Old 02-17-2015, 12:50 PM   #251
99 to Life
99 to Life's Avatar
Re: 53 Surburban "Family Truckster"
nice work, digging the trans tunnel. I'm more of a square tunnel fan in most builds. allows more utilization and most time I just like how they look.
51' 99toLife finished 2011,355 sbc,5speed, patina, redoing whole truck, inter, bags, etc
http://67-72chevytrucks.com/vboard/s...d.php?t=382481
49Hardtimes s/10 susp- bagged, vortec sbc, 5 speed, patina, sold
http://67-72chevytrucks.com/vboard/s...d.php?t=594874
VIDEOS https://youtu.be/E8zHhjgS_lA
Geronimo 54' LS engine, static drop IFS, Client build, just about done
http://67-72chevytrucks.com/vboard/s...62#post7399162
52' 3100 Slowly in progress, will be painted two toned, have 235 with a t-5, lowered OG frame
Other projects, 49' farmuse 3100, killer Patina, will be slammed, LS engine, full done interior up next!
www.coffeeandcustoms.com
99 to Life is offline   Reply With Quote
Old 02-17-2015, 10:42 PM   #252
youngrodder
youngrodder's Avatar
Originally Posted by alaska gasser View Post
Looking good. I dug all the lead out of my '52 panel due to rust under it. I sandblasted and filled it back in with fiberglass kitty hair and it held up great.
Eugene
I will probably sandblast the welds then treat them with some black rust guard prior to using kitty hair.
Marc
…………...........__________
.................. ((__|__||___\____
..;.;;.:;:;.,;..;((_(O))____ (_(O))
1948 Chevy Truck - Finished SOLD!!
1953 Chevy Suburban "Family Truckster" Completed: Spring of 2021
http://67-72chevytrucks.com/vboard/s...d.php?t=605484
1994 4x4 Blazer - "Field Find"
https://67-72chevytrucks.com/vboard/...ferrerid=30857
youngrodder is offline   Reply With Quote
Old 02-17-2015, 10:46 PM   #253
youngrodder
Thanks, I'm getting anxious to get the seat riser welded back in and getting the trans tunnel welded in so that I can get the front floor are all buttoned up.
Marc
Old 05-27-2015, 09:32 PM   #254
lower50's
lower50's's Avatar
Love your green truck. The Burb is lookin good and will be awesome.
http://67-72chevytrucks.com/vboard/s...d.php?t=648459
https://67-72chevytrucks.com/vboard/...d.php?t=769441
1951 MG TD
1967 Jeep CJ5 1.9L TDI 33X13.5X15 Mud Grapplers.
1952 GMC 9700 p/u 7.3L diesel on air, dually
lower50's is offline   Reply With Quote
Old 05-27-2015, 10:18 PM   #255
Sim6
Sim6's Avatar
Marc, great work.
1969 Chevy C10 SWB 350/400 4"-6" drop on steelies
53' Chevy 3100 5 window http://67-72chevytrucks.com/vboard/s...d.php?t=660793
http://67-72chevytrucks.com/vboard/s...d.php?t=771679
Sim6 is offline   Reply With Quote
Old 05-27-2015, 10:49 PM   #256
youngrodder
Originally Posted by Sim6 View Post
Marc, great work.
Thanks guys.. I should have some progress to report soon. Porterbuilt is getting close on the drop member that they are building for me. I also made a few changes to my 48 so that has eaten into my garage time. The weather has been nice as of late so I have been enjoying driving the 48.
Marc
Old 05-27-2015, 11:29 PM   #257
oldman3
oldman3's Avatar
Marc
So don't keep us guessing, what did you do to the 48, looked perfect to me...Jim
oldman3 is offline   Reply With Quote
Old 05-28-2015, 01:29 PM   #258
youngrodder
Well Jim, It started with a leaking freeze plug in the front of the block. Once I changed that, it snowballed into a couple other changes. Some changes are more visible than others. Here's a run down.
1 - Upgraded to a new bigger radiator. Needed to create room to fit.
2 - Painted a lot of my billet Street and Performance pulleys and brackets. Billet was too hard to keep polished. Black is the new chrome.
3 - Changed the collectors on my exhaust system and added some SS flex joints.
4 - Re-welded one of the mounts for my tail pipe that cracked (see item 3 above)
You know how it is, after putting miles on them you decided to fix/change some stuff.
I will take a couple pics of engine bay to give you an idea.
Marc
Old 05-28-2015, 02:16 PM   #259
oldman3
oldman3's Avatar
I know what you mean, did you go aluminum with rad...Jim
Old 05-28-2015, 03:08 PM   #260
youngrodder
Yes, but a 4 core. Because of the location of my steering box, I have a radiator that is 4" shorter than a stock radiator. I have never been pleased with the way my previous 3 core radiator cooled. Some of that might have to do with slug that was in my engine from sitting all of those years. I learned after my initial start up that Dexcool when mixed with air turns to a slug. I flushed the block and radiator a crap load of times. I think maybe my old radiator was partially plugged so I figured what the heck lets upgrade to a new 4 core while I'm at it. needless to say I have no cooling issues.
