Old 03-10-2011, 12:17 PM   #226
robnolimit
robnolimit's Avatar
Re: No Limit '72 C-10
hahaha, ok you caught me, it all a hoax. lol, I'm on the hwy, but I'll see if I can get someone at the shop to post.
GoodGuys 2012 Pro-Truck Champion
2012 Truckin' Throwdown Champion
GoodGuys 2011 National Champion
2011 Truckin' Throwdown Champion
GoodGuys 2010 National Champion
Proud to put our products up against all others!
robnolimit is offline   Reply With Quote
Old 03-10-2011, 12:37 PM   #227
67cheby
67cheby
67cheby's Avatar
OK.......well maybe we will believe if we can see.....
67cheby is offline   Reply With Quote
Old 03-10-2011, 11:06 PM   #228
mjensen
mjensen's Avatar
Originally Posted by 67cheby View Post
how can we believe any of this ........WITHOUT PICTURES !!!!
x2!!!
Mike
'69 GMC 3/4 ton 4x4 Build Thread
mjensen is offline   Reply With Quote
Old 03-12-2011, 11:23 PM   #229
smbrouss70
smbrouss70's Avatar
Originally Posted by robnolimit View Post
I'll put up a layout of the rear Z.
I'd be interested to see this!
Steven
"If dogs don't go to heaven, when I die I want to go wherever they went." -- Will Rogers
R.I.P. Oscar
R.I.P. Ratchet
1967 Pontiac GTO - Dad was the Original Owner
1970 Chevy 2wd SWB "Oscar's Truck"
1970 Chevy 2wd Blazer "Ratchet's Blazer"
2013 Chevy 2500HD Crew Cab Duramax/Allison Z71 LTZ "Brown Sugar"
2017 Chevy Suburban "BDB"
2020 Chevy Blazer Premier "Foxy"
Shop Build
smbrouss70 is offline   Reply With Quote
Old 03-26-2011, 05:51 PM   #230
robnolimit
robnolimit's Avatar
Here's a project update. We're using the JT as a test bed for the new rack & pinion kits, as well as other parts for C-10s. Sway bars, shock mounts, springs, and panhard rod kits. We're trying to take a 'clean slate' approach, instead of following the stock concept. This way we get parts that work right, and fit right.
Micheal's little brother Seth helped out with the bodywork. And there's some shots of the rear suspension, and the rack. The rear swaybar is a test prototype, and so far looks to be very good. The bumpstops in the rear are from GM chassis motorhomes, and are really soft, andding in to get a progressive spring rate for the last 2". The 5.3 is tucked in tight, and we added a Spectra air intake. The cooling system is all done, as is most of the wiring. More to come.
Old 03-26-2011, 06:02 PM   #231
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
That rack and pinion looks great...
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
Old 03-26-2011, 06:06 PM   #232
67cheby
67cheby
67cheby's Avatar
thats some pretty cool stuff right there !!!
Old 03-26-2011, 06:47 PM   #233
Hart_Rod
Hart_Rod's Avatar
Some more pictures of the setup would be pretty cool......
Hart_Rod is offline   Reply With Quote
Old 03-26-2011, 07:12 PM   #234
FRENCHBLUE72
PROJECT 7DEUCE
I agree what is involved with that set up??
MEMBER #6377
Project "7DEUCE"
Old 03-26-2011, 08:46 PM   #235
Zoomin
Man of Mini-Talents
Zoomin's Avatar
Man, a R&P system would be a HUGE improvement over the tiller set up I have now. Can't wait to hear the details...
Zoomin is offline   Reply With Quote
Old 03-28-2011, 04:55 PM   #236
mr48chev
mr48chev's Avatar
Looks great and I like the R&P swap but I have a few concerns and questions on the modifications to the A arms moving the ball joint out without giving a bit more explanation as to why you are doing this. I see the concept for this particular truck as the main focus is corner carving and running autocross where the alignment setup is quite a bit different from what would be desirable on the street to increase the longevity of a set of tires that sometimes now cost in the hundreds of dollars each.
Basically a front end that is set up correctly for Autocross will put severe wear on the inside tread of a set of tires in a few thousand if not hundred miles. Great for going faster around corners but not great when a set of tires might cost a guy as much or more than a month's net pay in a lot of cases and having increased negative camber could wear out a pair of tires before the second payment is due.
Old 03-28-2011, 05:14 PM   #237
SCOTI
SCOTI's Avatar
I beleive the BJ relocation was for increased caster.
And factory camber settings were around +.5 w/o wearing tires down so going -.5 would be the same amount of wear but benefit handling ability alot by keeping the nose of the truck in check & limiting the amount of 'push' in a constant corner.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 03-28-2011, 08:20 PM   #238
mr48chev
mr48chev's Avatar
I realize that Scott but quite often what works great for racing or some sort of competition doesn't always give optimum results for a strictly street driven vehicle. The increased caster will let the wheel snap back to center quickly and should allow the truck to track well. Usually a vehicle that is set up for serious autocross work will have around 1-1/2 to 2 degrees negative camber so that the outside tire has full tread contact on hard turns. That as you mentioned above would be out of alignment on a street only rig.
