#801 |
![]() Join Date: Jul 2012
Re: My 50 roadster pickup build
I was thinking about the same. Different rpm at test compared to use?
#802 |
![]() Join Date: Mar 2011
Maybe I said this wrong, the alternator works, and shows 14-1/2 volts but only above 1500 rpm, it should show 14-1/2 volts when at idle. I've taken the alternator back to George, he has a new stator with a smaller ID for the rotor, so it should charge about 70 amps, 14-1/2 volts at 600 rpm. It should be ready tomorrow afternoon, I will install and report back the results...Jim
my build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=459839 Jimbo's long bed step build:http://67-72chevytrucks.com/vboard/s...t=464626<br /> Last edited by oldman3; 09-09-2016 at 11:27 PM. Reason: spelling |
#803 |
You are correct Doug, I'm not sure of the rpm but is higher that 600 rpm. I'll see if I can get George to tell me more about the testing...Jim
my build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=459839 Jimbo's long bed step build:http://67-72chevytrucks.com/vboard/s...t=464626<br /> Last edited by oldman3; 09-20-2016 at 07:29 PM. |
#804 |
Did some catching up
![]() Very nice gauges!! New alternator is a good upgrade! Hope it works out the way it should!
Cheers!! Kees. 1959 Chevy Fleetside Longbed My build: http://67-72chevytrucks.com/vboard/s...d.php?t=643426 Kool Guyz CC Instagram: _King_Kustom_ |
#805 |
Thanks Kees, wasn't ready today, part had not come in, hopefully Monday...Jim
my build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=459839 Jimbo's long bed step build:http://67-72chevytrucks.com/vboard/s...t=464626<br /> |
#806 |
Well, we all know about "life gets in the way", and problems it can cause. Some may be thinking "it only takes 20 mins to install and alternator, what's the problem". Well my mother passed on Monday 9/12 and I had other things to take care of, my mom was 89 yrs old (3 months from 90) was in good health up until a few days before she passed. I praise God for his special gift of my mom to me. I miss her each day, but life goes on.
So now back to my alternator. I finally got the alternator and installed it today. I also talked to George about testing. The new stator was smaller on ID to the stator and he also said I had a bad diode. There was no charge for getting it right. He showed me it was putting out 14-1/2 volts at 800 RPM, and around 75 amps. 1st pic show 650 RPM, in drive, ac off - 14-1/2 volts 2nd pic shos 650 RPM, in drive, ac ON - 13-1/2 volts 3rd pic shows 850 RPM, in drive, ac ON - 14-1/2 volts ( I just gave it a little gas to raise the RPM's) 4th pic show a close up 700 RPM, in drive, ac ON - 13-1/2 volts If this were a new car, it would raise the RPM's when the ac was on, so I'm happy with how everything turned out. This is alot better than the first change to 105 amp. One of the main reasons for wanting higher volts, is within the next month I want to install FITech fuel injection. I wanted to make sure I always had a minium of 12 volts to the system. LEEVON has beat me to the punch and is installing one on his AD with the LS engine. I will still do a installation/pic update as I do mine. Catch you later...Jim
my build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=459839 Jimbo's long bed step build:http://67-72chevytrucks.com/vboard/s...t=464626<br /> Last edited by oldman3; 09-20-2016 at 11:22 PM. |
#807 |
Jim, Sorry to hear about your Mom. I lost mine far to young.
Good Job on the Electrical Problem. Now Lets hope the Injection System is easier |
#808 |
Jim, we are really sorry to learn of your mothers passing.
The alternator looks like a good fix. You are fortunate to have someone who can still work on them. It's been years since I've rebuilt one. Fitech install will be interesting and looking forward to that. |
#809 |
Condolences Jim,
May She Rest in Paradise
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD) 53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25 55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73 62 Solidaxle Corvette Roman Red (327 340hp 4spd 3:36) C4 & C5 suspension tube chassis LS 3 4L70E 65 Corvette Coupe 327 350hp 4spd 4:11 78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42 2000 S-Type 3.0 (wife cruiser) 2003 GMC SCSB 5.3 4L60E 3:42 |
#810 | ||
#811 |
Sorry to hear about your mother, Jim, condolences.
