#1326 |
Re: 48 Burb, bagged, 5.3, 20 year wait
ah man, I don't miss this stage of the engine you are at. Brake cleaner really works wonders. I use the air hose alot too. I also used a rosebud on a propane tank, would heat the block up, seemed to help. Just gotta keep going back and forth with "cleaners/degreasers" then a brake cleaner and heat and air. Then back and forth. Wire brush, flathead screwdriver and a mix of other tools like your dremel will def help. Yours looks like alot of hours already went into it or it was just a pretty decent start. Mine had clumps of grease all over it. I shoulda got a better candidate.
51' 99toLife finished 2011,355 sbc,5speed, patina, redoing whole truck, inter, bags, etc http://67-72chevytrucks.com/vboard/s...d.php?t=382481 49Hardtimes s/10 susp- bagged, vortec sbc, 5 speed, patina, sold http://67-72chevytrucks.com/vboard/s...d.php?t=594874 VIDEOS https://youtu.be/E8zHhjgS_lA https://youtu.be/E8zHhjgS_lA Geronimo 54' LS engine, static drop IFS, Client build, just about done http://67-72chevytrucks.com/vboard/s...62#post7399162 52' 3100 Slowly in progress, will be painted two toned, have 235 with a t-5, lowered OG frame Other projects, 49' farmuse 3100, killer Patina, will be slammed, LS engine, full done interior up next! www.coffeeandcustoms.com |
#1327 |
![]() Join Date: Jul 2012
Thanks Lower, Mark and 99. Amazon will have Super Clean here by Friday.
Mark, that engine looks really good! Is that the one that went in the Dodge? 99, you are right, there are several hours invested in the engine cleaning so far. Wouldn't it be nice to start with a clean new piece? Just a friendly reminder for all of us that brake clean can be hazardous when burned. This is worth a read...http://www.brewracingframes.com/safe...sgene-gas.html |
#1328 |
![]() ![]() Join Date: May 2015
Wow Doug...I never knew that about brake cleaner..that's good info..love those valve covers...where did those come from?
#1329 | |
They don't have much content on their website so check out their FB page for pictures. They build really nice components and accessory drives. |
#1330 | |
#1331 |
doug, for sure safety first. I'v read years ago, never clean any metal with brake clean and then weld it.
the wegner stuff looks nice, wish they had a better website. I can't believe the prices these companies charge for LS brackets. I need to get an AC compressor bracket. The custom serp setup on that pic is really nice. Id like to do away with the factory alt bracket but, its just not in the budget.
#1332 | ||
#1333 |
![]() Join Date: Mar 2007
Yes Doug I wish you would figure out what accessory drive we need to run...I'm just about to mount my front fenders to see what trimming I need to do for the steering linkage.
Marc
…………...........__________ .................. ((__|__||___\____ ..;.;;.:;:;.,;..;((_(O))____ (_(O)) 1948 Chevy Truck - Finished SOLD!! 1953 Chevy Suburban "Family Truckster" Completed: Spring of 2021 http://67-72chevytrucks.com/vboard/s...d.php?t=605484 1994 4x4 Blazer - "Field Find" https://67-72chevytrucks.com/vboard/...ferrerid=30857 |
#1334 |
There is chlorinated and non-chlorinated brake clean. Use the non-chlorinated stuff if your going to do any welding. It's the only kind I use and make sure it is dry. The Wegner web sight is being re done
http://67-72chevytrucks.com/vboard/s...d.php?t=648459 https://67-72chevytrucks.com/vboard/...d.php?t=769441 1951 MG TD 1967 Jeep CJ5 1.9L TDI 33X13.5X15 Mud Grapplers. 1952 GMC 9700 p/u 7.3L diesel on air, dually |
#1335 |
Hey Guy's as far as the component brackets go you can go with the Allen Grove Components brackets. This is is the same setup I used on Blakes truck.
Pic #1. This is the high mount setup (truck 5.3) new tensioner and belt inc. $240.00 Pic #2. All mounted to the motor,fairly clean setup. Pic #3. The dimensions of the kit Only 17" from center of crank pully. Pic #4. This is the low mount for the (truck 5.3) $175.00 Pic #5. The dimensions are pretty tight to the block providing you have room between the block and your frame this might be a good option. That being said I used the stock alt bracket from the 5.3 and cleaned it up real nice and painted it black to match the engine as well as the new A/C bracket and they disappear. I just bought the high mount for John's 49 Dodge as well for his A/C install. This a cheap alt. to having to spend a boat load on a serp. setup!
http://67-72chevytrucks.com/vboard/s...d.php?t=645774 Project Orangepeel 52 A.D. http://67-72chevytrucks.com/vboard/s...d.php?t=653337 John's LS 49 dodge http://67-72chevytrucks.com/vboard/s...d.php?t=655780 Blake's 67 GMC LS stepside http://67-72chevytrucks.com/vboard/s...d.php?t=690527 Reed 78 FJ40 Rebuild http://67-72chevytrucks.com/vboard/s...d.php?t=733259 Barger's 78 FJ40 |
#1336 |
Doug,to answer your question this is the motor that is going in the 38 chevy for troy. It does not have power steering so the pump was removed from the bracket and the bracket will be shaved to make it more streamlined.
