Old 06-09-2012, 03:24 PM   #976
Dinos63
chevy only
Dinos63's Avatar
Re: Shrunken66Stroker's build thread.
those mounts are trick !! always always such nice work
CHEVY ONLY... Nothin Else !
Dinos63 is offline   Reply With Quote
Old 06-10-2012, 11:59 AM   #977
shrunken66stroker
shrunken66stroker's Avatar
Thanks Dino. They came out nice but I seriously worked on them for almost two days. I'm slooooowww at this stuff.
shrunken66stroker is offline   Reply With Quote
Old 06-10-2012, 12:10 PM   #978
chad64chevy
chad64chevy's Avatar
the truck is looking good! when you leave for vacation??
chad64chevy is offline   Reply With Quote
Old 06-10-2012, 03:09 PM   #979
shrunken66stroker
Thanks. Mentally I'm already there.
Old 06-10-2012, 06:54 PM   #980
R.A.D
i thought you were...........
R.A.D is offline   Reply With Quote
Old 06-11-2012, 12:10 AM   #981
daverod
SSN 706
daverod's Avatar
Did you leave yet? It's all clear lets jack this thread. Have fun on vaca.
daverod is offline   Reply With Quote
Old 06-11-2012, 09:56 AM   #982
Strodder
Daring to be Different
Strodder's Avatar
Hijack???????? How shocking would that be?
Dennis
Check out my 65/73 Cheap Build Thread.
http://www.67-72chevytrucks.com/vboa...d.php?t=327644
KUSTOM RIDES
FACE BOOK PAGE:
https://www.facebook.com/groups/291198124258863/
1965 C-10 Short Bed 350/700r4
2012 Silverado 1500 Crew Cab
2016 Honda Accord w/ 18" rims
2007 Honda Goldwing Trike w/ NAVI
2001 Yamaha Roadstar Indian look alike
"Life's journey is not to arrive at the grave safely
in a well preserved body, but rather to skid in sideways,
totally worn out, shouting "...WOW!...what an amazing ride!"
Live Life Passionately!!!
[/COLOR]
I AM WE TODD IT, I AM SOFA KING WE TODD IT
Strodder is offline   Reply With Quote
Old 06-11-2012, 08:02 PM   #983
R.A.D
Old 10-01-2012, 12:59 PM   #984
theastronaut
theastronaut's Avatar
Shrunken, I'm going to be using an LS2 and No Limit's R&P on my '66. Do you think there would be any interference issues with notching the crossmember to drop the engine/trans lower?
From this pic it looks like there's room for maybe a couple inches? I imagine that it would be tough fitting headers around the frame rails if it was dropped any more. Thanks in advance.
theastronaut is offline   Reply With Quote
Old 10-01-2012, 01:06 PM   #985
wutnxt
Location: vancouver b.c....is the biggest place most people would know but I am actually out in the valley 45 mins away
Dude...
As always great work....one of the best 64-66 threads there is....you have great vision
1966 Pro street build http://67-72chevytrucks.com/vboard/s...?t=448089[
1958 LS 2 build http://67-72chevytrucks.com/vboard/s...d.php?t=527123
1966 SBFS low and go http://67-72chevytrucks.com/vboard/s....php?p=5799909
1966 SBFS street HULK http://67-72chevytrucks.com/vboard/s...=1#post5886625
Poject Low and go gets a 6.2 ltr LSA supercharged with 6 speed automatic
Aluinum Radiator Dealer pm for details
wutnxt is offline   Reply With Quote
Old 10-01-2012, 01:12 PM   #986
hotrod1
56 - autocross
hotrod1's Avatar
move the engine back to get away from the cross member and get a different pan. Better weight distribution and center of gravity. You will need to deal with your firewall though.
Autokraft has a nice pan for an LS. http://www.autokraft.org/products/
hotrod1 is offline   Reply With Quote
Old 10-01-2012, 08:08 PM   #987
chad64chevy
wow its been almost 4 months since we got an update, he must be busy taking pictures or forgot about us!!!
Old 10-01-2012, 11:43 PM   #988
McMurphy
McMurphy's Avatar
Probably just now cooling off in Nevada enough so he can touch it. Last time we saw it, it was all brushed steel yes?
Michael McMurphy
My 66 Stepside
My 64 Tow Truck
My 66 Tempest
Table Of Contents Added to Page1
McMurphy is offline   Reply With Quote
Old 10-06-2012, 07:14 PM   #989
R.A.D
damn i hope everything is alright!!!!!!!!!!!!!
Old 10-09-2012, 12:30 AM   #990
shrunken66stroker
Astronaut, the problems I see with lowering the engine might be prohibitive. Ultimately it's up to you but here goes. You'll have to custom fab the engine mounts and headers or cut the frame rail to squeeze headers in. You will have to get a shallower pan than the "muscle car swap" pan I have, which is about flush with the bottom of the crossmember. The f-body pan should work. I don't have the accessory drive yet, so that's a variable that I can't give you any insight on.
