#426 |
I'm just glad to be here!
Re: Project Goldilocks, '66 C10 SWB BBW Build
Sounds like a plan on the arms. Why not just use Porterbuilts Foward Arms?
The engine is going to look outstanding with those webers! Posted via Mobile Device
Karl ![]() 1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues) http://67-72chevytrucks.com/vboard/s...d.php?t=372424 The LST Challenge: http://67-72chevytrucks.com/vboard/s...=1#post7812257 Korbin's 1st Square: "Sunburn" http://67-72chevytrucks.com/vboard/s...d.php?t=418618 1985 GMC Sierra: "White Trash", Korbin's 2nd now... http://67-72chevytrucks.com/vboard/s...d.php?t=632305 Henry - 1984 Chevrolet, Owen's 1st Square |
#427 | |
I'm planning on coating the carbs with PPG DX series aluminum conditioner to get this look. The stacks will be satin black and manifold will be Alpine Green like factory '66 327s, and I'll use either zinc plated steel lines or regular rubber fuel hose for more of a factory look.
Project Goldilocks '66 C10 Short Fleet BBW Build '65 C10 Highly Detailed Stock Restoration Thread '78 Camaro Targa Roof Build '55 International Metal/Body/Paint Work '66 F100 Full Rotisserie Restoration '40 Packard 120 Convertible Coupe Restoration How To Restore and Detail an Original Gauge Cluster How To Detail Sand Body Panels, Edges, Corners, Etc |
#428 |
where did you find the air gauge and where can i get one? awesome work btw
#429 | |
#430 |
Body mount kit came in today, earlier than expected. Might get to start this weekend instead of next!
#431 |
Got the F-Body pan and cleaned it up. Also pulled out the front suspension parts to take baseline measurments from the A-arms.
#432 |
Great build! Looking forward to seeing more
Posted via Mobile Device |
#433 |
Thanks Eric, come over and check it out some time!
#434 |
Artist
![]() Join Date: Jan 2010
oh wow that intake is killer!! I was looking at doing a factory type three duece setup from a vette... but this is WAYYYY cooler. When this is done park beside mine as much as you can.... a background shot will be the only chance I'll have in the mags with this thing! HA!
66 Chevy C10 283ci~cough~ SBW Fleet Buttercup '66 |
#435 |
Hahaha whatever, by time I get this thing finished 60-66's will be out of style and you'll already have all the mag coverage tied up!
#436 |
![]() Join Date: May 2007
Went to a show today , thought you would like these
James 63 GMC V6 4speed carryall 65 chevy swb bbw V8 auto 68 K20 327/4 speed, buddy buckets 2002 GMC CC Dually Duramax 64 GMC lwb 3/4 V6 4speed SOLD 66 GMC swb bbw buddy buckets SOLD IG duallyjams The only thing that stays the same is constant change! |
#437 |
Nice, thanks for posting those! We nearly bought a '64 Vert that had been garaged for 30 years (no rust!) but the dude backed of the sale.
#438 |
chevy only
![]() Join Date: Sep 2006
Oh i like were this build heading and with you style and work being so clean duude
CHEVY ONLY... Nothin Else ! |
#439 | |
I sold the front suspension and brake parts so I weighed it all while I had it pulled out. My digital scales have a 35 pound weight limit so I had to measure the heavy stuff with bathroom scales. It will be interesting (to me atleast) to see how much weight I can save with the rack and pinion kit, tubular arms, and CPP modular spindles.
Total weight- 279 pounds, 4.1 oz.
#440 |
"MalibuKasey and I have been planning out building our own tubular A-arms that fix the lack of needed castor and camber adjustment that stock arms have and also move the wheel forward to center the wheel in the fenderwell while we're at it. I'm also going to look into taller C20 upper ball joints that will increase camber gain through the suspension travel, and possibly drop the upper A-arm cross bar mount for even more camber gain if its needed."