Mark...
#1337 |
Blakes all installed for reference
Mark...
http://67-72chevytrucks.com/vboard/s...d.php?t=645774 Project Orangepeel 52 A.D. http://67-72chevytrucks.com/vboard/s...d.php?t=653337 John's LS 49 dodge http://67-72chevytrucks.com/vboard/s...d.php?t=655780 Blake's 67 GMC LS stepside http://67-72chevytrucks.com/vboard/s...d.php?t=690527 Reed 78 FJ40 Rebuild http://67-72chevytrucks.com/vboard/s...d.php?t=733259 Barger's 78 FJ40 Last edited by reaper71; 11-30-2016 at 11:28 AM. Reason: pic didnt load |
#1338 |
![]() Join Date: May 2007
wow I missed all this and just got caught up! you sure are going the extra mile with your engine, that will really pay off in the looks.
I wish I had the room for that seating area. work is overrated!
#1339 | |||||
Before you do your inner fenders, check out Oldman3 inners. Very nice fab. Quote:
Very nice! Where did you get the black alternator? Quote:
Here is a sneak peek of a bit of what I have in mind.... |
#1340 |
What would really help the under hood looks department would be if Kees could work his artistry on this big blank firewall. Don't know if you've seen his work...he is very talented. Anyway, it would be freaking awesome if he did.
Burb was just sitting in the shop tonight waiting on me to show up. |
#1341 |
Doug
That intake is going to look great in your suburban. it will soak up some of the excess engine bay head space that the AD's have. It looks good seeing it on the ground. In need to barrow the (front) 20's off of my 48 to check fitment up front. Keep at it. Don't loose sight of your 2nd place trophy. Marc
#1342 |
Doug...answer to ? #1 The paint I used was all rattle bomb first was shot with Epoxy primer and then it was topped off with High Heat Ceramic paint for the block. The Intake was Shop line Satin black I had here at the shop.
Answer ? #2. The alternator was a factory unit That I shot with the same paint as the Intake. Mark...
#1343 |
Looks like you have a space problem in your Sub, Doug.
The few times I see one overhere they look big. I reccon a LS motor is bigger then an old small block? I like the intake setup, is this a High Rise manifold or stock? Looks good tho!! And I love to come over and stripe your firewall, I'll even do it for free for you!! Unfortunatly I'm short on money to buy tickets... But.....we are thinking about driving a camper through America next year, so who knows what will happen ![]()
Cheers!! Kees. 1959 Chevy Fleetside Longbed My build: http://67-72chevytrucks.com/vboard/s...d.php?t=643426 Kool Guyz CC Instagram: _King_Kustom_ |
#1344 | |||
That would be so cool if you guys came through with a camper! We have a lot of space and you would be very welcome. Hope you can do it! 52MNresto sent me a PM suggesting this company might be a good one to check out for accessory drives. Thanks again 52...! http://www.cvfracing.com/Black-Chevy...pentine-ac.htm |
#1345 |
Wow..that blacked out and dark red looks good on that engine...those valve covers and holley intake you posted would look killer on that paint combo.
#1346 |
That is a good color combo.....thinking Chevy orange maybe. Coil relo package is on the shelf...
#1347 | |
Simple? What's simple?
![]() Join Date: Apr 2007
![]() (http://www.kwikperf.com/lsx_high_mount.html - K10291 , Vintage Air sells this as their own LS mount bracket), and I'm going to have to bump the inner fender out about an inch for clearance. With your engine set back you'll be better off, but I suspect you'll still be too close for comfort.
CURRENT '50 GMC 100 shortbed Gen IV 4.8 LS - 4L65E (Secret truck, Shhh!!!) Build '63 Buick Wildcat Coupe 401ci Nailhead (Very much in pieces) Photos '66 Impala SS convertible 327-QJet-glide (4 speed swap one of these days...) Photos '69 CST/10 4x4 SWB Stepper 350 2bbl - NV4500/NP241C (Broken Truck!) '72 Sierra Grande 2WD LWB fleetside 350-TH350 Refresh '99 K2500 Silverado RCLB 5.7 Vortec - NV4500/NP241C (Daily) '99 K2500 Suburban 7.4 Vortec - NV4500/NP246 (still working out the bugs) SOLD '71 Custom/10 2WD LWB fleetside - '72 GMC K/3500 Dually (Sold to redryder) |
#1348 |
AD
I got a tip from a certified welder that worked in the oil field, welding steel casing for the drilling process. He said he uses acetone that he sprays from a spray bottle. He said no harmful fumes, and dries quickly, and cheaper than any cleaner you buy for 4-6 bucks. I have used it for years and I'm still breathing, and mix any ATF with acetone (50/50) it makes a great solution for rusted fasteners. I've used both and they both work. Just my 2 cents worth. That intake is "evil" Keep on keepin on NC ![]()
Been there, wrecked that ![]() |
#1349 |
Doug,anytime you ever plan on a road trip with the wife we would love to have you!
Come hangout and goof off in the shop. Mark...
#1350 | |
Here are the dimensions from the one you linked to. Thanks again. Hope you can get back on Red Herring soon. |
