Closed Thread
Old 12-11-2009, 09:49 PM   #426
Beatcoaster
69 Fleetside
Beatcoaster's Avatar
Re: Got some new wheels: Boss 338's in 20x10 and 20x8.5
Hmmm 22's eh? I wonder how those would work with a 3/5 drop...wonder if it would rub with a 40 series tire while turning...
Beatcoaster is offline
Old 12-12-2009, 12:52 AM   #427
Dirty McFast
Those are tall tires,...
(29" and 29.7" tall)
The rear tires might work,... but those front will be really tall on a static dropped truck.
They just threw those tires in to try and sell me. What do you think would be a good size to run? I do have a 4/6 drop. I was actually looking at 255/50/18 and 285/45/20 (or 285/50/20).
Dirty McFast is offline
Old 12-12-2009, 01:24 AM   #428
lolife99
67-72 parts collector,…
lolife99's Avatar
Just my opinion,...
but I don't like 18's and 20's.
I would runs a 20x8.5 with a 255/40-20 and a 20x10 with a 295/40-20.
A 50 series tire is too tall for a 4/6 drop.
There will most like be issues with any 4/6 drop and a tire larger than 26" tall, rubbing on the inner fenders. (on large bumps in the road).
73-87 trucks will be worse due to the shape of the inner fenders.
Keith
Convert to disc brakes.
lolife99 is offline
Old 12-12-2009, 02:27 AM   #429
BossHogg69
motor exploder
BossHogg69's Avatar
285/50's are 31.25" tall. i seriously doubt they'll work with a 4/6.
lolife is right on with the 40-series tire rec. for 20's.
Adam
1969 Chevy CST/10 stepside, DART Big M/TREMEC Magnum Extreme/3.73's w/Detroit Truetrac
1965 Chevy Bel Air Wagon (daily driver), 327/TH350,10 bolt w/3.08's
1961 Chevy Bel Air Sport Coupe, ZZ454/M21/9" rear w/3.50's & Detroit Truetrac
2005 GMC 1500 ccsb 2wd, 6.0L/4L65e/3.73 G80
2006 GMC 2500HD ccsb 4x4, DMax LBZ/Allison 6spd/4.56's w/Detroit TrueTrac
Use the SEARCH function on this forum - it is your friend!!
BossHogg69 is offline
Old 12-12-2009, 09:22 AM   #430
Strut
Strut's Avatar
Here is something you guy that are looking for tire can use:
Section Width
Following the letter(s) that identify the type of vehicle and/or type of service for which the tire was designed, the three-digit numeric portion identifies the tire's "Section Width" (cross section) in millimeters.
P225/50R16 91S
The 225 indicates this tire is 225 millimeters across from the widest point of its outer sidewall to the widest point of its inner sidewall when mounted and measured on a specified width wheel. This measurement is also referred to as the tire's section width. Because many people think of measurements in inches, the 225mm can be converted to inches by dividing the section width in millimeters by 25.4 (the number of millimeters per inch).
225mm / 25.4 = 8.86"
Sidewall Aspect Ratio
Typically following the three digits identifying the tire's Section Width in millimeters is a two-digit number that identifies the tire's profile or aspect ratio.
P225/50R16 91S
The 50 indicates that this tire size's sidewall height (from rim to tread) is 50% of its section width. The measurement is the tire's section height, and also referred to as the tire's series, profile or aspect ratio. The higher the number, the taller the sidewall; the lower the number, the lower the sidewall. We know that this tire size's section width is 225mm and that its section height is 50% of 225mm. By converting the 225mm to inches (225 / 25.4 = 8.86") and multiplying it by 50% (.50) we confirm that this tire size results in a tire section height of 4.43". If this tire were a P225/70R16 size, our calculation would confirm that the size would result in a section height of 6.20", approximately a 1.8-inch taller sidewall.
Just throwing it out there!
1972 Chevy C10 SWB
1999 GMC Sonoma Mini
2008 Yamaha R1
2007 Harley Nightster
Strut is offline
Old 12-12-2009, 09:37 AM   #431
DroppedAsAChild
DroppedAsAChild's Avatar
On my OBS 99 Im running 245/50/20 upfront and 255/50/20 out back on a 4/6. Like i posted earlier. I know there different clearance issues from the 67-72's and the 88-98's but. It is possible to run a 50 series tire on a 4 inch drop. I ran 255/50/20 up front for a while, it rubbed on larger bumps and dips but it still fit. I didnt want to rub at all so i went with smaller upfront.
1999 OBS Gmc Sierra ECSB Classic 1500 2wd-The Show truck
(Black/Greystone metallic 2 tone)
1999 OBS GMC Yukon 4dr 2wd-Daily Driver/Toy (White)
1990 OBS GMC Sierra ST RCSS 2wd-100% Factory Original
(Crimson Red/Metallic Silver 2 tone)
1997 OBS Chevrolet Silverado ECSB 2wd-Pops Daily/Tow Pig (White)
DroppedAsAChild is offline
Old 12-12-2009, 11:06 AM   #432
lolife99
lolife99's Avatar
Section Width
P225/50R16 91S
P225/50R16 91S
Good info.
I use Miata Tire Size Calculator. I'm not sure if it's 100% accurate,... but it's close.
http://www.miata.net/garage/tirecalc.html
Keith
lolife99 is offline
Old 12-14-2009, 08:34 PM   #433
love my 72
love my 72's Avatar
ok,
I dont know if we covered this but i spoke with the vendor who quoted me and the guy claims to have these wheels on a 68 Pick up with a 5 lug conversion and that all he needed was 1/4 inch spacer in the front wheels on standard length lug studs, and no problems.
