Old 01-09-2015, 11:38 PM   #76
JHT67
JHT67's Avatar
Re: 1940 Packard 120 Convertible Restoration
Amazing, crazy, and scary. When getting into something like this how do you estimate the amount of work your going to have to do? Do you even have a thought that it could be this bad? What is awesome is there is obviously no doubt you can fix it.
Going through life's daily grind, I can feel the effects of this physical body's fleeting days, But with a young spirit I look toward a brighter day, knowing that in the eyes of eternity, I am but a babe in the arms of my Lord.........
JHT67 is offline   Reply With Quote
Old 01-10-2015, 12:45 AM   #77
theastronaut
theastronaut's Avatar
I didn't know it would be this bad going in, only saw a few pictures before the car was delivered. It looked rough in the pics but I had no idea that every piece of metal around the bottom 6" would have to be replaced. Definitely no way to estimate the time involved when it's this bad, especially since the original panels are so far gone that making accurate patterns is very difficult.
theastronaut is offline   Reply With Quote
Old 01-10-2015, 08:30 AM   #78
duallyjams
duallyjams's Avatar
but you are really enjoying the challenge
James
63 GMC V6 4speed carryall
65 chevy swb bbw V8 auto
68 K20 327/4 speed, buddy buckets
2002 GMC CC Dually Duramax
64 GMC lwb 3/4 V6 4speed SOLD
66 GMC swb bbw buddy buckets SOLD
IG duallyjams
The only thing that stays the same is constant change!
duallyjams is offline   Reply With Quote
Old 01-10-2015, 11:37 AM   #79
Russell Ashley
Russell Ashley's Avatar
I don't know if he is enjoying it or not, but I am definitely enjoying seeing his work.
Russell Ashley is offline   Reply With Quote
Old 01-11-2015, 09:12 AM   #80
Advanced Design
Advanced Design's Avatar
Outstanding work! Curious, did the owner have any idea the body was in this bad of shape?
Advanced Design is offline   Reply With Quote
Old 01-12-2015, 08:49 AM   #81
theastronaut
Most days.
Thanks!!
Thanks, the owner bought it as a driver and had no idea. He started fixing minor issues and kept finding more problems.
Old 01-12-2015, 08:53 AM   #82
theastronaut
I had the floor braces sandblasted to remove the rust and started welding in the reinforcement plates and bars.
The owner had the original running boards stripped, then sent them to Hunley Acuff to vulcanize new rubber over the metal. We were very impressed with the way they turned out.
Old 01-12-2015, 09:30 PM   #83
duallyjams
duallyjams's Avatar
They must be awesome if they impressed you.
James
IG duallyjams
Old 01-12-2015, 10:18 PM   #84
MP&C
MP&C's Avatar
John, I have a set of RB for a 40 Chevy (gasser build) we need to send to them as well. Do they need the running boards in bare metal or epoxy primer or??
Robert
MP&C is offline   Reply With Quote
Old 01-13-2015, 09:06 AM   #85
theastronaut
I don't see how anyone could do any better, they're that nice.
Not sure, these are bare metal on the back side. The owner sent them so I haven't talked to the guy that did them myself. I would think epoxy would be better though to keep rust from forming under the rubber.
Old 01-13-2015, 02:07 PM   #86
Low Elco
I'm in! Great to see more of y'all's excellent work.
Low Elco is offline   Reply With Quote
Old 01-19-2015, 05:23 PM   #87
theastronaut
Thanks for following along!
Started cutting out the left rear inner wheel well rust. This was the better side,
Made a new inner flange.
Old 01-19-2015, 05:25 PM   #88
theastronaut
Started on the outer panel. I bolted the fender in place to mark the correct shape.
Outer edge folded over and shaped, then welded in.
Upper half made and welded in.
Old 01-19-2015, 06:48 PM   #89
dantimdad
dantimdad's Avatar
pics aren't there
“Life is and will ever remain an equation incapable of solution, but it contains certain known factors.” - Nikola Tesla
Matt. 6:27 "Who of you by worrying can add a single hour to his life?”
http://www.67-72chevytrucks.com/vboa...=507266&page=2
dantimdad is offline   Reply With Quote
Old 01-19-2015, 09:00 PM   #90
dantimdad
dantimdad's Avatar
Nevermind.
Old 01-23-2015, 08:08 PM   #91
Free Candy Inside
You do awesome work. Ciol you are bringing this thing back to life. I have a 52 250 I picked up a couple months ago!
Free Candy Inside is offline   Reply With Quote
Old 01-27-2015, 04:15 PM   #92
theastronaut
Thanks!! Nice looking '52!
