Old 12-31-2008, 10:30 PM   #26
SCIV
SCIV's Avatar
Re: '68 C10 Short-Step 6.0 + TT swap
Originally Posted by texanidiot25 View Post
Nice looking guages, where did you grab these?
Thanks! I thought the black/silver went well with the stock black/silver. When I get them all done, I will repaint it to look like new.
Autometer Sport Comp, got 'em from Summit. The other ones haven't come in yet (speedo, tach, volt, fuel).
I don't know what I am going to do about the center hole though.
'68 Chevrolet Short Step
6.0 L + 91mm + TH400 + 9" + 4-Link
SCIV is offline   Reply With Quote
Old 12-31-2008, 11:52 PM   #27
ripdog28
ripdog28's Avatar
Center one can be a trans temp or a Boost gauge when you got the turbo on. glad to hear your moving the pump and lines up a little.
69 c-10 BBC
462ci, forged crank, H-beam rods, 10.5-1 KB forged pistons, Dart Iron Eagle 308cc, Straub Cam, Comp Cams chrome moly full rollers, Weiand Team G, Prosystems 950, TH400/3500 Dalenzie stall, Currie 9+ Detroit Locker w/31spline axles.3.5/6in drop. My Build.
ripdog28 is offline   Reply With Quote
Old 01-04-2009, 06:58 PM   #28
SCIV
SCIV's Avatar
OK - I reconfigured the fuel pump/filter setup. Raised the pump 4" so the inlet is flush with the bottom of the tank. Also installed a 90* fitting to wrap the filter closer to the tank. Put the cell in it's final home too.
Also put in the radiator and Impala efans. Fans fit pretty well! Need to get hoses, and serp belt, and plug wires. Trans & oil cooler showed up too.
Old 01-04-2009, 07:06 PM   #29
ripdog28
ripdog28's Avatar
haha looks nice but i have another suggestion. Just trying to make sure you do not have problems later. Your filter should be after your pump. I could be wrong but i think you should have an unobstructed flow from your tank to your pump. It will probably be fine but i can see it possibly causing your pump to starve.
69 c-10 BBC
Old 01-04-2009, 07:37 PM   #30
SCIV
SCIV's Avatar
That is a 100 micron pre-filter. I also have a 10 micron after pump filter. That is the way Aeromotive suggested it?
Old 01-04-2009, 07:51 PM   #31
Hart_Rod
Hart_Rod's Avatar
You definitely want to have both.
Hart_Rod is offline   Reply With Quote
Old 06-02-2009, 09:36 AM   #32
SCIV
SCIV's Avatar
OMG...an update!!!! First and foremost, 2 thumbs WAY up for DBRODS!!!! Jon busted his butt on my truck, and I appreciate it tremendously!!! He can do just about anything, on anything. I HIGHLY recommend him for anything you need done.
Anyway, Saturday after lunch we busted up the 'Ol Smurf truck. Complete front drum to disc swap. 2.5" drop spindles, 2" drop springs, all new rotors, bearings, seals, calipers, brake pads, brake lines, upper & lower ball joints, inner & outer tie rod ends.
After that, Jon said lets see what it will look like with the new rear drop...
So, out come the factory rear coils (not until Jon broke the rear bolts out). 40 + years of grime and they weren't moving. So, out they come and we set her on the ground for about 7" of rear drop. Hmmm, with 31" tall rear tires, this thing is going to have serious rake. OK, take it back up, and pull the bumpstops. Ahh, 9-10" of rear drop and she will sit right!!
After that, the day was young, so we pulled the motor to swap the truck pan for my F-body pan & pickup tube. I also wanted double check my cam timing to make sure I had the dots lined up (I installed it several months ago). All was well. Modified the truck windage tray to fit, bolted it back up, and dropped her back in. Also, checked the cylinders while the pan was off, still had the cross-hatch with 9x,xxx miles.
Don't mind the front tires, they are just to roll around on. New wheel & tire combos are 15" X 7" steelies with 235/70 up front, and 15" X 12" with 31" X 16" MT SR Sportsmans on the business end.
Next up, 9" rear, 4-link & new trans (TH400 w/transbrake).
Thanks again to Jon & DBRODS!!!!
Some pics for your viewing pleasure...
Old 06-02-2009, 10:37 AM   #33
my67chevytruck
Under Construction
my67chevytruck's Avatar
looking good.
Heath
subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php
http://67-72chevytrucks.com/vboard/s...d.php?t=157669
FAQ how to's
1956 Chevy Apache
1967 C10 SWB FleetSide (under construction)
1969 K10 SWB FleetSide (Future Build)
1972 C10 SWB Stepside (Future Build)
56 chevy truck :
http://www.cardomain.com/ride/2955823/1
67 truck build:
http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1
69 k10:
http://67-72chevytrucks.com/vboard/s...d.php?t=389470
my67chevytruck is offline   Reply With Quote
Old 06-03-2009, 09:28 AM   #34
sandking
.....I am working on it.....
sandking's Avatar
Looks nice!! I see you have lines from each end of the fuel pressure regulator to each of the fuel rails and the feed in the bottom. I thought the regulator flows line in one side, line out the other side then the bottom was for the return. I may be wrong
View my build thread HERE
sandking is offline   Reply With Quote
Old 06-03-2009, 02:43 PM   #35
SCIV
SCIV's Avatar
My fuel goes through the rails first, then into the regulator, then out the bottom for the return.
