#1001 |
Re: What did you do to your truck today!
Had a buddy come over and we welded the exhaust back up right after the camaro tank install. Good to go now. Shot some more paint on the bed sides this morning. One more touch up spaying and I will start cutting the wood down and fitting it in the bed.
67 C10 Stepside 66 Mustang Coupe 99 Burb 2500 |
#1002 |
Put new valve cover gaskets on to stop major oil leak, changed oil, couldn't get filter off though. Also replaced broken turn signal arm.
#1003 |
![]() Join Date: Jul 2010
SQUAT........ I'm just waiting for Clifford Performance four barrel intake and dual shorty headers for my 250 inline 6. Man waiting sucks
#1004 |
Started tearing stuff out of the interior of the 71 Blazer I picked up. Removed rear seat and took out home made side panels and carpeting. Carpeting was glued down. Anyone know of a solvent that will aid in the removal of carpet adhesive. Paint thinner (mineral spirits) doesn't really do much.
1961 C1 Corvette 1959 El Camino 350 TPI, 9" 4 w disc 69 Blazer K5 - sold July '20 2021 Durango RT 5.7 |
#1005 |
I painted my hood, drivers side front fender, and driver side door. I have been painting my truck for neary the last month. More of less piece by piece. I am in a rush to finish the exterior befor it gets to cold outside.
Keith |
#1006 |
drove the wifey to lunch and put about 75 miles on it (in the rain) ran great good times! cheers, Pat
#1007 |
Got my bed back on int time for winter. Painted the inside of the doors and got them rehung today. Trying to get things ready for winter so I can work on the bed body work and or the motor.
A USED TRUCK IS A LOVED TRUCK! |
#1008 |
yes, i do
Ordered a gasket set and ez efi multi port retro fit kit for my 72. I actually ordered those last week when i found the kit in an ebay auction for $699. i can't wait to get the brake conversio done on the mrs's 72 maliu so my 72 can go in the garage for some work next
ERROR 404....... SNAPPY COMEBACK NOT FOUND ![]() _______________________________________________________________________________________________ -60 Chevy C10, dead 350/good th350 combo, sitting on a 76 c10 blazer frame, built from 11 different vehicles "the abomination" -07 gmt900 silverado 1500 lt xcab z71, granite blue -81 suzuki gs650g "shelah"- current project -81 kz1000m1 csr "sarge" -next project (just beautification) -07 kawasaki vulcan classic vn900 |
#1009 |
Collector of Projects
Swapped in a Red-Head steering box. Rebuilt the rag joint. Pulled the PS pump and ordered a new one alond with what I hope is the correct high pressure line....
I also unbolted the body mounts so I can install the new poly kit and 1" ORD body lift.... ![]() Last edited by mcmlxix; 10-25-2010 at 12:44 AM. |
#1010 |
4" rear drop...woo hoo!! 2" front is ready to go in as soon as the front rebuild kit arrives from CPP.
And also, a trip to the car wash ![]()
Derek 72 Chevy Cheyenne Super LWB 454 SS LS6 90 GMC Suburban V2500 350 ----------- 64 Chevy El Camino 357 73 Jeep Wagoneer 360 78 Jeep Cherokee 360 79 Scout II 345 88 Jeep Wrangler 4.2L 91 Jeep Wrangler 4.3L 98 Lincoln Mark VIII 4.6L 01 GMC Yukon 5.3L "If it's not broken, fix it 'till it is!" |
#1011 |
Junior Member
Finally found a little time between other projects to work on the '71. I re-routed the wire to the temperature sending unit wire away from the headers.
Mounted the remote solenoid and figured out how to run the new wires. While re-routing the temperature sending unit wire I noticed that the wire to the Hei distributor was spliced to the yellow wire. It has been running ok that way, but I decided to run a new heavier duty wire to the distributor from the ignition unfused connection in the fuse block with a in-line fuse.
'67 Chevy C-20 short stepper - build complete, 454/SM-465. '75 C-30 Single Cab DRW-350 small block/NP-435. '77 GMC-6500 Dump Truck, 427 Tall Deck. '92 GMC K-3500 Duallie, 454/4L80E. |
#1012 |
Redefining LowBudget
relized that with Cupped LCA, 2 1/2" drop spindles, and a dropped X member not only would I have to get rid of my A/C and heat but the tire would be rubbing on the hood and firewall....Dam why can't it be easy to be cheap
1970 C10 CST fleetside 472 ....big dreams little cash... SunShine Syndicate.. ![]() Mikes Sandwich Fair Run OCT 8th 2011
#1013 |
![]() Join Date: Oct 2010
Gettin ready to go back out and wire wheel the wheel wells and core support for paint!