Old 01-27-2015, 04:41 PM   #93
theastronaut
Started the front floor pans this week. The owner brought a set of pans made by Classic2Current Fabrication when he delivered the car . They would work ok for patch panels if you aren't picky but they're nowhere near close enough to use as full replacement panels. Their patterns for the beadwork was laid out wrong, plus they didn't take much time to stay on the pattern they laid out. They were also missing the recessed areas for the body mounts. After taking a closer look at them I decided to make my own instead of reworking their pans.
Transmission cover laid over the C2C floor pan. Its not even close to being useable around the trans area. There were other issues too.
The original passenger side floor pan hadn't been cut out yet so I was able to trace over the stampings to make a rough pattern.
Rough pattern transferred to translucent paper. The L/R floor pans are mirrored so I can use the same pattern for both sides.
Transferred to metal and mocked up to check the location of the body mount dimples.
Marked the area to stretch with the plannishing hammer. Pre-stretching the beaded areas keeps distortion to a minimum, especially with these 1" wide beads that want to pull a lot of metal from the sides. The bead roller doesn't have to work as hard either, there is a very noticeable difference in the amount of force needed to tighten the dies together.
After stretching the metal with the plannishing hammer. Looks like it's raised too much but the bead roller will pull the metal back into shape.
After rolling one of the beads. Some distortion but nowhere near as much compared to not pre-stretching. This was also before detailing the ends of the beads, which helps level out the panel as well.
I cut down a piece of 1" ID tubing and smoothed the edge to use as a finishing tool at the ends of the beads. The bead roller only shapes the sides of the beads; there's nothing to shape the ends. This "closes" the ends of the beads and makes them look finished, and also flattens the metal around the ends so the panel is flat.
After finishing the ends of the beads with the pipe tool. The panel is much flatter now, even across multiple beads.
Old 01-27-2015, 05:54 PM   #94
yahoos
yahoos's Avatar
Wow, Impressive as always
yeah buddy
yahoos is offline   Reply With Quote
Old 01-27-2015, 08:59 PM   #95
Advanced Design
Very nice work! I like the translucent paper idea for the mirror image.
Old 01-28-2015, 08:26 AM   #96
MP&C
MP&C's Avatar
John, maybe when you're done you can sell your pattern to C2C so they can get their stampings corrected!
Nice job on the beads. I use the e-wheel to pre-stretch and it always seems to be a guessing game as to when it's enough. What do you use as an indicator to determine the stopping point for pre-stretch?
Robert
Old 01-28-2015, 09:50 AM   #97
theastronaut
Thanks guys!
From what I've seen, they offer free floor pans (just pay shipping and handling! ) if you send them patterns for a car they don't already have patterns for. I think I'll pass on that offer...
I ususally use English wheel for pre-stretching too, and like using it better but with the extra depth of the 1" beads I didn't have tight enough bottom wheel to get the amount of stretch I wanted. So this is the first time I've tried it with the planishing hammer. I need to polish the dies and lower the air pressure to get a smoother finish before doing any beads that would show. The floors will be shot with Raptor Liner so these were ok like they are.
I did a test panel to get an idea of how much to pre-stretch, eyeballing how much of a "bump" I was making compared to the size of a finished bead. Flattening the ends of the beads with the pipe tool seems to change how you pre-stretch the ends of the beads too, you don't need to stretch as far out in the corners of the pattern.
Old 01-28-2015, 10:20 AM   #98
MP&C
MP&C's Avatar
I think the process of forming the beads does more pulling in from the sides than from the ends. Thanks for the insight, always good to get another's perspective to see what I'm doing wrong..
Robert
Old 02-19-2015, 12:49 PM   #99
theastronaut
Finished up most of the work on the front 2/3 floor pans. Still need to make the rear floors and pans under the rear seat.
Made patterns for the other floor sections. I only had the pictures we took of the car in Dillard GA to go by.
Battery door cut out.
Been slack at taking progress pics, so I only have the finished pan.
The original battery cover door was missing it's retaining tab so I made a new one and welded it on.
Old 02-19-2015, 01:04 PM   #100
theastronaut
Front passenger side pan. This side had an extra cut out for a small transmission inspection cover.
I didn't show the body mount area on the drivers side pan earlier. Made it the same way, pre-stretched then used the bead roller. I used a 5/8" round bead to make the straight lines and the 1/4" offset dies. I spaced one of the offset dies out to match the rounder 5/8 bead.
Distortion from pre-stretching.
Both pans finished, ready for final trimming and fitting.
Compared with the C2C pans.
