06-24-2013, 12:35 PM | #26 | |
Re: Porterbuilt extreme Dropmember and 2 piece drive shaft question???
Keith 66 Suburban Burb Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=751361 IG: bennett68c10 |
06-24-2013, 05:45 PM | #27 |
Yes. Floor & back cab wall.
06-24-2013, 06:34 PM | #28 |
Yeah I forgot the back wall of the cab and floor.
06-26-2013, 11:11 PM | #29 |
Very interested in this information as well.. Subscribed
06-27-2013, 12:01 PM | #30 |
Talk to a local driveline shop and explained exactly what I needed. It should be done by tomorrow. I'll post pictures of the fit.
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
06-27-2013, 05:31 PM | #31 | |
Posted via Mobile Device |
06-27-2013, 07:38 PM | #32 |
^^^ X2
Posted via Mobile Device Posted via Mobile Device
06-30-2013, 08:13 PM | #33 |
Subscribed! Will be tackling the driveshaft issue in the coming weeks.
'72 GMC Suburban 1/2 Ton (Red) '68 C10 Short Fleet (OG 503 Light Green and Patina) '70 C30 Dually (OG City of Charlotte Welding Truck) Past 67-72's Chevy Trucks '68 C10 Short Fleet on 20" Coy's, '72 C20 Suburban (Ochre Big Block), '69 C20 Suburban (Silver), '69 C10 Suburban (Red/White on Boyd's), '72 C10 Short Fleet (Ochre on Torq's), '70 C10 Short Fleet (POS) |
07-04-2013, 10:25 AM | #34 |
Sorry for the late update, but the the shop didn't get the shaft completed until Monday afternoon. After I picked up and took it home I realized he had put an input shaft on for a 6L90 instead of a 4L60, arghhh!!! Ran back over there and he swapped it out in about 5 minutes. All said and done, $515 out the door for all new pieces including the carrier bearing and 3" diameter (more on that later). So I finally started fitting it but the angles were way off. I rechecked all my measurements and did some online research to find that the problem is with the height of the motor mounts. They are too tall and need to be 1" shorter. So I called and discussed this with Nate and he is supposed to build and send me some shorter ones next week. 1 step forward and 2 backwards, . And people wonder why we price our trucks so high when they ask. Here are a couple of pictures. As soon as I get the new motor mounts, I plan on doing a complete write up of how I did the measurements for all of this. Pics of course.....
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 Last edited by Hart_Rod; 07-04-2013 at 12:20 PM. |
07-04-2013, 11:17 AM | #35 |
Sooo frustrating. Sorry man.
68 BB burb build thread Scott's super slam front/rear http://67-72chevytrucks.com/vboard/s...d.php?t=378084 |
07-04-2013, 11:33 AM | #36 |
Yeah, that stinks, but at least there's a solution in the works. Thanks, as always, for the updates! She's gonna be AWESOME!
07-05-2013, 09:47 AM | #37 |
Sucks you are learning the hard way !! But thanks for all the info . This is something I need to do someday . Same set up as you, so hopefully mine can go a little smoother . Thanks for all the info !!!
07-05-2013, 05:33 PM | #38 |
No worries guys. I'm sure I'll get it all figured out sooner or later.
07-06-2013, 10:55 PM | #39 |
Sorry I'm late here with my driveshaft pics. I just had my driveshaft rebuilt a month ago, but I decided I'm switching to a ls/4l60 setup too, so I'll have to pull it back out. I don't like my carrier bearing because the bolt heads are the lowest part off the truck underneath. Nate told me that there's a differentstyleso when i pull it out i wanna change.
07-06-2013, 11:01 PM | #40 |
Here's the pics
07-07-2013, 01:20 AM | #41 |
I like where this is going ..
07-07-2013, 09:33 AM | #42 | |
07-07-2013, 09:35 AM | #43 |
67-72 parts collector,…
I think he means, carrier bearing,...
11-20-2013, 03:49 PM | #44 |
Hart_Rod - wondering where you ended up with all this - Nate actually had to built taller motor mounts for my engine to get it off the rack up front - so I'm super interested where you ended up with measurements and the like as I have to tackle coming up with a two-piece driveshaft for the ol girl.
-Wayno
64 Step Side - The Mistress |
11-20-2013, 05:07 PM | #45 | |
11-21-2013, 10:58 AM | #46 | |
Shorter motor mounts seemed to help, but I'm still messing with it. I've been busy with the LS install in my truck. I hope to be back on this by Christmas.
12-26-2013, 12:24 PM | #47 | |
///Relaxed Atmosphere |
12-26-2013, 12:50 PM | #48 | ||
12-26-2013, 01:32 PM | #49 |
Doh.. I'm a dumbass!! I read the exact post 3-4 times and overlooked the part number.. My bad and thanks!
///Relaxed Atmosphere Last edited by Rochlow; 12-26-2013 at 03:45 PM. |
12-26-2013, 03:39 PM | #50 |
Looking forward to you finished results as my extreme dropmembers front and rear should be headed my way soon and this will be an issue for me as well im sure.
