Old 05-17-2018, 09:24 AM   #76
Hart_Rod
Hart_Rod's Avatar
Re: RetroSound kickpanel speaker
Pictures of pedal pad bracket.
Hart_Rod is offline   Reply With Quote
Old 05-17-2018, 10:18 AM   #77
slowcpe
slowcpe's Avatar
Originally Posted by Johoevasmatrix View Post
Who’s spacer did you go with?I've got a pair of MTX the speaker fits in the panel but the grill will not go in so I will need to bring the speaker out 1/2 inch to make the grill work.
Sorry I just now saw this. The spacers I use are from Metra.
Ryan
1967 Red Stepside..."Laymond" http://67-72chevytrucks.com/vboard/s...40#post6441840
1972 Medium Olive SWB-Chester http://67-72chevytrucks.com/vboard/s...d.php?t=759628
1967/71 Blue SWB C10..SOLD
1977 SWB K10..my grandpa's.....never should have sold
slowcpe is offline   Reply With Quote
Old 01-14-2021, 09:34 AM   #78
Rich72C10
Mr. Cheyenne
Rich72C10's Avatar
@Hart_Rod - would you mind posting photos of your brake pedal mod with it off the arm - so I can see bracket and how it is now attached to the arm?
I am going to have my brother do something like this (or just like you did) but I'll want to pass on some photos so he is perfectly clear what I am looking for. He'll be doing this remotely by me sending him a parking brake assembly.
Richard
'72 Chevy C10 Cheyenne *Super WHT/MED BRONZE/WHT
SBC 350 | TH350 | LWB | AC | Buddy Seats
Upgrades: Tilt | Front Sway Bar | Radio | Sliding Window | Bed Spare w/Lock
Bed Rails | Full LEDs | Courtesy Lights | Tachometer | Glovebox Lock & Light | Head Light Relays | *Upgraded Fully Super Trim
Rich72C10 is offline   Reply With Quote
Old 01-14-2021, 01:06 PM   #79
Hart_Rod
Hart_Rod's Avatar
Unfortunately these are the best pictures I have.
R
Old 01-14-2021, 01:09 PM   #80
Rich72C10
Mr. Cheyenne
Rich72C10's Avatar
thank you for replying and the photos.
Richard
Old 07-05-2021, 09:29 PM   #81
woog74
Bumping and old thread I know. Great info on speaker set ups in here. Just wondering, the classic radio has 4 channels, no one ran two 6x9s in boxes under the seats? In addition to kick panels?(I can't imagine 6x9s would sound very clean just on their own.)
I measured under my seat tonight and there is about 10 inches between bottom of seat and floor, so enough room for 6x9 box, even with lowered seat brackets
woog74 is offline   Reply With Quote
Old 07-07-2021, 07:56 PM   #82
bigmac73
bigmac73's Avatar
i was going to shim up the seat rails about an inch with spacer blocks and then put a couple of these under mine with upgraded pioneer 6 inch speakers in the kick panels
Mike
72 C-10 Cheyenne off frame resto and Upgraded to 4 wheel disk, Tilt, Dakota Digital Dash / Rear slider.
421 SBC / TH350 3000RPM Stall
Progression Ignition /Holley 750 DP/3:73 gear Eaton Limited Slip unit / 2 1/2 exhaust glasspacks
bigmac73 is offline   Reply With Quote
Old 07-08-2021, 01:27 AM   #83
Richard
Something to think about. Every 6x9 I have seen and most car audio speakers 6" and smaller are designed for infinite baffle installation. Meaning no box or a leaky box. ie a door, trunk etc. Putting an IB speaker in a smaller box/enclosure will limit mid bass/bass response. Any air leakage from rear of speaker to front will also cancel mid bass/bass output. Those speakers in the small kick panels are probably dropping out at 300-600hz at best. Adjust sub crossover accordingly. If the sub reaches that high.
Richard
Old 07-08-2021, 09:43 PM   #84
woog74
You can fit 6x9s in the kick panel area?
Old 07-09-2021, 06:57 PM   #85
jimijam00
I'm thinking he meant 6" round speakers. But, if you don't mind cutting metal, losing your vents, and fabbing up part of the vent opening that, it could be done.
jimijam00 is offline   Reply With Quote
Old 07-09-2021, 08:54 PM   #86
woog74
Agreed. I read that a little too fast the first time.
