#251 |
Re: 53 Surburban "Family Truckster"
nice work, digging the trans tunnel. I'm more of a square tunnel fan in most builds. allows more utilization and most time I just like how they look.
51' 99toLife finished 2011,355 sbc,5speed, patina, redoing whole truck, inter, bags, etc http://67-72chevytrucks.com/vboard/s...d.php?t=382481 49Hardtimes s/10 susp- bagged, vortec sbc, 5 speed, patina, sold http://67-72chevytrucks.com/vboard/s...d.php?t=594874 VIDEOS https://youtu.be/E8zHhjgS_lA https://youtu.be/E8zHhjgS_lA Geronimo 54' LS engine, static drop IFS, Client build, just about done http://67-72chevytrucks.com/vboard/s...62#post7399162 52' 3100 Slowly in progress, will be painted two toned, have 235 with a t-5, lowered OG frame Other projects, 49' farmuse 3100, killer Patina, will be slammed, LS engine, full done interior up next! www.coffeeandcustoms.com |
#252 | |
![]() Join Date: Mar 2007
I will probably sandblast the welds then treat them with some black rust guard prior to using kitty hair. Marc
...........__________ .................. ((__|__||___\____ ..;.;;.:;:;.,;..;((_(O))____ (_(O)) 1948 Chevy Truck - Finished SOLD!! 1953 Chevy Suburban "Family Truckster" Completed: Spring of 2021 http://67-72chevytrucks.com/vboard/s...d.php?t=605484 1994 4x4 Blazer - "Field Find" https://67-72chevytrucks.com/vboard/...ferrerid=30857 |
#253 | |
Marc
#254 |
Love your green truck. The Burb is lookin good and will be awesome.
http://67-72chevytrucks.com/vboard/s...d.php?t=648459 https://67-72chevytrucks.com/vboard/...d.php?t=769441 1951 MG TD 1967 Jeep CJ5 1.9L TDI 33X13.5X15 Mud Grapplers. 1952 GMC 9700 p/u 7.3L diesel on air, dually |
#255 |
Marc, great work.
1969 Chevy C10 SWB 350/400 4"-6" drop on steelies 53' Chevy 3100 5 window http://67-72chevytrucks.com/vboard/s...d.php?t=660793 http://67-72chevytrucks.com/vboard/s...d.php?t=771679 |
#256 | |
Marc
#257 | |
![]() Join Date: Mar 2011
my build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=459839 Jimbo's long bed step build:http://67-72chevytrucks.com/vboard/s...t=464626<br /> |
#258 | |
1 - Upgraded to a new bigger radiator. Needed to create room to fit. 2 - Painted a lot of my billet Street and Performance pulleys and brackets. Billet was too hard to keep polished. Black is the new chrome. 3 - Changed the collectors on my exhaust system and added some SS flex joints. 4 - Re-welded one of the mounts for my tail pipe that cracked (see item 3 above) You know how it is, after putting miles on them you decided to fix/change some stuff. I will take a couple pics of engine bay to give you an idea. Thanks Marc
#259 |
I know what you mean, did you go aluminum with rad...Jim
#260 |
Yes, but a 4 core. Because of the location of my steering box, I have a radiator that is 4" shorter than a stock radiator. I have never been pleased with the way my previous 3 core radiator cooled. Some of that might have to do with slug that was in my engine from sitting all of those years. I learned after my initial start up that Dexcool when mixed with air turns to a slug. I flushed the block and radiator a crap load of times. I think maybe my old radiator was partially plugged so I figured what the heck lets upgrade to a new 4 core while I'm at it. needless to say I have no cooling issues.
My truck never overheated it just ran hotter than I was comfortable but well within spec for the motor. Marc
#261 |
Sounds like some good upgrades!! They all need some TLC from time to time.
#262 |
![]() Join Date: Jul 2012
Nice upgrades on the 48. Looking forward to seeing them....no rush getting back on the Burb.
#263 | |
Here are a couple pics. I included a pic of the shrink band that I used. If you have never used these they work great and look clean. I basically changed out the motor components and ss radiator hoses to black and had to notch the radiator panel to make room for the radiator. Thanks Marc
#264 |
That truck is just bad ass
#265 |
Thanks man....
#266 |
Really incredible! Have looked at those bands before and never seen them installed. Were you happy with how they worked out so far?
#267 | |
Marc
#268 |
SAVING ONE TRUCK AT A TIME
![]() Join Date: Feb 2010
Very clean marc. Looks great.
53-suburban (99% done) 40-pick up (99.9% done) 12-cc lb dually D-max (dd) 61-crew cab D-max "PAY LESS FOR WHAT YOU NEED PAY MORE FOR WHAT YOU WANT" 53 BURBAN BARN FIND:http://67-72chevytrucks.com/vboard/s...d.php?t=404091 1940 PROJECT MOON SHINE:http://67-72chevytrucks.com/vboard/s...d.php?t=551088 1961 CREW MAX: http://67-72chevytrucks.com/vboard/s....php?p=6957999 |
#269 |
Marc! Saw your spread in Street Trucks....absolutely gorgeous!!!
-Greg '51 3600/s10 swap- in progress Build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=641511 |
#270 | |
Marc
#271 |
If they gave you digital copies, I'd love one of the straight on shots for wallpaper!!!
#272 | |
Marc
#273 |
Due to an expected/unexpected job change I have not been spending anytime on the burb. I did get out there tonight and I plan on working on it more and more now that I'm a couple weeks into a new job. Porterbuilt is close on the AD kits. Here are a few pics that they have shared on Instagram. A few of that changes are now the front and rear will be a bolt in unit. The rear rails flow like the stock rails. I was told they just need to fab the front radiator support and there done. In the meantime I will get my frame blasted in anticipation.
Marc
#274 |
Very nice parts. Looking forward to seeing them on your chassis!
#275 |
Well I spent a good portion of last Sunday in the garage as well as today. I was able the get the floor out. The problem that I ran into was the rusted carriage bolts that held the wood in around the perimeter. The nuts were rusted and the bolts simply spun. I ended up spot welding each one so that they would not spin. I also removed the rear sill. I was not certain how this was to come out after snapping the heads off of about 12 bolts and cutting a few spot welds I was able to easy it out. I needed to remove it to properly replace the rear driver side cab corner. Here are some pics to prove it.
