06-06-2012, 08:16 AM | #51 |
Re: '55 International Metal/Body/Paint Work
The doors didn't fit in the openings very well with uneven gaps all the way around. I learned how to use 1/8" welding rods to fill up the gaps and make them even on the blue '65 I restored.
I started by bending the 1/8" welding rod to the shape of the door/panel edge and used magnets to hold the rod flush with the edge of the panel. Once the rod was tacked in place I fully welded it on. I like to do one spot weld at a time, skipping around to limit heat build up until all of the gaps are filled in. After fully welding the seam, I ground the welds down flush with the door skin. I used a 4.5" grinder to knock down the biggest part of the weld bead, then switched to a 2" air grinder to finish off the weld. There were smaller uneven spots that 1/8" rod was too big to fit so just welded up the edge enough to close the gap. There were some spots that were too tight, so I had to grind them down and reweld the edge to make the gap larger.
Project Goldilocks '66 C10 Short Fleet BBW Build '65 C10 Highly Detailed Stock Restoration Thread '78 Camaro Targa Roof Build '55 International Metal/Body/Paint Work '66 F100 Full Rotisserie Restoration '40 Packard 120 Convertible Coupe Restoration How To Restore and Detail an Original Gauge Cluster How To Detail Sand Body Panels, Edges, Corners, Etc |
06-06-2012, 08:46 AM | #52 |
The hinges needed rebuilding so I had a local machine shop drill and ream them for oversize hinge pins. The pins weren't available oversize, so I had to hunt and find replacement pins from other cars/trucks that would fit, or atleast be workable. I found some for a Dodge truck that were too long, which was great since the driver side door had an extra long tapped stem on the bottom to mount the mirror.
Before pressing the pins out, I cleaned and stamped each half with LT, LB, RT, and RB so they wouldn't get mixed up. I stamped them where they slide in the door so I could keep the area masked off, and the bodywork/paint process wouldn't cover up the markings. The edges were pretty rough so I smoothed them, and in the after pic you can see where I added oil-impregnated bronze thrust washers to keep the hinges from wearing as quickly. The washers were also the only way I had to adust the door up and down.
06-06-2012, 12:47 PM | #53 |
Beautiful work as usual, I like your pace and varied tasks. When I saw the red fenders I thought you were done. Nice to see the welder at work again. Do use a TIG or MIG its very nice I'm thinking TIG?
06-06-2012, 09:22 PM | #54 | |
Another couple teaser shots, one as I was working on the panel alignment metalwork, and the other is after the bodywork was done and sprayed with PPG K93 tinted surfacer/sealer.
06-06-2012, 09:36 PM | #55 |
The grill panel was a nightmare, almost no part of it was straight. The center bar was pushed in and twisted right in the center emblem stamping and highly stretched, there was rust between the inner brace and outer sheetmetal, the bottom peices behind the bumper were mangled, bent, and cracked, and one of the headlight stampings was pushed in a good bit. The joys of not having replacement panels available!
Headlight/turnsignal area warped. Grill bar damage.. Bumper filler damage. Rust. Cracks, in every corner of the bumper bracked notches.
06-06-2012, 09:50 PM | #56 |
I cut the grill bar out to straighten it, there was no way all the damage was coming out if I left it in.
Once it was cut out I braced the straight side with a 1x1 steel tube and heated the crumpled area red hot with a torch and bent the bar roughly back into shape. Overall shape is alot closer, still needs fine tuning. After more time heating, bending, shrinking, and stretching it was pretty close. At this point it's only tacked in place to check how it fits in the opening. The two end points where it's spotwelded to the panel needed straightening as well. After all metalwork was done and welded back in place. That's a flexible stainless ruler on top of the grill bar in the bottom pic, I use it alot to check how even or flat a shape is.
06-06-2012, 10:08 PM | #57 |
That is some amazing bodywork... Top notch work. Good to see an old Cornbinder being saved.
- 2010 Silverado - 1984 Chevy M1028 (K-30) - 1969 Chevy C-30 - 1933 Ford Stock Car |
06-12-2012, 06:32 AM | #58 |
I don't say this much but i would let you work on my stuff anytime.
06-13-2012, 07:37 PM | #59 |
Read your whole thread as well as all of your others in the past. Love them all! What i was wondering is you used Spies SS on the blue truck and it turned out amazing. What made you jump over to the Omni on this one? And you are doing BC/CC on this one correct?