Notching the cross member won't be a problem, you just need to leave enough room to get to the nuts to tighten the rack mounting plate inside the crossmember. You might have to reroute the brake lines that run along the rear of the crossmember. Also, address the usuals stuff like drive shaft angle, length and shifter location. A couple inches probably won't affect flow between the block and radiator, right?
And after all of that, when you're done the engine compartment might look half empty. I don't know if it's worth the trouble, honestly. You're already taking a ton of weight off the front end with aluminum block, heads and no boat anchor steering box. Are you planning on racing autocross with it? If you are, go for it. If it's a street truck then I wouldn't bother with an inch or two either way. I hope this ramble helps. Good luck!
Originally Posted by wutnxt View Post
Dude...
Thanks!
Yes, good advice. If you move it back more than two inches the fire wall will need to be addressed.
I've been lurking a little and definitely didn't forget. I haven't gotten much done over the summer because I've been busy with work and family. Business is getting better... Finally!
And it still is!
All good, just trying to pay some bills. Thanks, guys.
Old 10-09-2012, 12:15 PM   #991
ERASER5
ERASER5's Avatar
Paying bils! Are you maskerading as a responsible adult or something?
'70 GMC C1500 LWB
Power disc brakes. WooHoo!
Posi 6 Lug Dana 60
ERASER5 is offline   Reply With Quote
Old 10-09-2012, 12:28 PM   #992
montoya22
montoya22's Avatar
cant wait to see it when its done.. what kinda wire are you welding with?? i been doing some welding with my flux but it seem to be burning the metal .. any advice would help.. thank and keep working hard
montoya22 is offline   Reply With Quote
Old 10-09-2012, 01:05 PM   #993
61 son of a Gun
61 son of a Gun's Avatar
GREAT build !
Hey, how exactly is a rainbow made?
How exactly does the sun set?
How exactly does the posi-trac
rear end on a Plymouth work?
It just does.
61 son of a Gun is offline   Reply With Quote
Old 10-09-2012, 03:06 PM   #994
theastronaut
Glad to see that all is well with you, and thanks for the detailed reply! It'll be a street truck that will occasionally see autocross action. Most of the things you listed will be things I'll be doing anyways (my own engine mounts and brake lines, move shifter forward, aftermarket baffled oil pan) so it may not be that much more work other than the headers and chopping the crossmember. I'd like to keep the stock low hump floor if possible so dropping the engine would help gain clearance for the T56. Rob at No Limit posted that guys do extra work to lower the engine even fractions of an inch when possible for track cars so 1-2 inches should be worth the extra work.
This is definitely one of my favorite build threads, can't wait to see what's next with it!
Old 10-09-2012, 11:46 PM   #995
shrunken66stroker
No problem! After 5 years it's hard to know when to draw the line and move on in the name of driving it again some day, hopefully soon. I'm just a weekend warrior and I've used this project to teach myself everything about the rebuild process. When it's finished I will have done 100% of the work, so I want it to be dialed in. That said, I'm done moving the engine around and need to move forward. I need to get the accessory drive, radiator and some other misc. parts and get back to it. I'll post any progress I make and follow yours as well.
Old 02-22-2013, 07:44 PM   #996
daverod
SSN 706
daverod's Avatar
We really do need a update....
Old 02-22-2013, 09:48 PM   #997
R.A.D
i second that
Old 03-22-2013, 09:40 AM   #998
bubbalou65
bubbalou65's Avatar
Been looking thru the thread. Everything is looking great. I just saw that you pulled the front fender back 2in. I am doing the same thing just never saw anyone do it. Always thought that front needed to come back. I havn't done mine yet so now I have a visual. Thanks. Also what are the tire sizes on the front. I know they are 17's but I like the side wall height on yours and im getting my wheels next week. Thanks for all the info with this build.
bubbalou65 is offline   Reply With Quote
Old 03-22-2013, 10:53 AM   #999
bubbalou65
bubbalou65's Avatar
Thanks Jason. Good to see you back.
Thanks French. Go Ducks!
Thanks Dino!
A little trip the the ER with an ulcer has been keeping me down recently. I'm felt good enough to roll it out and take some picks today before I cleaned the garage.
love the grill. I am using the same one on mine. It was a freebie ta boot. looks great.
Old 03-25-2013, 01:17 PM   #1000
shrunken66stroker
Argh. Been too busy to work on it, but the weather's nice and I'm going to get back out there soon. My wife bought me a small hydraulic lift for Christmas and I haven't even gotten a chance to use it yet.
i second that
It will be back on the front burner soon. I promise.
Thanks, Bubba. Yes, 17x8 and the tires are 235/55/17 Toyo Proxes.
There will be updates sooooon..I hope.
1966, bagged, disc, long to short, stroker
