#376 |
![]() Join Date: Jan 2015
Re: slammed 57
Well,the dash is going to need another round or two of 2k primer as you can see some of the low spots, I been making these small sanding blocks to match the contour and hard to reach places when they come upon, I also put together some door stands so I can hammer + dolly, bodywork and prime and paint etc..... makes things a little easier
#377 | |
Re: slammed 57
![]() 1940 Ford Dlx Coupe 1969 Mach1 |
#378 |
Who Me?
Re: slammed 57
Excellent build! I will be following along.
![]() 1997 Tahoe LT 4D 2WD (DD) 2001 Blazer 4D 2WD 1961 Apache 10 (sold) 1965 C10 Stepper (sold) |
#379 |
Re: slammed 57
i have had succes with an office eraser as a small sanding block
#380 |
Re: slammed 57
Getting closer for some color, a few coats of poly and then work through the grits
#381 |
Re: slammed 57
Looking good! I finally put a coat of primer on my 57 this week. Now I’ll be sanding for a while until I get it straight!
John Z 1962 Chevy C10 Stepside 62 Barnfind My build tread: http://67-72chevytrucks.com/vboard/s...d.php?t=507513 |
#382 |
Re: slammed 57
Great progress…it’s coming along. I’m hoping to start laying mud soon myself. Not my favorite step in the project
http://67-72chevytrucks.com/vboard/s...d.php?t=780018 Jason’s 56 build |
#383 |
Re: slammed 57
Looking good. Did you decide on final paint?
My museum of good intentions: 1957 3100 BBW restomod -- 1970 442 W30 |
#384 |
Re: slammed 57
Hey Bud , yes I went with spi black bc/cc already sittin on the self
#385 |
Re: slammed 57
4 coats of poly ….. and MORE sanding!!!!!
#386 |
Re: slammed 57
It's looking good. All the sanding makes the finished product in the end. What are you using for poly? Steve
My 57 Fleetside C4 build. http://67-72chevytrucks.com/vboard/s...d.php?t=817054 |
#387 |
Re: slammed 57
Hey steve, Iam using rust defender (same as "All U Need" or "Sandy")
#388 |
Re: slammed 57
Thank You. Steve
#389 |
Re: slammed 57
body work done from the cab forward... ready to paint here in a week or two. heres a little video of it
https://youtu.be/Ngo2-Qw21aE Last edited by slammed57; 04-04-2022 at 04:31 PM. Reason: double |
#390 |
Re: slammed 57
nice and straight, great work.
when i do bodywork I use wax and grease remover, applied liberally, to check the straightness of the bodywork as i go. what color do you plan to spray? gloss, semi gloss, flat sheen? |
#391 |
Re: slammed 57
Wow that looks good. Envious of you being done with the bodywork. I’ve been sanding for weeks. Driving by July?
#392 |
![]() Join Date: Mar 2011
Re: slammed 57
Very nice, will look great painted...Jim
my build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=459839 Jimbo's long bed step build:http://67-72chevytrucks.com/vboard/s...t=464626<br /> |
#393 |
Re: slammed 57
will you lay down some sealer before paint in case of incompatabilities between manufacturers?
#394 |
Re: slammed 57
I sure wish by july. but I still have to prep the bed and rear fenders and then buff the entire truck...... by the end of summer I hope is more probably more realistic
#395 |
Re: slammed 57
Yes sir.. the base will lay down better and the seal helps for better adhesion with chips from road debris... from what Iam told
#396 |
Re: slammed 57
thanks for the video and pics thru your journey with the truck. you do great work Mike.
#397 |
Re: slammed 57
sorry i just saw this post. yes the wax and grease really helps. I will be doin gloss black
#398 |
![]() Join Date: Mar 2007
Re: slammed 57
Looks great...
Marc
…………...........__________ .................. ((__|__||___\____ ..;.;;.:;:;.,;..;((_(O))____ (_(O)) 1948 Chevy Truck - Finished SOLD!! 1953 Chevy Suburban "Family Truckster" Completed: Spring of 2021 http://67-72chevytrucks.com/vboard/s...d.php?t=605484 1994 4x4 Blazer - "Field Find" https://67-72chevytrucks.com/vboard/...ferrerid=30857 |
#399 |
Re: slammed 57
Body work is the most time consuming part I think! Looking great by the way.
http://67-72chevytrucks.com/vboard/s...d.php?t=648459 https://67-72chevytrucks.com/vboard/...d.php?t=769441 1951 MG TD 1967 Jeep CJ5 1.9L TDI 33X13.5X15 Mud Grapplers. 1952 GMC 9700 p/u 7.3L diesel on air, dually |
#400 |
Re: slammed 57
Well I sprayed some smaller parts to get my gun adjustments dialed in( I really like this SPI base and clear) I put on 6 coats of clear to give me a little wiggle room for when I cut and buff. Hopefully if all goes well I’ll get the front fenders sprayed this week.
