06-22-2016, 02:06 PM | #1 |
Need help with Magnacharger tune
I installed a 2006 Tahoe 5.3/4L60E in my 69 suburban. I also installed a used a 1200 Magnacharger, with 17113739 42# injectors and am running a returnless style fuel system. Since I bought the supercharger used, I was not able to get the factory programmer that comes with Magnacharger's new units in order to install their basic tune. I called Magnacharger directly, but as of yet, they haven't ben able to help. If any one has a copy Magnacharger's MP 112 basic tune, to include all the correct fuel injector data I would be greatly appreciative. Please let me know if you have any other questions on my request. Thanks in advance.
Rob
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
06-22-2016, 06:24 PM | #2 |
meowMEOWmeowMEOW
Re: Need help with Magnacharger tune
Thats an E40 pcm so a little less fun IMO. You may need to run a 2bar OS because the hardcoded airflow limit on those is low. I think we have a copy of the canned tune and I'll see what they have setup. If it runs the 1 bar OS just scaled, you get that loss of resolution and can end up with differences command vs actual, and have to change the way the ECM scanner is setup.
I'll let you know when I find it.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
06-22-2016, 07:01 PM | #3 | |
06-22-2016, 07:45 PM | #4 |
Did you search the HPT tune repository?
I found this buy searching "Magnacharger" 2006 Chevrolet Silverado Engine: 6.0 V8 - Automatic Submitted By: gofish7 2006 Vortec Max LQ9 Magnacharger vcm os id 12606807 4l60e trans segment |
06-22-2016, 08:36 PM | #5 |
I found that one Chris, but the fuel data is for a vacuum adjusted fuel pressure regulator (1:1) and not a dead head system. The IFR data table is constant value (42#) and not sloped. I talked to Magnacharger but they don't want to give up the data, .
06-23-2016, 12:07 AM | #6 |
meowMEOWmeowMEOW
2006 should be an e40, does it have the GenIII reluctor wheel?
If it is actually on a GenIII (like a p59), then we should have the base file. *but I'm totally not giving it to you because its proprietary intellectual property of the manufacturer*
06-23-2016, 08:58 AM | #7 | |
OBTW, I was looking at some of the Maggie tunes and most of the LS1/LS2's kept the 1 Bar MAP. Do you see a problem with that?