Any thought son this? I personaly dont like that idea too much but it is a nice American made wheel for the $$
51 Chevy 3100 Deluxe Cab(SOLD)
65 **stang 6cyl
70 C10 Long Bed Fleetside(1st truck,thanks Dad![SOLD])
72 C10 Short Bed Fleetside
73 Blazer 2WD Catalina Blue White Top(Needs Love)
73 Blazer 2WD Work in progress LT1/4L60E
83 Grand National (SOLD)
94 Blazer K1500 Silverado (SOLD)
96 Impala SS All original (NEXT IN LINE 2 B SOLD)
99 Tahoe 2DR, 2WD
love my 72 is offline
Old 12-14-2009, 08:48 PM   #434
lolife99
lolife99's Avatar
Originally Posted by love my 72 View Post
ok,
I put my front 20x8.5" wheel on a 5-lug 1.25" wide rotor and there was at least a 1/2" gap keeping the wheel from making contact with the face of the rotor.
Maybe the '68 had 1" rotors.
As far as I know this is the only solution (except machining the rotor) to make the old design work.
Keith
lolife99 is offline
Old 12-14-2009, 08:54 PM   #435
lolife99
lolife99's Avatar
My old rotor comparison pics.
I say buy a set and let us know how it turns out using the 1/4" spacers.
Looks like you would need longer lug studs.
Keith
lolife99 is offline
Old 12-15-2009, 12:24 AM   #436
Strut
Strut's Avatar
Where can a guy get these 1 inch rotors? Do you have any Part #'s for them?
1972 Chevy C10 SWB
2008 Yamaha R1
Strut is offline
Old 12-15-2009, 01:07 AM   #437
brossow
Amateur Rust Fighter
brossow's Avatar
They're just the light-duty rotors. Should be able to find them at any auto parts store by looking up the base model for your particular year, I would think.
Keep in mind that the narrower rotors may require different calipers as well. Not sure about that.
Brent
'72 Chevy SWB stepside - [ Build Thread ]
'79 ChevMC SWB fleetside - [ Build Thread ]
'64 Chevy SWB fleetside & '66 Chevy SWB stepside (waiting in the wings...)
brossow is offline
Old 12-15-2009, 01:45 AM   #438
Hart_Rod
Hart_Rod's Avatar
and spindles.....
Hart_Rod is offline
Old 12-15-2009, 02:16 AM   #439
lolife99
lolife99's Avatar
Yep.
Requires 1" rotor, and compatible caliper, and spindle.
If you are installing these on any truck other than a 73-87 (73-91 'burb),... you will need to swap ball joints and tie rod ends as well.
Keith
lolife99 is offline
Old 12-15-2009, 02:17 AM   #440
brossow
brossow's Avatar
Yep.
But other than that, it's a piece of cake.
(Seriously, just wait a few weeks for the corrected wheels to come to market.)
Brent
brossow is offline
Old 12-15-2009, 02:30 AM   #441
lolife99
lolife99's Avatar
I know what you are saying.
I am rebuilding the entire front suspension on my '86 anyway,... so I just have to use the correct 1" rotor parts.
Now if the wheels end up on my '69,... I will be swapping out a ton of good parts just to bolt them up.
Ha,... and 5 months of "waiting just a few more weeks".
Keith
lolife99 is offline
Old 12-15-2009, 11:31 PM   #442
brossow
brossow's Avatar
I don't get why you'd downgrade your braking to accommodate a poorly designed wheel. But that's just me.
Brent
brossow is offline
Old 12-15-2009, 11:57 PM   #443
lolife99
lolife99's Avatar
Rotor is only .250" thinner.
Diameter of the rotor is the same.
Caliper will function the same.
The real reason,... all four 20's for $700.
Keith
lolife99 is offline
Old 12-16-2009, 12:09 AM   #444
love my 72
love my 72's Avatar
I Agree with lolife,
I imagine that the .250 thickness will make a minimal measurable downgrade to the braking efficiency.
Hopefully the corrected hub will be available by the time i "need" the rims
65 **stang 6cyl
99 Tahoe 2DR, 2WD
Old 12-16-2009, 12:25 AM   #445
SCOTI
SCOTI's Avatar
For a cruiser/lt.duty truck that doesn't see 'hard' life, the 1.00" rotor combo would be fine. If you tug a trailer around.... 1.25" rotors are better suited.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
SCOTI is offline
Old 12-17-2009, 06:03 PM   #446
rob32472
ok guys i have been told the new wheel is avail so I ordered them today...... was told I could return if they dont fit. I will post pics when they arrive
rob32472 is offline
Old 12-17-2009, 06:34 PM   #447
sixty8c10
MY EX DRIVES A BROOM
sixty8c10's Avatar
where'd you order from, is a group an option?
They say nobody's perfect.
I'm a nobody, so I must be perfect.
Building Nemo -1968 C10 Long Bed
FRED -1947 KB-2 International
sixty8c10 is offline
Old 12-17-2009, 06:39 PM   #448
Hickup pickup
Hickup pickup's Avatar
PT Barnum once said " there's a SUCKER born every minuite!.
2-20, 2-21 whatever it takes!
Hickup pickup is offline
Old 12-17-2009, 06:50 PM   #449
Strut
Strut's Avatar
Hope they fit.....
1972 Chevy C10 SWB
2008 Yamaha R1
Strut is offline
Old 12-17-2009, 08:02 PM   #450
lolife99
lolife99's Avatar
Let us know your outcome with the wheels you ordered.
Several sources are saying they are still weeks (if not months) away from being ready with the new design.
Keith
lolife99 is offline
Closed Thread
