Old 09-26-2016, 02:55 PM   #426
ptc
ptc's Avatar
Re: 1956 Chevy Pro-Street Build
Originally Posted by l78vetteman View Post
Just looking at your beautiful headers - very nice. Are they custom for the truck or were they spec'ed for something else? Maybe '57 Chevy BB?
Keep up the good work.
Actually those chrome ones are for a BBC in a 55-57 Chevy Car. But they fit the truck frames really nice and mine has a Camaro clip on the front. The passenger side bolts right on but the driver side is a misfit on the front tube.
Im going to be selling this chrome set because I dont want to cut up the chrome finish. They are made by Sanderson and Im asking $250 for the set.
let me know if you are interested.
My Build: 57 Chevy Pro-Street
ptc is offline   Reply With Quote
Old 10-06-2016, 10:40 AM   #427
ptc
ptc's Avatar
Havent been on the old inter-web in a while but have had a few changes going on in life and the truck..... My oldest daughter (I have 3 of them) gave birth to our 3rd GRAND BABY! A boy named LUCAS!!! so we welcomed him into this world September 19th and he is a gem! We feel very blessed.
And the truck - well Ive been fighting the front of the engine 'blues' trying to get everything to fit around that BIG OLE AIR SUCKER!!!! finding a power steering pump mostly to fit and the lines. Have tried 2 different ones now and now changing to a KRC circle track race car pump. Its tiny but pumps like crazy. And the inlet and outlet are in the right places too. So once this is in I will be able to get some lines done and get all this completed.
So the mount is on the block and the new pump is on its way. Crossed fingers that this is the one that will work!
Heres some more pics
Old 10-06-2016, 11:24 AM   #428
joedoh
joedoh's Avatar
congrats on the grandbeeperfish! I have 3 daughters too, my brother in law said famously that "boys take risks, if you can keep them alive till about 12 then there is a good chance they will be fine after that. girls are easier in the beginning, but at 12 your problems have just started" haha
the mass of men live lives of quiet desperation
if there is a problem, I can have it.
new project WAYNE http://67-72chevytrucks.com/vboard/s...d.php?t=844393
joedoh is offline   Reply With Quote
Old 10-06-2016, 12:37 PM   #429
Rods57
Rods57's Avatar
Congrats on the Grandson, i think we all forget sometimes life happens, good to take some time to live it....
Rods57 is offline   Reply With Quote
Old 10-06-2016, 07:39 PM   #430
ptc
ptc's Avatar
SO VERY TRUE!!!! --- part 2 of that advice is if they can stay alive AFTER meeting GIRLFRIENDS DADS they have an even better chance at a long life!!! lol
Thanks much for the congrats guys....
Old 10-06-2016, 10:50 PM   #431
lower50's
lower50's's Avatar
Congrats!!! So 3 daughters, 3 grandchildren, is it one per or 3 from your oldest? Either way it should be fun. Nice looking pump to, if it pumps like crazy will you need a ps cooler?
http://67-72chevytrucks.com/vboard/s...d.php?t=648459
https://67-72chevytrucks.com/vboard/...d.php?t=769441
1951 MG TD
1967 Jeep CJ5 1.9L TDI 33X13.5X15 Mud Grapplers.
1952 GMC 9700 p/u 7.3L diesel on air, dually
lower50's is offline   Reply With Quote
Old 10-07-2016, 12:35 AM   #432
Nut Case
Nut Case's Avatar
ptc
Grandchildren are the reward for not smothering our children while they slept.
If that shirt had buttons they would all be gone.
Good on ya!!!
Your build is so fun and informational
Keep on keepin on
Nut Case
Been there, wrecked that
Nut Case is offline   Reply With Quote
Old 10-07-2016, 07:48 AM   #433
Kim57
Kim57's Avatar
Congrats on the new grandson.
Very cute kid.
Kim
My build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=283107
Kim57 is offline   Reply With Quote
Old 10-12-2016, 08:35 AM   #434
RockinKees
RockinKees's Avatar
Congratz with your new grandson!!
Future Hot Rodder?
Must be....
You're blessed!
Cheers!! Kees.
1959 Chevy Fleetside Longbed
My build: http://67-72chevytrucks.com/vboard/s...d.php?t=643426
Kool Guyz CC
Instagram: _King_Kustom_
RockinKees is offline   Reply With Quote
Old 10-12-2016, 10:07 AM   #435
ptc
ptc's Avatar
Thanks Guys so much! -- Yes feel very Blessed / Son has grandson #1 - 3yrs old now, Oldest Daughter has 2 grandkids; 2yr old grandaughter, and now our brand new grandson #2.
Daughters 2 and 3 are still working on finding somebody Dad doesnt chase away with a salt gun!..... no hurry!
Ok so I got the radiator all mocked up into place with the stock support.... albeit HIGHLY CUSTOMIZED to fit the cross flow radiator from a Chevelle. It is the biggest one that will fit between the bottom dimension. Its a Champion radiator, has trans cooling and inlet and outlet of 1.5" dia.
I made a saddle bottom mount using some Uni-Strut and some 1/2" angle iron to 'saddle' around the bottom flange of the radiator. That mount goes across the whole bottom and holds the radiator just above the main support mounting bolt heads after its bolted in.