I don't know Fitech Injection, so I'll keep an eye on it!
#812 |
Really sorry to hear about your Mom. I think it is a blessing to be in good health right till the end at that age.
Glad you got the alt fixed up.
http://67-72chevytrucks.com/vboard/s...d.php?t=648459 https://67-72chevytrucks.com/vboard/...d.php?t=769441 1951 MG TD 1967 Jeep CJ5 1.9L TDI 33X13.5X15 Mud Grapplers. 1952 GMC 9700 p/u 7.3L diesel on air, dually |
#813 |
A320 Pilot/USAF Retired
Very sorry for your loss.
JJ My 1957 build: http://67-72chevytrucks.com/vboard/s...d.php?t=334552 http://www.trifive.com/forums/showthread.php?t=22037 Instagram - Chuckdriver57 |
#814 |
![]() Join Date: Mar 2007
Sorry for your loss...Hang in there
Marc
…………...........__________ .................. ((__|__||___\____ ..;.;;.:;:;.,;..;((_(O))____ (_(O)) 1948 Chevy Truck - Finished SOLD!! 1953 Chevy Suburban "Family Truckster" Completed: Spring of 2021 http://67-72chevytrucks.com/vboard/s...d.php?t=605484 1994 4x4 Blazer - "Field Find" https://67-72chevytrucks.com/vboard/...ferrerid=30857 |
#815 | ||
Thanks JJ Thanks Marc, getting better each day, it's just part of life. Jim
#816 |
Jim
Mothers are special, sorry yours is gone! I'm down for the injection system. Keep on keepin on Nut Case
Been there, wrecked that ![]() |
#817 |
Kim |
#818 | |
Kim, thank you...Jim
#819 |
Jim, will you be running the fuel command center on your install?
#820 | |
I checked Speedway, Summit, Jegs, etc. The fuel system hook up is on back order, Jegs says 10/3 will ship. I talked to tech at FITech and he said it would be longer than that, possibly 4 weeks. I will order the unit tomorror, they will ship that day, and go on the list for the fuel system. I'm checking the net for other kits, if I can find good stuff for about the same price I will buy that...Jim
#821 |
![]() Join Date: May 2007
EFI is something you will never regret, in my admittedly dim opinion. its like going from a bugle to a symphony.
the mass of men live lives of quiet desperation if there is a problem, I can have it. new project WAYNE http://67-72chevytrucks.com/vboard/s...d.php?t=844393 |
#822 |
joedoh, I agree 100%, Mark and I have put LS engines in a few cars and it is unbeliveable how nice they are. I have been wanting to do mine for a couple years. I ordered mine today, Fitech, unit will ship tomorrow and pump lines, etc to ship on Oct 3, can't wait to get it installed....Jim
my build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=459839 Jimbo's long bed step build:http://67-72chevytrucks.com/vboard/s...t=464626<br /> Last edited by oldman3; 09-28-2016 at 11:33 PM. |
#823 |
Hey troops, you can't believe how busy I've been the last couple weeks, and this week is starting to look busy. Anyhow I received by Fitech unit on Thursday 9/29 and the unit looks great. I also cancelled by order for the fuel pump system with Fitech, would be a least 3 weeks before shipping. I ordered the LS1/LT1 system from Speedway and a couple fittings, should be here Tuesday October 4. Mark and I will pick up the rest locally, which he has done for the LS swaps.
Talk to Leevon today, very helpful with how he set his up, and I'm following suit. It still may be awhile before I can work on mine. Mark got in another job today, 78 Firebird, needs complete floor pans installed. So three cars in the shop, so I will wait my turn. Pic of unit in the box. Will post as I start changing my stuff...Jim
#824 |
Man of Mini-Talents
I'm putting FiTech in another car of mine, I'm doing the pump in the gas tank now as well. Looking forward to firing it up.
Steve Project - Ruth 66 Skylark Project - Lola 60 Biscayne Project - Iron Ox 54 GMC 100 Project - Darth 69 Camaro |
#825 |
Sounds great, let us know how it works out...Jim
