Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > Info Center > FAQ Truck Tech > 67-72
Old 04-21-2020, 01:08 AM   #1
conoco
conoco's Avatar
Front axle ujoint questions
I just finished putting a 4 inch lift and a bunch of other stuff so I was just going to replace the brakes and calipers also. However, as I started to disassemble I noticed that everything could use a good sandblasting and bearing replacement. I need help identifying the rubber seal that sits on the axle shaft and then the dust guard is installed in front of that. (PICTURES BELOW). all the bearing look great and nothing bad so I wont be replacing them. The axle ujoints are a different story though. They dont have the little C clips ontop of the ujoints and I am hoping someone can tell me how to get them out so I can replace them. Also is there a heavier duty ujoint to replace it with or a recommended one that you all have had good results with. I am going to sand blast the axle shafts and dust guard and all the other rusted stuff. On a side not the truck ran smooth, no wobbles, u joints were solid no problems at all. But they are in desperate need of some maintenance. Any help so I can get the right parts would be great. Stay safe everyone.
conoco is offline   Reply With Quote
Old 04-21-2020, 01:11 AM   #2
conoco
conoco's Avatar
Re: Front axle ujoint questions
Close up of the rubber seal
Old 04-21-2020, 01:16 AM   #3
Jcfcamaro
Jcfcamaro's Avatar
U joints have snap/C clips on the inside. Just did mine and it was a pain. Those u joints press hard. I did find a YouTube video where they actually use a hammer and beat on the opposite yoke to drive the other one off. Tork king is a good place to look at parts.
Jcfcamaro is offline   Reply With Quote
Old 04-21-2020, 01:19 AM   #4
Jcfcamaro
Jcfcamaro's Avatar
I don't remember which seal kit it was but it came with the rubber dust seal. I bought mine from rock auto.
Old 04-21-2020, 01:31 AM   #5
4x41971SWB
Yukon gear and axle #YSPSP-025
Summit racing has them in stock
4x41971SWB is online now   Reply With Quote
Old 04-21-2020, 01:38 AM   #6
conoco
conoco's Avatar
Thanks everyone I will get started in the morning. Appreciate the help.
Old 04-21-2020, 08:18 AM   #7
MJN
MJN's Avatar
As it was stated the u-joints have clips on the inside of the yoke ears. If you have access to a ball joint press- they make changing these quick and easy. I only use Spicer U-joints, non greasable. There are two different size u-joints for Dana 44 axle shafts, the early open knuckle (pre-73) used Spicer 5-260X which have smaller u-joint caps. The later axles used Spicer 5-760X which are larger. They are both 1310 series joints. As far as the slinger- you can get them here https://torqueking.com/product/40460...shaft-slinger/
I've also had great service from www.northerndrivetrain.com- they will drop ship from Spicer as well.
Might as well replace the spindle bearings while you're in there too, along with all the seals. Pickup spindle bearing kits, part number SBK-1. This kit will have the spindle bearing and both rubber seals.
'51 South Bend Model "9A"
'56 Chevy 3600 NAPCO
'08 GMC Envoy Denali
'12 GMC Sierra 2500HD Denali
'17 GMC Yukon XL
VCCA member #58596
http://www.nohrco.com
Old 04-23-2020, 09:19 AM   #8
MJN
MJN's Avatar
Spicer makes a more extreme duty axle joint as well but not sure if they're available in the 260x.
https://spicerparts.com/parts/drives...treme-u-joints
'17 GMC Yukon XL
VCCA member #58596
Old 04-23-2020, 11:18 AM   #9
BLAZERMAN
Currently Blazerless
BLAZERMAN's Avatar
Lots of good info and part numbers here. Should be moved to the 4x4 FAQ Index
1972 C/30 133" W.B. C&C
1970 GMC 3500 157" W.B. single wheel C&C
BLAZERMAN is offline   Reply With Quote
Old 07-13-2021, 09:52 AM   #10
Hart_Rod
Hart_Rod's Avatar
Great thread! Working on rebuilding mine.
Hart_Rod is offline   Reply With Quote