My truck never overheated it just ran hotter than I was comfortable but well within spec for the motor.
Marc
Old 05-28-2015, 03:41 PM   #261
lower50's
lower50's's Avatar
Sounds like some good upgrades!! They all need some TLC from time to time.
1951 MG TD
Old 05-28-2015, 05:20 PM   #262
Advanced Design
Advanced Design's Avatar
Nice upgrades on the 48. Looking forward to seeing them....no rush getting back on the Burb.
Advanced Design is offline   Reply With Quote
Old 05-30-2015, 10:49 PM   #263
youngrodder
Hey that's my line...ha ha
Here are a couple pics.
I included a pic of the shrink band that I used. If you have never used these they work great and look clean. I basically changed out the motor components and ss radiator hoses to black and had to notch the radiator panel to make room for the radiator.
Marc
Old 05-30-2015, 11:53 PM   #264
Iceburgh
Iceburgh's Avatar
That truck is just bad ass
1953 suburban build
http://67-72chevytrucks.com/vboard/s...d.php?t=621331
Iceburgh is offline   Reply With Quote
Old 05-31-2015, 12:08 AM   #265
youngrodder
Thanks man....
Old 05-31-2015, 09:10 AM   #266
Advanced Design
Really incredible! Have looked at those bands before and never seen them installed. Were you happy with how they worked out so far?
Old 05-31-2015, 09:49 PM   #267
youngrodder
Yes, I was skeptical because I always seemed to chase coolant leaks but from day one these sealed up tight. They are more $$ than clamps but sometime its the details that are the difference. I plan to use them on all my builds.
Marc
Old 05-31-2015, 10:31 PM   #268
CHIZZLER
SAVING ONE TRUCK AT A TIME
CHIZZLER's Avatar
Very clean marc. Looks great.
53-suburban (99% done)
40-pick up (99.9% done)
12-cc lb dually D-max (dd)
61-crew cab D-max
"PAY LESS FOR WHAT YOU NEED PAY MORE FOR WHAT YOU WANT"
53 BURBAN BARN FIND:http://67-72chevytrucks.com/vboard/s...d.php?t=404091
1940 PROJECT MOON SHINE:http://67-72chevytrucks.com/vboard/s...d.php?t=551088
1961 CREW MAX: http://67-72chevytrucks.com/vboard/s....php?p=6957999
CHIZZLER is offline   Reply With Quote
Old 06-11-2015, 10:20 PM   #269
IWanna49
IWanna49's Avatar
Marc! Saw your spread in Street Trucks....absolutely gorgeous!!!
-Greg
'51 3600/s10 swap- in progress
Build thread:
http://67-72chevytrucks.com/vboard/s...d.php?t=641511
IWanna49 is offline   Reply With Quote
Old 06-16-2015, 02:20 PM   #270
youngrodder
Thanks man...I'm pretty stoked about it.
Marc
Old 06-16-2015, 10:04 PM   #271
IWanna49
IWanna49's Avatar
If they gave you digital copies, I'd love one of the straight on shots for wallpaper!!!
-Greg
Build thread:
Old 06-18-2015, 11:02 PM   #272
youngrodder
I need to play around and resize the image as the files I have are hi-res. Let me see what I can do
Marc
Old 07-28-2015, 10:34 PM   #273
youngrodder
Due to an expected/unexpected job change I have not been spending anytime on the burb. I did get out there tonight and I plan on working on it more and more now that I'm a couple weeks into a new job. Porterbuilt is close on the AD kits. Here are a few pics that they have shared on Instagram. A few of that changes are now the front and rear will be a bolt in unit. The rear rails flow like the stock rails. I was told they just need to fab the front radiator support and there done. In the meantime I will get my frame blasted in anticipation.
Marc
Old 07-29-2015, 10:24 AM   #274
Advanced Design
Very nice parts. Looking forward to seeing them on your chassis!
Old 08-29-2015, 09:59 PM   #275
youngrodder
Well I spent a good portion of last Sunday in the garage as well as today. I was able the get the floor out. The problem that I ran into was the rusted carriage bolts that held the wood in around the perimeter. The nuts were rusted and the bolts simply spun. I ended up spot welding each one so that they would not spin. I also removed the rear sill. I was not certain how this was to come out after snapping the heads off of about 12 bolts and cutting a few spot welds I was able to easy it out. I needed to remove it to properly replace the rear driver side cab corner. Here are some pics to prove it.
