Old 02-28-2013, 08:12 PM   #101
1985-GMC
Chevy Enthusiast
1985-GMC's Avatar
Re: The Dakota Cadillac (68 K20 w/ Cummins)
Oh ok those are the new style.
Tony
1985 GMC K2500 restoration Project: Rust, White & Blue
1989 Chevy R3500 CC Cummins & 4X4 swap some day...
1989 Burb (D60, 14BFF, 12V, NV4500, NP205, 37" tires in progress)
1985-GMC is offline   Reply With Quote
Old 02-28-2013, 10:57 PM   #102
jbclassix
Junk Yartist
jbclassix's Avatar
Do you have any tire rub issues with the front right tire on the down pipe with the exhaust run out the frame like that? I have been contemplating that route.
-Jeremy
YOU ONLY FAIL IF YOU STOP TRYING
70 Crew Cab Build Link
70 GMC Suburban 4X4 build thread
95 Yukon Daily Driver
Rebuilding an NP205
jbclassix is offline   Reply With Quote
Old 03-11-2013, 11:38 PM   #103
lowrollin70gmc
Too many projects
lowrollin70gmc's Avatar
I haven't had any problems, but my front end is very stiff and doesn't like to flex too much. I'll see how it works out but I'm more worried about rust from wheel spray than smashing the pipe with the tire. Also, the pipe is very close to the firewall plate and heater hoses from Vintage Air, so I used exhaust wrap for the downpipe within the engine bay.
It might be changing eventually as I want to run an exhaust brake and there is no room behind the turbo for my spare PacBrake. The turbo needs to move forward and I'm thinking up, possibly an industrial manifold flipped? We'll see what happens but that is down the road.
Andrew
84 GMC C1500 SWB 6.2 Diesel/700R4/3.42 "Grandpa's odd duck"
70 GMC C1500 LWB My first truck: shaved, bagged, and more: the lowrollin70gmc
68 K20 Suburban 12V Cummins/NV5600/NP205/D60/11.5AAM 3.73s "Dakota Cadillac"
63 Chevy II Nova Coupe 250 I6/T56/4.56s "Economy car"
53 Willys Wagon 350/NV4500/BW4401/HP D44/9inch “Winter Wagon”
30 Model A 16 Focus ST
lowrollin70gmc is offline   Reply With Quote
Old 03-12-2013, 07:55 AM   #104
RatRod68
RatRod68's Avatar
get the console in yet?
build Threads:
Nasty 68 C10. My lil hotrod
Leftovers 68 C20
D-Ranged Ford Ranger on steroids
Semper Fi
RatRod68 is offline   Reply With Quote
Old 03-18-2013, 08:02 AM   #105
lowrollin70gmc
Too many projects
I haven't bolted it down yet, but today may be that day as work just got canceled for a snow storm. I'm already up and have a lunched packed so I might just head out to the garage and take advantage of the time off.
Andrew
Old 09-16-2013, 10:39 PM   #106
67chevy2wd
67chevy2wd's Avatar
Any updates? And nice to see another ND member.
07 Chevy classic LBZ Duramax (a few mods)
'67 Chevy 1/2 ton 2wd (in pieces)
'69 Chevy 1/2 ton 2wd (on hold)
'71 GMC 3/4 ton 4x4
‘71 GMC 1/2 ton 2wd suburban
67chevy2wd is offline   Reply With Quote
Old 09-16-2013, 11:54 PM   #107
lowrollin70gmc
Too many projects
I've mainly been driving it as it gets the best mileage of my vehicles. I traveled for a few months for work and it pulled the 120 mile drive each way like a champ. A few fuel filter issues have popped up but that is due to the tank lining not sticking so once the tank is low this time I'm pulling it and cleaning her out.
Oh, and I swapped rear springs and shackles for about an inch more lift.That and a little trimming allowed my 37's to clear and flex. I can feel less power from reduced gearing and heavier wheels/tires but it still has plenty of grunt.
Oh, and I parted out a 91 C2500 that has donated it's cable operated hood latch to remove the need for the ratchet strap. After two years maybe it's time.
Andrew
Old 09-20-2013, 08:04 PM   #108
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
Lookin good man!
Ryan
1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread
1972 GMC Sierra Grande Longhorn 4x4
1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed
1972 C10 Suburban Custom Deluxe
1969 Chevy milk truck
1971 Camaro RS 5.3 BTR STG3 Cam Super T10
1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project
Tired of spark plugs? Check this out.
Dieselwrencher is offline   Reply With Quote
Old 05-15-2014, 06:46 PM   #109
OSM 70 C20
OSM 70 C20's Avatar
I think we passed on 25th a few minutes ago
"I taste Rust"
I wish I had the money my truck thinks I do
I taste "Patina"
OSM 70 C20 is offline   Reply With Quote
Old 05-15-2014, 11:24 PM   #110
lowrollin70gmc
Too many projects
We definitely did, I just got home from work in this guy, I put it back into service as my daily driver.
I need to put some updates on this thread, I've done a few little things over the winter (not as many as I wanted to) to include a new fuel tank, sending unit, filter mount, and a few other shenanigans. I'm quickly finding out having a few project cars/trucks and an old house and garage to work on eats up a lot of time. But I have a month break between classes, so hopefully I can get some sound deadener inside this rig as I don't think a radio would be much use right now.
Andrew
Old 05-18-2014, 08:28 PM   #111
shopteacher
Looking real nice! Just read the thread and I'm Subscribed !
There is lots of sheet metal in side the cab so some dyna mat or Fat mat will make a great improvement !