I just don't want to see guy who don't quite understand that this particular truck is being set up primarily to run hard and quick in it's chosen track venue with being street driven a secondary consideration. That fact that it may take higher steering effort or wear tires a bit more really isn't an issue as long as it keeps dropping the times at the track. What is a great modification for this truck might not be the best modification for a truck that is only driven on the street and primarily driven to cruise nights or shows.
Old 03-29-2011, 10:34 AM   #239
robnolimit
robnolimit's Avatar
Good morning. While it is true that we want the JT to handle, it IS being built to be a daily driver. The A-arm mod in question is designed to increase caster, and yes, we did move the bottom ball joint out 1/4", this is only to make sure that we can set the alignmentcorrectly. Many stock trucks are limited, in alignment, when they run out of - camber range. Larger diameter wheels, and tires with shorter sidewalls react differently than the 78 series 15" wheels of yesteryear. Cars like BMW, Corvette, Mustang, Charger have high caster settings from the factory. Even the new Camaro comes with 8 1/2 deg caster. Our base alignment will be .75 deg - camber, +7 deg caster, toe in 1/16" No tire killer there.
Old 03-29-2011, 11:56 AM   #240
SCOTI
SCOTI's Avatar
From what I've read, this is not an 'all out' vehicle like the Ford truck is. It's being built for the street & still have the ability to handle track days too.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 03-29-2011, 04:48 PM   #241
nuke1
nuke1's Avatar
Rob, i really respect your builds and dedication to the sport and our site. Great build!!!! Thanks for being apart of the site and help out those of us that love to learn!!
James
1968 GMC "HAVOC"
1986 GMC "Frank"
J.J.R.H. Design & Consulting
My 68`Rebuild "HAVOC": http://67-72chevytrucks.com/vboard/s...d.php?t=316300
A 58' chev build thread: http://www.67-72chevytrucks.com/vboa...d.php?t=311238
1969 Camaro Pro Touring http://67-72chevytrucks.com/vboard/s...61#post3513361
Swiss Cheese: http://67-72chevytrucks.com/vboard/s...d.php?t=384390
Adjustable Trailing Arm How-To: http://67-72chevytrucks.com/vboard/s...d.php?t=321100
1968 Ford Farm Truck: http://67-72chevytrucks.com/vboard/s...=1#post6555587
nuke1 is offline   Reply With Quote
Old 03-30-2011, 02:50 PM   #242
robnolimit
robnolimit's Avatar
More picts coming. Last night we drove the JT down to Adams Motorsports Park, and ran some time-attack laps. It was kind of gutsy to pull it off the lift, and drive straight to the track - but, hey, everything worked out great. The truck drives great, stays flat and hooked up in the corners, and it totally predictable.- not like it was. The steering is perfect, and the swaybars feel great. To say we are happy with the results is an understatement. The auto trans could be better, but it's a stocker with 60k miles. We are thinking about a late model style tuner like an Edge, or a Bullydog tuner that has trans control. If you are shocked about the JT being almost finished, don't worry. We have over 100 picts to post, and lots of text and part #'s to go along with it. My guys did the tear-down and rebuild in about 3 weeks, and I can't give then enough credit. They worked thier asses off. They set a goal to drive it to Del-Mar for the GoodGuys show this weekend, and they made it with time to spare.
Old 03-30-2011, 03:01 PM   #243
robnolimit
robnolimit's Avatar
Here's a teaser.
Old 03-30-2011, 03:05 PM   #244
tubbedII
needs more $$$
tubbedII's Avatar
Nice! So, the fastest time I've seen posted is 54.45, what were the times from last night?
1970 2wd Blazer
tubbedII is offline   Reply With Quote
Old 03-30-2011, 03:16 PM   #245
67cheby
67cheby
67cheby's Avatar
LOVE the color
Old 03-30-2011, 03:16 PM   #246
robnolimit
robnolimit's Avatar
53.35, but we were'nt pushing it very hard. 51's will be easy. Bret Voekel (RideTech) ran his 69 mustang last night, and I was focussed on helping him dial in the suspension, he ran a blazing 47.3 sec lap, and says the car handles better than ever.
Old 03-30-2011, 03:41 PM   #247
SCOTI
SCOTI's Avatar
He swapped to coil-overs right? That thing had some mean twist coming out of corners w/the ShockWaves.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 03-30-2011, 04:11 PM   #248
tubbedII
needs more $$$
tubbedII's Avatar
Here's a teaser.
Wow! I didn't expect it to have actual paint on it too!
1970 2wd Blazer
Old 03-30-2011, 08:06 PM   #249
gringoloco
A guy with a truck
gringoloco's Avatar
Looks awesome so far- let's see more
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is offline   Reply With Quote
Old 03-30-2011, 08:18 PM   #250
robnolimit
robnolimit's Avatar
No, thats on shockwaves. We spent about 4 hrs tuning and aligning the suspension yesterday, and it sure paid off.
1972 chevy, c-10, no limit engineering
