Old 05-03-2021, 05:38 PM   #376
slammed57
slammed57's Avatar
Re: slammed 57
Well,the dash is going to need another round or two of 2k primer as you can see some of the low spots, I been making these small sanding blocks to match the contour and hard to reach places when they come upon, I also put together some door stands so I can hammer + dolly, bodywork and prime and paint etc..... makes things a little easier
My 57 current build
http://67-72chevytrucks.com/vboard/s...d.php?t=662590
slammed57 is offline   Reply With Quote
Old 05-07-2021, 09:01 AM   #377
my56chevytruck
my56chevytruck's Avatar
Re: slammed 57
WOW, good work Mike, when I get to when I need my truck redone, I'll need your home address, lol
RUBBER DOWN AND HIT THE ROAD!!!
1940 Ford Dlx Coupe
1969 Mach1
my56chevytruck is offline   Reply With Quote
Old 05-07-2021, 01:22 PM   #378
61_FL_Apache
Who Me?
61_FL_Apache's Avatar
Re: slammed 57
Excellent build! I will be following along.
Steve
1997 Tahoe LT 4D 2WD (DD)
1961 Apache 10 (sold)
1965 C10 Stepper (sold)
61_FL_Apache is offline   Reply With Quote
Old 01-02-2022, 08:54 PM   #379
dsraven
Re: slammed 57
i have had succes with an office eraser as a small sanding block
Old 01-02-2022, 08:55 PM   #380
slammed57
slammed57's Avatar
Re: slammed 57
Getting closer for some color, a few coats of poly and then work through the grits
My 57 current build
Old 01-03-2022, 06:44 PM   #381
62 Barnfind
62 Barnfind's Avatar
Re: slammed 57
Looking good! I finally put a coat of primer on my 57 this week. Now I’ll be sanding for a while until I get it straight!
John Z
1962 Chevy C10 Stepside
62 Barnfind
My build tread: http://67-72chevytrucks.com/vboard/s...d.php?t=507513
62 Barnfind is offline   Reply With Quote
Old 01-03-2022, 10:48 PM   #382
Jason 56
Re: slammed 57
Great progress…it’s coming along. I’m hoping to start laying mud soon myself. Not my favorite step in the project
http://67-72chevytrucks.com/vboard/s...d.php?t=780018 Jason’s 56 build
Jason 56 is offline   Reply With Quote
Old 01-09-2022, 12:16 PM   #383
BIGglaSS
BIGglaSS's Avatar
Re: slammed 57
Looking good. Did you decide on final paint?
My museum of good intentions: 1957 3100 BBW restomod -- 1970 442 W30
BIGglaSS is offline   Reply With Quote
Old 01-09-2022, 07:13 PM   #384
slammed57
slammed57's Avatar
Re: slammed 57
Hey Bud , yes I went with spi black bc/cc already sittin on the self
My 57 current build
Old 01-22-2022, 09:13 AM   #385
slammed57
slammed57's Avatar
Re: slammed 57
4 coats of poly ….. and MORE sanding!!!!!
My 57 current build
Old 01-22-2022, 10:55 AM   #386
57FleetsideC4
Re: slammed 57
It's looking good. All the sanding makes the finished product in the end. What are you using for poly? Steve
My 57 Fleetside C4 build. http://67-72chevytrucks.com/vboard/s...d.php?t=817054
57FleetsideC4 is offline   Reply With Quote
Old 01-22-2022, 10:58 AM   #387
slammed57
slammed57's Avatar
Re: slammed 57
Hey steve, Iam using rust defender (same as "All U Need" or "Sandy")
My 57 current build
Old 01-22-2022, 09:37 PM   #388
57FleetsideC4
Re: slammed 57
Thank You. Steve
Old 04-01-2022, 10:35 AM   #389
slammed57
slammed57's Avatar
Re: slammed 57
body work done from the cab forward... ready to paint here in a week or two. heres a little video of it
https://youtu.be/Ngo2-Qw21aE
My 57 current build
Old 04-01-2022, 08:26 PM   #390
dsraven
Re: slammed 57
nice and straight, great work.
when i do bodywork I use wax and grease remover, applied liberally, to check the straightness of the bodywork as i go.
what color do you plan to spray? gloss, semi gloss, flat sheen?
Old 04-02-2022, 12:07 AM   #391
Jason 56
Re: slammed 57
Wow that looks good. Envious of you being done with the bodywork. I’ve been sanding for weeks. Driving by July?
Old 04-02-2022, 10:03 AM   #392
oldman3
oldman3's Avatar
Re: slammed 57
Very nice, will look great painted...Jim
oldman3 is offline   Reply With Quote
Old 04-02-2022, 10:07 AM   #393
dsraven
Re: slammed 57
will you lay down some sealer before paint in case of incompatabilities between manufacturers?
Old 04-04-2022, 03:35 PM   #394
slammed57
slammed57's Avatar
Re: slammed 57
I sure wish by july. but I still have to prep the bed and rear fenders and then buff the entire truck...... by the end of summer I hope is more probably more realistic
My 57 current build
Old 04-04-2022, 03:38 PM   #395
slammed57
slammed57's Avatar
Re: slammed 57
Yes sir.. the base will lay down better and the seal helps for better adhesion with chips from road debris... from what Iam told
My 57 current build
Old 04-05-2022, 09:40 AM   #396
my56chevytruck
Re: slammed 57
thanks for the video and pics thru your journey with the truck. you do great work Mike.
1940 Ford Dlx Coupe
1969 Mach1
Old 04-11-2022, 08:26 PM   #397
slammed57
slammed57's Avatar
Re: slammed 57
sorry i just saw this post. yes the wax and grease really helps. I will be doin gloss black
My 57 current build
Old 04-12-2022, 10:57 AM   #398
youngrodder
youngrodder's Avatar
Re: slammed 57
Looks great...
Marc
…………...........__________
.................. ((__|__||___\____
..;.;;.:;:;.,;..;((_(O))____ (_(O))
1948 Chevy Truck - Finished SOLD!!
1953 Chevy Suburban "Family Truckster" Completed: Spring of 2021
http://67-72chevytrucks.com/vboard/s...d.php?t=605484
1994 4x4 Blazer - "Field Find"
https://67-72chevytrucks.com/vboard/...ferrerid=30857
youngrodder is offline   Reply With Quote
Old 04-28-2022, 10:03 AM   #399
lower50's
lower50's's Avatar
Re: slammed 57
Body work is the most time consuming part I think! Looking great by the way.
http://67-72chevytrucks.com/vboard/s...d.php?t=648459
https://67-72chevytrucks.com/vboard/...d.php?t=769441
1951 MG TD
1967 Jeep CJ5 1.9L TDI 33X13.5X15 Mud Grapplers.
1952 GMC 9700 p/u 7.3L diesel on air, dually
lower50's is offline   Reply With Quote
Old 05-01-2022, 03:47 PM   #400
slammed57
slammed57's Avatar
Re: slammed 57
Well I sprayed some smaller parts to get my gun adjustments dialed in( I really like this SPI base and clear) I put on 6 coats of clear to give me a little wiggle room for when I cut and buff. Hopefully if all goes well I’ll get the front fenders sprayed this week.
My 57 current build
