Old 05-07-2023, 09:24 AM   #1
samert111
samert111's Avatar
Front shock selection for 2" lowering springs
I just installed front 2" lowering springs on my 68 C10 and trying to find a shock that will work without relocating the upper mount.
With the truck sitting on the ground the shock mounting length is right at 11" and the stock shocks are 10" compressed which only gives me 1" of travel before bottoming out.
I have searched everywhere for drop shocks for just a 2" lowering spring and most offered are similar in length to the stock shocks lengths. I've found a Monroe shock that is 8 3/8" compressed and 12 3/4 extended with the correct mounts but with these I'm worried that the extended length is too short for when the truck is on the lift since the unloaded mount length is 13 1/2" and the shock would be supporting the weight of the front suspension vs. the upper bump stop.
So what shock is everyone using for shock for a 2-3" front drop spring?
samert111 is offline   Reply With Quote
Old 05-07-2023, 02:31 PM   #2
Richard
Re: Front shock selection for 2" lowering springs
A stock length shock will work fine with the drop springs unless you changed the bump stop height. Truck bottoms out at the same location as stock with the lowering springs. Note that the shock is mounted at an angle and not at end of arm. Suspension movement to shock is not 1 to 1 or as much as wheel travels up and down.
Richard
Old 05-07-2023, 08:46 PM   #3
PGSigns
PGSigns's Avatar
Belltech street performance shocks work great on these trucks. Are available in drop lengths.
Jimmt
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 05-16-2023, 02:00 PM   #4
theastronaut
theastronaut's Avatar
I used these and trimmed the extra tabs off. Bolted it to the frame rail of my '66, it gave 2-3" more travel using a stock length shock. Rode great with the bump stop brackets removed, KYB Gas-A-Just shocks, and stock spring with 1.5 coils cut off.
https://www.summitracing.com/parts/cur-ce-7020
theastronaut is offline   Reply With Quote
Old 05-17-2023, 12:27 PM   #5
SCOTI
SCOTI's Avatar
Yep.... Another vote for stock shock lengths & if anything upper shock relocation brackets.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