I also made the top holding pieces out of 16 GA sheet metal and just bent it around the top flange of the radiator. They are sheetmetal screwed into the main support with flat top heads. Then I made my own radiator top cover to completely cover the whole top, across the latch mount piece and the radiator altogether. All these parts will be painted same color as frame. The radiator will stay polished alum.
The P/S pump is in and the reserviour is on the next to the radiator, and I got all the trans lines made up too.... busy weekend!!!
pics
Old 10-12-2016, 10:39 AM   #436
ptc
ptc's Avatar
Heres some other stuff Ive been working on too... electrical panel for fuse box, CDI, Harness mount. this goes under the dash left of column. Also got the P/S pump installed.... fits perfect!
Got the dash and the bottom skirt all welded in tight with the wraps on the ends fitted in. The new trans tunnel is done. Just need to tackle that firewall again.
Next is blow it all apart for the last time and sand and prep the frame for paint.... FINAL ASSEMBLY is in SIGHT!!!!
Old 10-12-2016, 04:27 PM   #437
Kim57
Kim57's Avatar
Looking real good.
Radiator install and trans tunnel came out nice.
Kim
My build thread
Old 10-12-2016, 05:03 PM   #438
II_Slow
II_Slow's Avatar
So how did you get turned on to the Daytona Sensors Igntion? I'm not familiar with their stuff.
1955 SB Stepside 3100 big window cab on a 99 Ram 2500 Frame w/ 12-V Cummins diesel power and
47RH AOD transmission
http://67-72chevytrucks.com/vboard/s...d.php?t=640042
II_Slow is offline   Reply With Quote
Old 10-12-2016, 09:52 PM   #439
Advanced Design
Advanced Design's Avatar
Congratulations on the Grandson! We are up to four now (2 boys, 2 girls) and they are the delight of our lives.
Nice work on the radiator and transmission tunnel. Good deal on the ps pump too.
Advanced Design is offline   Reply With Quote
Old 10-13-2016, 05:19 PM   #440
ptc
ptc's Avatar
Thanks guys for checking in....
Thanks Kim - you are the master of metal works... Mine looks ok from 20 feet! lol still more finishing to do on the metal work.
2 Slow - My Cam builder actually got me involved with them, really nice stuff, and made in 'Merica!!! It came as an entire kit with the CDI, Coil, Harness, mounts, tuning guide with USB port, and a book of instructions! I have never had any problems with MSD on my boat but for the money I got alot more with Daytona. Im using a MSD Pro Billet Disty with it.
AD - Thank you, and yes we love them like crazy... I want them to grow up fast so we can do more.... but then again I like them as babies too, there just so darn cute!!!!
Old 10-13-2016, 06:14 PM   #441
lower50's
lower50's's Avatar
The rad looks like it is factory. Nice looking tunnel. It looks removable?
1951 MG TD
Old 10-15-2016, 09:40 AM   #442
55 Chevy Dave
55 Chevy Dave's Avatar
Wow! You've gotten a lot done! Everything looks great! I wish I was as far along as you are. Guess I better get back out to the garage and get to work!
My build thread http://67-72chevytrucks.com/vboard/s...d.php?t=654899
55 Chevy Dave is offline   Reply With Quote
Old 10-16-2016, 08:52 PM   #443
Coupeguy2001
Coupeguy2001's Avatar
Why are you doing all of this if you don't have stock in a tire company????
just talking out loud........
Coupeguy2001 is offline   Reply With Quote
Old 10-18-2016, 12:31 AM   #444
ptc
ptc's Avatar
Well moving right along ....
I thought I was keeping up here on the build but I guess not. Over the past week and a half I have gotten the frame stripped of everything, painted, and just about put back together.....
Pics
Went with the Gray Hammerfinish...
Old 10-18-2016, 12:35 AM   #445
ptc
ptc's Avatar
Back into the shop it went and the late night helpers have put Hoopdy Doopdy back together again!!!
pics
Old 10-18-2016, 02:56 AM   #446
Nut Case
Nut Case's Avatar
ptc
This looks so good, you gotta be jazzed, the final assembly
Someday I'll make it to where you are.
Good on ya
Keep on keepin on
Nut Case
Old 10-18-2016, 08:05 AM   #447
Kim57
Kim57's Avatar
Looks real good.
Kim
My build thread
Old 10-18-2016, 09:09 AM   #448
gotmotors
gotmotors's Avatar
Great build you got going here ptc. It's gonna be baaaad.
Chassis looks awesome.
Jim
My 55 build
http://www.trifive.com/forums/showthread.php?t=97044
gotmotors is offline   Reply With Quote
Old 10-18-2016, 07:44 PM   #449
ChuckDriver
A320 Pilot/USAF Retired
ChuckDriver's Avatar
Frame looks great!
ChuckDriver is offline   Reply With Quote
Old 10-18-2016, 09:54 PM   #450
l78vetteman
l78vetteman's Avatar
That frame looks outstanding! What color paint is that? I like the contrast with the black suspension components.
l78vetteman is offline   Reply With Quote
