good start! 15 years in waiting?
Old 11-30-2009, 02:01 AM   #10
CheyenneShop
CheyenneShop's Avatar
With a name like that how could anyone go wrong.
72 Cheyenne shorty "CheyLow"
72 3/4 long 4X4
69 SWB "Prospector"
68 C/10 shorty - "Picacho" http://67-72chevytrucks.com/vboard/s...d.php?t=428379 sold to "93redsled"
Have you heard about C10 Talk? C10 Talk is a podcast all about C10 Trucks, the builders, the vendors, and most importantly the C10 Community. Check us out online at www.c10talk.com
CheyenneShop is offline   Reply With Quote
Old 11-30-2009, 06:36 PM   #11
steinepstein
Oh yea, definitely a donkey. Hard working, durable, and stubborn, no doubt.
I bought this thing in college and it moved from garage to storage unit to garage to storage unit. Whenever I had spare cash or time I was always burning my cash on it. Now it sits in Manteno, IL, in a garage where I can work on it and have plenty of space. I should have this thing running by the end of the year.
Old 02-03-2010, 08:41 PM   #12
steinepstein
Couple updates:
We have spending a lot of time wiring. Going to need five relays to run nitrous, radiator fans, fuel pump, ignition system, and FI system. The Motec system will run the radiator fans at a requested temperature and dump more fuel when I request nitrous, pretty trick. The other relays are used for safety/redundancy.
I also purchased an Entropy radiator from ebay. I am quite pleased with the quality and price, but will have to fabricate new brackets or do something new. The serpentine belt drive plus the radiator fans makes for a tight fit. I feel like that engine could go back a few inches, maybe more.
I also purchased a set of mild notches from Porterbuilt, nice quality, gotta bring this donkey down a couple more inches and stuff some big meats in the back. I'll be switching over to a trailing arm setup also.
Old 02-03-2010, 09:40 PM   #13
Ronm909
67GMC Slammed
Ronm909's Avatar
nice project, subscribed
my dropmembered 67 GMC build thread http://67-72chevytrucks.com/vboard/s...d.php?t=383215
Ronm909 is offline   Reply With Quote
Old 02-25-2010, 11:06 PM   #14
steinepstein
Picked up an ART kit from VA72C10, did some mock up last weekend.
Have to pull the engine out because I dented the oil pan during install and I need to make sure no damage has been done and the oil pickup is not pressed against the pan.
A lot of the dirt and dust buildup was bugging me also, I want to get everything cleaned up, painted, and tightened down for final install, so here I am.
Project Burro Viejo: http://67-72chevytrucks.com/vboard/s....php?p=3778216
Old 02-25-2010, 11:15 PM   #15
steinepstein
I got the engine out and on a stand via forklift, actually pretty easy.
I have an old sprint car aluminum block that is supposedly sold. I decided to mock it up in the frame with the engine back further, before I get rid of it. I really wanted to build an Al SBC with a dry sump setup and put it in the Burro Viejo but the block is leaking between the cylinder walls and my engine builder didn't recommend it.
I really don't like how far the engine sits forward in these trucks, this is something that is bugging me, I want to get it back as far as possible, without making drastic changes to the firewall. I talked to the HAVOC owner and he did a little welding and fabrication to get the engine back against the firewall, I will probably be doing the same, thanks HAVOC!
You can just pick up that Al block and stick it right in there!
Old 02-25-2010, 11:24 PM   #16
steinepstein
I had Rad Rides by Troy weld up those exhaust extensions and install bungs for the O2 sensor and the exhaust temp sensor. The cars in that shop are unreal, absolute perfection, you can see them on their website.
Quick shot of the front suspension crossmember with the ART plates marked up and ready to be drilled.
Old 02-25-2010, 11:34 PM   #17
sourkraut
sourkraut's Avatar
great looking project! what kind of wiring harness are you using?
"The way it is" truck build
http://67-72chevytrucks.com/vboard/s...d.php?t=359200
sourkraut is offline   Reply With Quote
Old 02-25-2010, 11:44 PM   #18
VA72C10
VA72C10
VA72C10's Avatar
Looking good!!!
Old 02-26-2010, 12:26 AM   #19
nuke1
nuke1's Avatar
NICE TRUCK!!!! I like your thoughts and how your are going about everything, Motec huh? we have played with megasquirt up here some. That is what i want to use for my truck, but may consider the motec yet.
James
1968 GMC "HAVOC"
1986 GMC "Frank"
J.J.R.H. Design & Consulting
My 68`Rebuild "HAVOC": http://67-72chevytrucks.com/vboard/s...d.php?t=316300
A 58' chev build thread: http://www.67-72chevytrucks.com/vboa...d.php?t=311238
1969 Camaro Pro Touring http://67-72chevytrucks.com/vboard/s...61#post3513361
Swiss Cheese: http://67-72chevytrucks.com/vboard/s...d.php?t=384390
Adjustable Trailing Arm How-To: http://67-72chevytrucks.com/vboard/s...d.php?t=321100
1968 Ford Farm Truck: http://67-72chevytrucks.com/vboard/s...=1#post6555587
nuke1 is offline   Reply With Quote
Old 02-26-2010, 11:25 AM   #20
steinepstein
Nuke,
I used to work for a guy in Dallas, Bob Norwood, Norwood Autocraft, that used Motec a ton, he knows it backward and forward. I was able to play with the software a bit, it's a good system. The M48 is an older version, but still fine, you can find them on ebay once in a while for a lot less. I don't know a lot about Megasquirt, but I know a lot of players are making big time power with Big Stuff 3. BS3 seems to be the best out there from a hardware standpoint.
Old 02-26-2010, 11:28 AM   #21
steinepstein
sourkrat,
Using a EZWiring harness with 21 circuits. Wanted to get as many as possible because of the extra relays on the FI harness. Since there is so much custom wiring already, I wanted to use a basic harness, since an exact fit harness may have gave me problems and cost much more.
VA72C10,
Thanks, going to get my crossmember drilled up today! I'm excited to go full bags.
Old 02-26-2010, 11:38 AM   #22
Hart_Rod
Hart_Rod's Avatar
Nice project. You could always use 6 cylinder motor mounts to get your motor set farther back. They should bolt right to your frame and crossmember without any modification. That's what I've got in my 68 S/C truck and it sets the motor about as far back as you can go with a SBC.
Hart_Rod is offline   Reply With Quote
Old 02-26-2010, 12:27 PM   #23
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
This is gonna be one killer truck when done..
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
FRENCHBLUE72 is offline   Reply With Quote
Old 02-26-2010, 02:40 PM   #24
mcbassin
Still Learning
mcbassin's Avatar
Looks like some serious ponies under the hood!
Old 02-26-2010, 06:29 PM   #25
steinepstein
I've been asking a lot about how to get the engine back further I will try the I-6 mounts, thanks.
I've got a set of vortec heads on there with 2.02/1.6 valves and bowl work completed by Rehrer Morrison out of Dallas, TX. The cam should idle nicely and take it up to about 6500rpm, so I'm hoping to make north of 450hp. It also has a nitrous relay that will automatically dump more fuel into the motor when I hit the switch. Good mule motor.
