![]() Join Date: Apr 2005
PBFab driveshaft carrier bearing spacer???
Does anyone make and sell a driveshaft carrier bearing spacer for a PBFab rear setup?
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
Re: PBFab driveshaft carrier bearing spacer???
I don't see a reason why this won't work. Carrier bearing dimensions shouldn't be different.
https://www.gsimfab.com/gsi-1-inch-c...4276_8760.html If this won't work, shoot me a PM with the dimensions you need. I might be able to help. |
#3 | |
Why not just use some 2" square tubing?
AZ Pro Performance has one that is either 1.5" or 2.5" tall with shims to raise them another .75"
https://azproperformance.com/product...acer-63-87-c10
Steven "If dogs don't go to heaven, when I die I want to go wherever they went." -- Will Rogers R.I.P. Oscar R.I.P. Ratchet 1967 Pontiac GTO - Dad was the Original Owner 1970 Chevy 2wd SWB "Oscar's Truck" 1970 Chevy 2wd Blazer "Ratchet's Blazer" 2013 Chevy 2500HD Crew Cab Duramax/Allison Z71 LTZ "Brown Sugar" 2017 Chevy Suburban "BDB" 2020 Chevy Blazer Premier "Foxy" Member of Louisiana Classic Truck Club (LCTC) Shop Build |
Hart Rod, this is what I used, just a 2" solid stock bar from a machinist I know
2016 Silverado2005 GMC Sierra 2002 Chevy Slverado Extra Cab (youngest sons) 2009 GMC Denali (oldest sons) 2015 Lexus 250i (wifes) 1972 Chevy C10 LWB, 5.3 / 4L60e swap "COLOR OF MONEY" http://www.louisianaclassictruckclub.com |
I just made my own out of some aluminum stock.
1970 C-10 LWB "Blu" Instagram (current build pictures) 70_nc_c10 |
Thanks guys. I ended up buying a AZPro one from a fellow board member.
