#226 |
67-72 parts collector,…
![]() Join Date: Nov 2002
Re: Got some new wheels: Boss 338's in 20x10 and 20x8.5
These are my measurements from the two rotors:
1" ROTORS: -Hub Diameter: 2.650" -Hub height: 1.750" -Total height from wheel flange to end of dust cover: 2-11/16" -Height from disc face to lugnut flange: 1-7/8" 1.25" ROTORS: -Hub Diameter: 2.895" -Hub height: 2" -Total height from wheel flange to end of dust cover: N/A (No cap on my rotor) -Height from disc face to lugnut flange: 1-9/16" Looks like the thinner rotor has a taller "hat",... and a shorter hub. And here's the wheel mounted!
Keith Convert to disc brakes. http://67-72chevytrucks.com/vboard/s...d.php?t=444823 Last edited by lolife99; 09-20-2009 at 03:53 PM. |
#227 |
Here's the final dimensions.
(excuse my crappy skills in "paint")
#228 |
Nice!! Now I got to figure how to get them to work on my 97' truck!!
#229 |
It'd be alot cooler if you did
Nice work Keith.
#230 |
This won't solve everyones issues,... but at least they will fit something.
And,... I don't have to return mine or wait for the new design.
Keith Convert to disc brakes. http://67-72chevytrucks.com/vboard/s...d.php?t=444823 Last edited by lolife99; 09-22-2009 at 05:49 AM. |
#231 |
I hope I don't have these issues on a mustang II rotor. I bought these in a 18x8 and a 18x9.5 for my brothers 59 truck. We have the rears on and haven't done the fronts yet.
Kevin Special Thanks to All who have helped on the TRUCK! My Pass Time Show http://s129.photobucket.com/albums/p...Chapter1-0.mp4 So Far my best Times are: Motor only: 6.44 1/8 @ 104.13 10.39 1/4 @ 125.83 Nitrous Times: 5.785 1/8 @ 118.65 with a 1.336 60ft 9.168 1/4 @ 142.58 with a 250 shot dead out of the hole! |
#232 |
I did some digging and ithink the 88-98 trucks are like the 73-87 trucks they used 2 different rotors depending on the option or the gvwr. i may head to the parts store and pull a few rotors and measure..
#233 |
Tot Roddin'
Awesome FAQ Keith!
-Nate ![]() 1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6) 1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior) 2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package) |
#234 |
![]() Join Date: Apr 2005
Keith - quick questions, I'm getting ready to buy new spindles and am thinking about going with the LD ones. What else has to be changed besides the rotors and spindles to make the LD stuff work? Thanks,
R/
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
#235 |
Great feed back man...i got the 20x8 & 20x10 set up for my 72 c10, so i only need to get the 1" thick rotors? or will i need the drop spindles for 1" brake rotors as well? will caliper from my stock 1.25 rotors work on the 1" rotors? any feedback will help. Thanks.
#236 |
Rob and Benji,... the only thing I'm not sure about is the calipers.
I need to stop by the local auto parts store and check that out tomorrow,... but I'm sure they are a different part number. If I had DSL,... I'd look online,... but it's not worth the effort. (And the slow internet, driving me crazy) My frame is a 1983,... so that's the application I will use. (Hint, hint dsl guys) Last night I ordered a set of 73-87 Belltech 3" drop spindles (part #3200 for the LD version), for my '86 Dropmember project. Anyone else running 63-70 conversion spindles will have to swap to the 73-87 version and change balljoints. I think the upper and lower balljoints of the 71-72 trucks will work with the 73-87 spindles,... but I'm not 100% sure. (another cross reference item for you dsl guys) I'm pretty sure there is no 1" spindle for the pre '73 trucks,... so a balljoint/tie rod switch will be in order. (with maybe the exception being the 71-72 trucks)
Keith Convert to disc brakes. http://67-72chevytrucks.com/vboard/s...d.php?t=444823 Last edited by lolife99; 09-21-2009 at 06:10 PM. |
#237 |
GUYS! please remember that going to a 20" wheel combo is going to be double, if not triple the weight per wheel. Braking distance IS INCREASED. Before ordering all the brake hardware, think about increasing the rotor diameter, which would also include a different caliper/spindle setup. I am all for the GO GO GO, but we also need to STOP STOP STOP.
I didn't think there was going to be that much of a difference from the 15" 165/50/15 combo I had until I went out to do this measuring. Holy cow was that wheel heavy. I am a school teacher who used to work at a few tire shops in my younger years. I equal the weight to about a split rim set up for a box truck. Maybe not quite that bad, but heavy enough. I AM looking into getting a bigger brake combo for my rig. Just keep the longer stopping distance in mind. |
#238 |
Good luck finding a rotor,... ANY rotor,... that will fit this wheel.
So far the Light Duty version of the stock rotor is the ONLY one that will work. And that's what you have right now. Let me know if you find another rotor/brake system that this wheel will fit.
#239 | |
Amateur Rust Fighter
I agree that brakes need to be a MUCH higher priority than just about anything else on a vehicle. But I don't see adding a few pounds per corner as something that necessitates a $2000 brake upgrade. IMHO, of course. Brent
Brent '72 Chevy SWB stepside - [ Build Thread ] '79 ChevMC SWB fleetside - [ Build Thread ] '64 Chevy SWB fleetside & '66 Chevy SWB stepside (waiting in the wings...) |
#240 | |
I laugh when people make this argument. Like when they pull that 2 ton trailer, or load the bed that the truck was okd to haul. or when you put the 5 passengers in the vehicle. better upgrade your brakes ASAP ![]() ![]() |
#241 |
I'm good with a brake upgrade,... but until they redesign this wheel,... they won't fit anything except the factory LD rotors.
I guess I was just happy to get them to bolt on with no modifications,... finally. You guys keep me posted if you find another rotor that will work,... or a new part number for the redesigned wheel.
Keith Convert to disc brakes. http://67-72chevytrucks.com/vboard/s...d.php?t=444823 Last edited by lolife99; 09-22-2009 at 12:08 PM. |
#242 |
I am not panicing, nor am I suggesting there be a panic. I am only stating, since I have put the 20's on my truck, my stopping distance has increased. I wouldn't consider myself a maniac on the road, but then again, this is subjective.
#243 | |
#244 |
![]() Join Date: Feb 2008
well I was just looking at the ECE page and the brake conversion they sell (and I bought) have a 1.25" rotor.
So is it possible to just go back to the 1" or is there something to do with the newer spindles that you have to have the 1.25" (or heavy duty)? |
#245 |
You can machine the HD 1.25" rotors & use spacers to work w/these wheels if you can accommodate the slight increase of track width.
#246 |
Id rather not use spacers? Sorry if I missed it but is there any word on the release of the new wheels?
#247 | |
Your ECE "conversion spindle" eliminates all that. It may be better to wait for the "new" design on the wheel itself.
Keith Convert to disc brakes. http://67-72chevytrucks.com/vboard/s...d.php?t=444823 Last edited by lolife99; 09-23-2009 at 11:58 AM. |
#248 |
I haven't heard anything yet.
#250 |
I talked to Jeff from ECE today and he had another option but I dont think it's worth it..
He said I can take my spindles off they can press out my PIN (Axle) and he can press in the smaller one that accomidates the standard rotor... to much work if you ask me.. So Ill just wait for the wheels to come out.. hey NLPD, How was it you can tell the new design? I thought you said soemthing about part # or something. THANKS!! |
