Rottenwood Garage Member
1985 S10 V8 swap...save me some time please!
Ok guys, I have never even considered playing with an S10 but one has dropped in my lap. I am going to do a 350/350 swap just because I have it sitting here and after I get it dialed in and right I plan on giving it to my nephew for his 16th birthday.
I don't have the time to weed through all the banter and opinions on the best kits and easiest way to go about the swap. Could some one PLEASE send me a link or thread to the best site or thread on what to buy so I have it all here when I begin?? Mounts, exhaust, x members, fans etc. Thanks
2004 Chevrolet Suburban C1500 2001 Chevrolet 2500HD Crew 6.0 1999 Harley Davidson Electra Glide 1972 Chevrolet C-20 Custom Camper "Dump Truck" 1972 Chevrolet C-20 Suburban "Big Green" 1969 Chevrolet C-50 Wedge Hauler "Leonidis" 1966 C-10 2x4 short fleet 327 4 speed "Race Truck" 1952 Plymouth Cranbrook "Rican" (my grandfathers) 1931 Ford Model A Coupe "Black Beauty" 1930 Ford Model A truck "Club Cab" 4x4 Rottenwood Garage and Speed Shop.....where everything must be racy! It's not just a hobby..It's a LIFESTYLE!!! Thanks for nothing Barrett-Jackson You cant fix stupid or teach accountability! Time wasters, looky Lous and tire kickers are everywhere! |
Re: 1985 S10 V8 swap...save me some time please!
giving a 16yo a V8 powered s10 is not a good choice, but thats none of my business.
but, mounts are easy to make and use facotyr chevy truck mounts, exaust is up to you, id run stock iron manifolds, x-member is stock, slighlty modified for oil pan, fan is best using the stock fan/fan clutch, and thats about it. super easy, get a driveshaft made, and have some fun. |
My first vehicle was a V8 as with most everyone I knew. I however didn't come from a child seat, seat belt and styrofoam hat on a bicycle generation. If his overprotective mother doesn't want it than so be it but Im going to enjoy it for a couple of years before he turns 16.
Jagsthatrun.com has good info and kits.
66 shorty ![]() |
http://s-seriesforum.com/forum/showthread.php?t=35696
the metal frame mounts can be bought on eBay for around $50.00. the factory rubber mounts to use are the ones from the 2.8l v6 the only factory cast iron manifold you can use; that will fit; are the 1982-1992 Camaro/Firebird; low performance version. the main problem will be the driver side. the steering column will have to be moved about 3/4" to the driver's side. if using a column shifter, the linkage will have to be bent/modified. the air conditioner evaproator housing(if you have ac) will have to be modified so it clears the passenger side valve cover. the firewall; mainly the body seam; will have to be modified with a big hammer. the best cooling radiator is the 1984-1989 Corvette radiator and it has auto trans fittings. use a motor driven fan. there's a lot more to it than this. like "donthekawguy" said; and get the "Chevrolet S-10 Truck v-8 Conversion Manual"; published by JTR (jags that run). around $25.00 Also, this is not going to be like our full-size pickups; where just about everything is a bolt-on and go. With the S10, it's going to be clearance issues with everything you do. Not questioning your mechanic abilities, but I don't care how good of a mechanic you are; it's not gonna be just a one weekend project.
Robert Member 1532 Last edited by 90\87Formula; 08-10-2014 at 11:49 AM. |
#6 | |
Now that's what I am looking for. Thanks. In the weeks since this post I have gotten the book, the jags mount brackets, the correct manifolds because I don't believe in headers and put my hands on a few other parts. We are fully capable here at Rottenwood Garage with all the tools, manpower and experience. Its just none of us have done a V8-S10 swap. We are really looking forward to it.
![]() Join Date: Apr 2005
Bump for progress. Looking to do an LS swap in a 99 S-10.
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
