#26 |
Re: back from Hiatus... :)
STILL waiting on control arms. If the machine shop guy does not get them done, like by Tuesday, gonna toss them and get some tubular setup.
Trans is supposed to be here this week. Can't wait. As soon as I get this motor/trans mounted up, I can get started on the myriad of little things that eats up your time and nickle and dimes you to death. More to come.
1986 C10 SWB 6.0/6l90e Miami...Flee it like a native |
#27 |
Trans not here. Control arm situation went from "it's been almost 4 weeks...it's just bushings" to QA1 front coilover setup. Guess that LSA blower is just not in the cards...
#28 |
Picked up trans today, got it unloaded, and the old one in the shipping crate to go back.
Waiting on qa1 front setup...... neighborhater mufflers came in today also....running dual 3" dump
#29 |
![]() Join Date: Apr 2005
About time....
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
#30 |
Got the spring perches cut for the qa1 setup. Going to put the front suspension back on this weekend...and probably get the motor/trans put in for the final time.
#31 |
Moving forward.
Thanks to Hart_Rod for lending me a hand, and catching up after several years.
#32 |
Motor, trans, trans xmember are in. Running fuel lines this weekend, and get that gas tank mounted(tired of looking at it).
#33 | |
#34 |
Formerly- 1972SuperCheyenne
![]() Join Date: Oct 2008
Nice work man! I love the tubular arms!
--Josh My Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=799218 A good crossthread is better than Loctite any day. Life is not about what you have, but who you have to share it with. |
#35 |
not a lot to update...Rob came over and gave me a hand with a couple of things. Big help.
Hopefully get exhaust welded up this weekend, think I tossed out a new set of header gaskets, could not find them, had to buy another set...should be here by the weekend. Get the headers/gaskets installed, get the rest of exhaust mounted up, Run power wire to fuel pump, maybe even get the tank bolted in. At least that's my plan for the weekend and next week. Then I'm off to tarpon paradise for awhile. Harness should be done by then, and get back at it full speed.
#36 |
Looking forward to updates!
#37 |
Back home...
Mounted the fpr up on firewall, started to run fuel lines. Bought a new belt. Started on the window felts and channels. Had to crack and pick the old channel out, long process, came out about 1" at a time. Only one side, was pretty muggy yesterday here in NW Florida. Be back at it tomorrow. Still have not mounted the gas tank. ![]()
#38 |
I did get the gas tank kinda mounted with 2 bolts, just for it to be in place. Almost got the fuel lines done, gotta drop the tank to finish, had to order a few things off summit tonight so I can get that part complete. Finally. Harness was supposed to be done end of May, but couple weeks behind. Still looking for oe core support that's in good shape, bought one awhile back, did not notice the previous owner had cut/zipped off the bottom area where the cushions sit in....might be able to cut my og one up and weld it, or just buy amd...and be done with it.
Will be VERY happy once I get this fuel system done, checked and tested. Then I can move on to core support, radiator(anyone run the rd ls swap unit?) and trans cooler. Not running a/c, might just yank all that junk off the firewall.
#39 |
some pics:
Click Here
#40 |
slow progress...motivation has been elsewhere past few weeks.
got a/c firewall panel, fuel lines are done, waiting on fuel hat from 87chevy, mount trans dipstick(just need little spacers or nuts), harness is on, got firewall grommet today, putting that in tomorrow. Got the ecm under the dash, and will put the small fuseblock that came with it under there somewhere too. Then on to the bulkhead wiring and get the trans lines run also. Might get some pics tomorrow.
#41 |
she's alive