Old 06-03-2009, 04:03 PM   #36
sandking
sandking's Avatar
Aw, so the injectors use what they want, then spits the rest through the regulator. That makes sense.
Old 06-12-2009, 10:29 PM   #37
SCIV
SCIV's Avatar
Update...got the bed off and starting the 4-link rear suspension. I will post pics as soon as I can get them.
Old 06-13-2009, 06:19 AM   #38
71cadc10
71cadc10's Avatar
looks good, what are you doing for power steering hookup? Using the gen III pump and stock box I take it?
I need to get a solution.....lines figured out.
thanks
71 C10 long bed, 2003 6.0L, 06GTO E40, T56, 12bolt 4.10 rear
71cadc10 is offline   Reply With Quote
Old 06-13-2009, 12:39 PM   #39
Ford Assassin
Ford Assassin's Avatar
thanks
I had a local hydro hose shop custom build me a power steering hose for my swap. I brought them both ends, one coming from the LSx pump and the end going to my factory box. The put the two together with new Goodyear 1000 psi hose, swedged the connections, and even installed swivels on both ends to keep the hose from getting twisted up. Cost about $50 total.
Cable
-K5 Blazer 2wd: 6.0 LQ4, 7875 Turbo, Tick Stage II Turbo Cam, Built 4L80e, RevMax Billet 3600, 9.5" 14 Bolt
-Chevy 3+3 Crew Cab Dually: Cummins 12v P-Pump Swap, Compound Turbos, A2W Intercooler, NV4500HD, 4wd conversion, Radius Arms, Coilovers, Crossover Steering, etc
Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=803608
Ford Assassin is offline   Reply With Quote
Old 06-13-2009, 11:27 PM   #40
SCIV
SCIV's Avatar
I don't plan on running power steering, so I won't be of much help. I actually cut the power steering pump off the bracket. Assassin's idea sounds like a great plan.
Here is a sneak peak at the new rear & tires!!!!
Old 06-13-2009, 11:43 PM   #41
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
Those rear tires are huge. Im glad to see that you moved the fuel pump and filter up outta the way.. Looks great keep up the good work..
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
Old 08-07-2009, 03:47 PM   #42
SCIV
SCIV's Avatar
Well, how about another update (has it been 2 months already???) Some of the plans changes a little...now going with a manual valve body TH400, going to redo the motor mounts and move the motor back an inch or two.
And French, the cell got moved up another 2", so the pump will get moved up even more.
4 link underway:
Thanks again to DBRODS!!!
Old 08-07-2009, 04:58 PM   #43
SCOTI
SCOTI's Avatar
Nice.... Pretty slick welds too!
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 08-11-2009, 01:43 PM   #44
SCIV
SCIV's Avatar
Here is another update pic. Now we are getting somewhere!!!
Old 09-06-2009, 09:09 PM   #45
SCIV
SCIV's Avatar
Well tomorrow makes 1 year since I brought her home!!
Got the suspension done, and started to put her back together. Some update pics:
I still don't think it is low enough, but it will have to do for now. I want to drive it!!
Old 09-06-2009, 09:37 PM   #46
SCOTI
SCOTI's Avatar
Got the suspension done, and started to put her back together. I still don't think it is low enough, but it will have to do for now. I want to drive it!!
Looks cool.... but I must agree w/this. It's always something that can be addressed in the future. Leaving that rear bumper? I like the farm truck look but a 'sport' bumper painted & aged would look really good too.
Anyhoo.... Get some time-slips posted!
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 09-06-2009, 10:01 PM   #47
mcbassin
Still Learning
mcbassin's Avatar
Cool Hot Rod! Did I miss the part where you wired in the engine? Did you buy an aftermarket harness? I am considering this same setup in one our builds. thanks
mcbassin is offline   Reply With Quote
Old 09-06-2009, 10:45 PM   #48
Hart_Rod
Hart_Rod's Avatar
That rear shot just looks TOUGH!!!
Old 09-07-2009, 11:32 AM   #49
SCIV
SCIV's Avatar
Scoti - Yup, the rear bumper is staying. Curious though, got a picture or link to a "sport" bumper?
Mcbassin - I have a modified stock harness that I got with the motor. WAY too much crap still left in it though. I will be using nelsonperformance.com for a new custom harness.
Hart - Thanks man!
I am hoping to have it all sorted and running again by Christmas. Thanks for the kind words everyone.
Old 09-07-2009, 01:31 PM   #50
SCOTI
SCOTI's Avatar
http://67-72chevytrucks.com/vboard/s...d.php?t=191687
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