Just got done cleaning up threads on all the bolts. Also, gave my water pump to my motor builder. I need to get this front end ready for my 327! Pronto! |
#1014 |
White wall terror
I just got done replacing my LMCrap wiper switch that was in the truck for maybe 6 months with a 40 year old GM switch that still works.
#1015 | |
![]() Join Date: Feb 2008
On Sunday - did a temporary work around for a bad wire somewhere in the heater harness. Ran a fused line from the fuse box to a toggle switch at the cig lighter location & then on to the motor. On or Off at full speed is better than NOTHING. It's been a little chilly here some mornings & foggy windows are hazardous to drive with. ![]()
Bryan '52 Bel Air 2dr HT - in pieces '68 C10 - 6cyl/4spd REMOVED, LT1/T56 to be installed “Any society that would give up a little liberty to gain a little security will deserve neither and lose both.” - Benjamin Franklin "And those who know what's best for us, Must rise and save us from ourselves" - RUSH lyric (mockery) Last edited by 68C10HotRod; 10-25-2010 at 07:50 PM. Reason: added heater line |
#1016 |
![]() Join Date: Feb 2003
installed trim,headliner bumper,wireing, built doors.........
1971 K5 CST Blazer 1965 Chevelle Malibu 283 (sadly sold) 1968 Camaro 327 1968 Honda mini-trail z50a #377 1966 uh 1-D Huey |
#1017 |
few more
#1018 |
I welded up my firewall and fuel inlet on my cab.. I ordered everything from Infanti machine http://www.infantimachine.com/products.htm. fit perfect. The gas filler hole was rolled perfect... It would have been cheaper to buy a sheet of metal but saved me a day of labor ($80.00 total with shipping). Highly recommend.
Mark 1972 C10 SWB LS1/T56 6 speed trans/4:56 posi with 5.5"-7" static drop/Boss 338 Wheels 18"x20" My build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=424609. My first start up http://youtu.be/R899YQ1OcjU |
#1019 |
I installed the power steering pump and new hoses.... filled and bled the pump and box.... its still on jack stands because I had to go to work ...
And the Red Head .... ![]() Last edited by mcmlxix; 10-31-2010 at 06:28 AM. Reason: added pic because everyone loves pics |
#1020 |
Nothing except get a drill and tap together to install a ground line off my fuel cell to the frame, need a good ground hole on the frame.
Mike. Swamp Rat build thread : http://67-72chevytrucks.com/vboard/s...d.php?t=595019 72 3/4T 4X4 4" BDS Lift 33" BFG's |
#1021 |
RAT1968 '68 Cab/'71 Parts
My wife picked up our new one-piece drive line ($272 all rebuilt w/new yoke...I expected about $150, but I'm living in the past, I guess.).
Bolted up the new brake set up to the pedal (now the only thing left in the cab). Guess what, the '68 (the cab I'm using) pedal assy has the part that accepts the brake rod that goes through the fire wall about 3/8" shorter than the brake set-up I got. Luckily, they sent that part attached to the threaded rod, so I used it. Just one more "'68 ain't a '71" surprise. Same with the carb linkage. I have to use the '68 on the cab and make a rod to attach to the Edelbrock 600 cfm. I'm going to use a '68 rod that LMC says is for a six cyl. Stuffed one of my three steering columns thru the hole in the firewall and came home. Tomorrow's another day.
M17 Coarsegold, CA RAT's shiny now. But always a rat. Last edited by magwakeenercew2jh; 10-26-2010 at 10:56 PM. |
#1022 |
![]() Join Date: Apr 2005
Finished installing my new disc brake system on the 68 S/C truck, 13" fronts, 12' rears, all new lines and a CPP aluminum mastercylinder with built in proportioning valve. I also, installed a B&M line lock for good measure,
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 Last edited by Hart_Rod; 10-26-2010 at 11:20 PM. |
#1023 |
PROJECT 7DEUCE
![]() Join Date: Dec 2002
I got these in the mail froma good friend today for the blazer now just have to find time to install them..
GO BIG GREEN ![]() MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
#1024 |
I installed a new rear view mirror in my passenger door, the door never had one so I had to measure the drivers mirror about twenty times before I was happy enough to drill holes in my new paint! The new mirror is beautiful compared to the old one on the drivers side, now I have to replace that one! While I had the door panel off I installed a bunch of 1/2" thick rubber sheeting on the inside of the doors, what a big difference in the way the door sounds now! Sounds very solid when you close the door and driving is a lot quieter!
Posted via Mobile Device Posted via Mobile Device |
#1025 |
Installed a new master cylinder and power booster and discarded my 41 year old master cylinder. I am excited I don't have to use all the muscle in my legs to stop my truck like Fred Flitsone did.