Don't tell me you 86'd this part of the project and decided to buy rather than redesign. I was curious on what you came up with cause your always top notch. ![]() I recently made a upper ball joint/a-arm mod and not sure if it will help or hinder my build. |
#441 | |
#442 |
Did a little parts shopping. Picked up an original offset stud driver side mirror that will replace the original (and hideous!) RV jr mirrors. Still need a passenger side arm and mirror head. Also scored a deal on a pair of NOS Custom sail plates.
Project Goldilocks '66 C10 Short Fleet BBW Build '65 C10 Highly Detailed Stock Restoration Thread '78 Camaro Targa Roof Build '55 International Metal/Body/Paint Work '66 F100 Full Rotisserie Restoration '40 Packard 120 Convertible Coupe Restoration How To Restore and Detail an Original Gauge Cluster How To Detail Sand Body Panels, Edges, Corners, Etc Last edited by theastronaut; 03-19-2013 at 05:30 PM. |
#443 |
Sweet!!! Nice find on the Sail plates.
#444 |
Rollin' Old Skool
nice finds, especially the cab sails! I need to find a set of mirrors like that for mine in the future. I plan to get rid of the dumbo style aftermarket mirrors which are also hideous! btw, where'd you find the Custom cab sails?
_____________________________________________ Phillip My Build threads: 1966 Chevy C-10 "Black Betty" shortbed, fleetside, BBW, 327 V8/ Powerglide (under construction) http://67-72chevytrucks.com/vboard/s...ighlight=betty 1997 Chevy Tahoe, 2dr/2wd, mild custom (Daily driver) http://67-72chevytrucks.com/vboard/s...d.php?t=601142 Pics: '66 C-10 https://flic.kr/s/aHsjHWD4h9 '97 Tahoe https://flic.kr/s/aHsjGZ7wKP '93 C-1500 https://flic.kr/s/aHskxdpdnQ '88 S-10 Blazer https://flic.kr/s/aHsjYGx4Md Previous Rides: 1993 Chevy S-10 ext. cab, 4.3L, 4/5 drop (Sold) 1993 Chevy C-1500 short/step Retro-Rod (Sold) 1988 S-10 Blazer 2dr/2wd mild custom (Sold) |
#445 | |
![]() Posted via Mobile Device
#446 |
Hate when that happens
#447 |
I love your builds. I went back the other day to your dodge build to get a refresher on blocking and what seam sealers you use. Your documentation on here is priceless.
#448 |
Can I ask where you got your body mount kit?
Craigerrr My build thread, CRGRS 66 Winter Build: http://67-72chevytrucks.com/vboard/s...09#post5638709 |
#449 | |
That's my second late night catch! The other was a just-posted Marchal Amplilux headlight for $65 BIN, ten bucks shipping. I posted it on a Porsche forum and sold it for $175 plus shipping the same week... I'm still kicking myself for selling that one, I should have pieced together a pair for Goldilocks.
Really neat headlights from the 60's/70's. They have a separate bulb and reflector for low/high beams so each reflector and lens section is suited for the beam pattern. ![]() ![]() Quote:
I bought it from US Parts Outlet on ebay. Shipping was very quick, got here a few days sooner than expected. I couldn't find anyone local that had them.
#450 |
Daring to be Different
That head light would look great om my motorcycle.
Dennis ![]() http://www.67-72chevytrucks.com/vboa...d.php?t=327644 KUSTOM RIDES FACE BOOK PAGE: https://www.facebook.com/groups/291198124258863/ 1965 C-10 Short Bed 350/700r4 2012 Silverado 1500 Crew Cab 2016 Honda Accord w/ 18" rims 2007 Honda Goldwing Trike w/ NAVI 2001 Yamaha Roadstar Indian look alike "Life's journey is not to arrive at the grave safely in a well preserved body, but rather to skid in sideways, totally worn out, shouting "...WOW!...what an amazing ride!" Live Life Passionately!!! [/COLOR] ![]() I AM WE TODD IT, I AM SOFA KING WE TODD IT |