72 Chevy blue LWB, 99% original Oklahoma truck, 28,000 miles 72 Chevy SWB: http://67-72chevytrucks.com/vboard/s...d.php?t=486626 (Attempt/Mistake #2) 2003 Harley Davidson Dyna Superglide with 2007 Street Bob front end 2000 Ford F350 Powerstroke 4WD CCLB, 310,000 miles running great (STOLEN St. Patricks Day 2014 AND NEVER RECOVERED) 2002 Ford F250 Powerstroke 4WD CCLB (To replace stolen one) Hook em Horns!!! |
06-13-2012, 08:26 PM | #60 | |||
For the International, it's BC/CC- Omni base and PPG 2021 clear. I though it would be ok to use Omni since I'd be spraying over red tinted surfacer/sealer and would cover good. It sprays and lays out fine, just took a little more base than I thought it would to cover. I've sprayed PPG base on a Jeep and loved it, so I shoulda stuck with that. The Omni is decent with a color matched substrate, but I'll stick with all PPG from now on. I made the switch from Spies to PPG after spraying PPG base and 2021 clear with a matting agent on a Jeep and LOVED it. I don't have any pics of the Jeep, but the clear came out killer for a satin job- no cutting/buffing possible so you're stuck with whatever comes out of the gun. Thankfully the 2021 layed out like glass with no runs or trash, then dried to a very even satin finish. I'll take some pics of it this weekend and post them.
06-23-2012, 10:52 PM | #61 |
Been waiting for pics!! Don't hold out on us please. Itching to see more
06-24-2012, 08:44 AM | #62 |
We have a couple of shops here ones a normal garage i wouldn't let touch my lawnmower let alone my car lol.From what i have learned spend the money the first time its cheaper then doing it over again.Its just nice too see some one really do body work,I have seen enough get it close enough and just down it in filler tell its smooth.I'm not anti filler it has its place but too many use it as a fix it all when its not needed.
06-28-2012, 08:49 AM | #63 | ||
06-28-2012, 09:22 AM | #64 |
More work on the grill panel, cutting the rust out and welding in new metal.
Another spot that was rotted. Anywhere there was layered panels, I used etch primer to keep the seam protected. The passenger side bottom edge was easier to replace than fix. I cut it out and used the driver side as a template, and used the shrinker/stretcher to form the lower edge.
06-28-2012, 09:31 AM | #65 |
The corners around the bumper mount openings were cracked, so I ground out them out and welded them closed.
The lower grill panel sections were bent out of alignment, so I leveled the grill with an angle finder. And then found the angles of the lower panels and made them match from side to side. I also used the stainless ruler to make sure the panels were in line, or flush with each other. Bottom edges trued up.
06-28-2012, 09:38 AM | #66 |
More details on straightening the lower edges.
Lumpy and sunk in bottom eges. After straightening. Another crack. More rust. Metal work done and skim coated.
06-29-2012, 05:19 PM | #67 |
Nice man!!! How do u do it when you put another piece of metal on that you have to weld on? How do u prep the inside, do you use weld through primer or how do you keep the inner coating from burning off? Does that make any sense?
06-29-2012, 08:31 PM | #68 |
I love watching folks do what they want with some metal, and a welder.
Going through life's daily grind, I can feel the effects of this physical body's fleeting days, But with a young spirit I look toward a brighter day, knowing that in the eyes of eternity, I am but a babe in the arms of my Lord......... |
07-01-2012, 12:46 PM | #69 |
If I ever win the lottery, I'll keep you busy for years!!!
Nice work, John!
Check out my latest endeavor: https://roundsixpod.com My build threads: '55 Chevy: http://67-72chevytrucks.com/vboard/s...d.php?t=247512 '64 C-20: http://67-72chevytrucks.com/vboard/s...d.php?t=446527 |
07-06-2012, 08:53 PM | #70 | ||
Thanks, that sounds good to me!!
07-08-2012, 04:18 PM | #71 |
Astro I feel like you are holding out on pics of paint! I have been drooling over that red paint in those little teaser pics on the "cut and buff" thread. Now we just need some visual relief in the form of some big pictures of this truck!
07-31-2012, 03:58 PM | #72 |
I have a 49 international, im glad the body work was done when I bought it, just had to do the rest! haha I wish i knew body work...
08-14-2012, 09:31 AM | #73 | ||
Here's pics of the hood. The inner brace was bent and broken, there was large dents and creases, and a small spot of rust in the nose. Fixing the rust. Busted inner brace. Large creases and low spots on the front of the hood top. Crease at the rear edge. Good size dent and crease on the side of the hood.
Project Goldilocks '66 C10 Short Fleet BBW Build '65 C10 Highly Detailed Stock Restoration Thread '78 Camaro Targa Roof Build '55 International Metal/Body/Paint Work '66 F100 Full Rotisserie Restoration '40 Packard 120 Convertible Coupe Restoration How To Restore and Detail an Original Gauge Cluster How To Detail Sand Body Panels, Edges, Corners, Etc Last edited by theastronaut; 08-14-2012 at 09:42 AM. Reason: Added wrong pics |
08-14-2012, 09:45 AM | #74 |
Fixing the inner brace. I cut the damages spot out to repair it, then welded it back in.
Cut it through the cracked area to fix the bent edges. Straightened and welded back in.
08-14-2012, 09:48 AM | #75 |
Fixing the dent on the side of the hood.
Roughly beat back into shape. Sanded with a long block to show the high/low spots. First round of hammer/dolly work to raise/lower the high/low spots. After another round of hammer/dolly work.