Keep us posted
shopteacher is offline   Reply With Quote
Old 08-30-2014, 08:32 AM   #112
Hart_Rod
Hart_Rod's Avatar
bump
Hart_Rod is offline   Reply With Quote
Old 10-05-2014, 11:46 PM   #113
lowrollin70gmc
Too many projects
Keep us posted
This man speaks the truth! While this update is a little overdue, I did finally put some basic insulation and carpet in this old guy. What a difference it has made! I've spent the last two years content knowing that my tin box was loud and obnoxious to drive, I've even driven 500 mile roadtrips (with no radio) without being able to think over the noise.
I can hear my phone ring while driving in town now! I can't answer it because my hands are busy driving, but I now know that it rang.
That insulation and carpet was done partway (stopped at my parent's house 250 miles away) through a 1500 mile weekend to attend Kool Deadwood nights with my family. This included laying down a 12 second pass at the dragstrip.
Okay, it was an 1/8 mile strip and it had wheel hop like none other but it was fun slamming the gears, I'll post up a video when I get time later this week.
Anyways, other than loosing a power steering return line at greater than highway speeds (>75mph limit) and borrowing a few quarts of power steering fluid from a nice gentleman in Christine, ND it's been running flawlessly. I finally turned up the pump and will be ordering injectors, a fuel pin, and new lift pump (I loose fuel pressure at extended full throttle) at some point this winter.
Winter projects for this guy:
-- Pull front clip to ease access to everything
-- Reseal motor, I'm leaking like crazy and I believe it's from the vacuum pump/timing case gaskets. This will be replaced with a plate to mount the power steering directly to the case.
--Rebuild front crossmember to accommodate a winch
----Hickey sidewinder I picked up last year
----Mile Marker hydraulic/powersteering (bought for car hauler, but not sure if I want to buy a hydraulic pump for my 62 IH's PTO.
-- Modify/fabricate a new exhaust manifold to move the turbo forward/up and mount exhaust brake.
-- Build new turbo/intercooler/intake plumbing
-- Mount / plumb larger air filter
-- Build an A/C compressor mount and reroute belt to make it work.
-- Clean and paint firewall
-- Clean and repaint motor : going back to Cummins industrial tan to better match future gold (original color) repaint
-- It will also be getting a wood headliner (thinking 3/4 or 1" strips, like a hand made canoe). I like dealing in metal, not so great with wood so a lot of help will come from my woodworking Dad, only problem is the 250 miles apart that we live. Maybe a long weekend at his place, so maybe not this winter but eventually.
Sorry for the long update, I'm loaded with work/school/house projects and can't seem sit down to write shorter posts more often.
Pics/video of drag run to come soon...
Andrew
Old 10-06-2014, 01:09 AM   #114
jbclassix
Junk Yartist
jbclassix's Avatar
right on man! looking forward to the progress!
-Jeremy
Rebuilding an NP205
Old 10-07-2014, 06:11 PM   #115
Dieselwrencher
Sounds like you can be relieved from the noise now. It's crazy how bad bread trucks and suburbans magnify the drown these things put off. It sounds like you have a good mod list going there.
Ryan
Old 05-22-2018, 05:20 PM   #116
Travisarmenta
Travisarmenta's Avatar
Originally Posted by lowrollin70gmc View Post
Pics of truck before the swap
The harley, burb, chevy ii, and donor dodge all in one place last year!
Love it.
Semper Fi Bro
Travisarmenta is offline   Reply With Quote
Old 07-11-2018, 01:55 PM   #117
1972K20
1972K20's Avatar
Nice Suburban!
I like the Cummins. Any pics of the engine mounts or cross-member?
Also, did you pull the engine, trans and t-case out together with the cherry picker in the earlier photo?
1972K20 is offline   Reply With Quote
Old 07-12-2018, 09:55 PM   #118
lowrollin70gmc
Too many projects
Originally Posted by Travisarmenta View Post
Love it.
Semper Fi Bro
Semper Fi, I haven’t looked at those pictures in years. Lots of memories in those old barracks.
Originally Posted by 1972K20 View Post
Nice Suburban!
Thanks, it’s a fun truck and it hasn’t given me too much trouble in the years since building it. Just lots of driving and pulling trailers. I’ll grab some better pictures of the crossmember tomorrow, it’ll be dark when I drive it home tonight.
I pulled the entire engine/trans/case out of the Dodge as a single unit through the former grill opening on that trusty cherry picker. Then, I removed the 5 speed and NP205, did some painting, resurfaced the flywheel, put in a new clutch, and hung the NV5600 and Dodge NP205 off it. The entire assembly was put into the Burb (minus front clip) as a single unit with the same engine hoist, set at the final position, tacked up the mounts in place, unbolted the mounts for final welding and paint, then bolted back in.
I find that is the easiest path, as there’s no wrestling a heavy transmission into place and no guessing at measurements. The engine only went in once, and if I ever have to pull it, the entire assembly will come back out the same way.
Andrew
Old 07-18-2018, 12:10 AM   #119
lowrollin70gmc
Too many projects
Ok, so tomorrow turned into a few days, but here are pictures of the motor mounts.
The engine side is stock 1991 Dodge W250 brackets and rubber engine mount. It is then attached to a plate and 2 parallel pieces of 1”x2”x3/16” tubing. A piece of angle iron (I think 3”x3”x1/4”) is bolted into the frame and the 1x2s are welded to it. I also designed the center section to be removable (the engine would have to be on a cherry picker for support, but it can be removed) for access to remove the oil pan if needed.
The trans mount is a piece of 6” channel on its back, with 2 poly bushings and tabs to a 2”x2”x1/4” tubing. This crossmember is the lowest part of my frame and even with the bottom of the clocked up NP205. This will also support a transfer case skid plate when I get around to it.
Andrew
