#151 |
Restoration Virgin!
Re: Project: Mistress
Okay...finally installed the VC and air cleaner cover....what do ya think?...
I installed perma-dry plus gaskets and reused the T-bars hold downs (which I DON'T like)...I'll be changing those out....But noticed there was oil leaks on the passenger side about half way back along the outside...I don't want to reuse the spreader bars, but how can I get it to seat better??
Geoff with a G 1968 Chevy C10 SWB The Mistress 1972 Custom Deluxe C20 Suburban A Suburban Named Isabella 1966 Ford Mustang Mama's High School Graduation Present |
#152 |
VA72C10
![]() Join Date: Mar 2008
Looks good in there. Other than the spreader bars, I'm not sure...maybe someone else will chime in.
Looking for a 67-72 swb or blazer project in or around VA. ![]() |
#153 | |
![]() Join Date: Apr 2005
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
#154 |
Looks good!
#155 |
Restoration Virgin!
So I finally worked on the Mistress a little more this weekend....needed to install the radio and kick panel speakers...It was a pretty easy install once I found a good ground....next I finally got lighting to the gauges in the center panel and hooked up the voltmeter.....then I finally decided to get the fuel gauge working...I had wired it wrong (it took me 2 nights to figure it out, but I got it resolved).....and since I had the bench seat out, I went ahead and installed my original lap belts that were in the truck when I bought it (gonna install 3 pt belts soon so these are temporary)....also, finally got the engine bay cleaned up by installing stainless steel bolts as hold downs on the valve covers (removed the T-bars).....here's a looky at my progress....
#156 |
gcburdic,
WOW! Love that Color! The color really pops out at you! So how does the exhaust sound on the road? THanks MrBlue |
#157 | |
Restoration Virgin!
exhausts sounds like....wah, chirp, wahhhhh, chirp, wahhhhhhhhhhhhhhhhhhhhhhh (only a TH400) ![]() just kidding.....still sounds good to me, but will take it out back at some point.....just sounds too good to me right now!!! When I first drove it home (took about an hour), it was cold out and I rode home with the windows up.....When I got out it was like I had the bass in the stereo up full blast for the last hour... ![]() Thanks for looking!!! ![]()
#158 |
sweet truck man. i may have to swing one exit over and check it out sometime. i keep seeing all these awesome colors and cant seem to decide what color i want mine. i guess i should stay away from this color since we'll be running in the same town(s)
![]() 69 burb/01 yukon chassis 65 Comet Caliente 289 4 Door Sedan 99 Millenia S (supercharged) 4 Door Sedan 02 Yamaha R6 69 swb c10 http://67-72chevytrucks.com/vboard/s...36#post3799136 building with a buddy: 85 C10 http://67-72chevytrucks.com/vboard/s...94#post3708194 |
#159 |
Under Construction
looking good Geoff!
Heath subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php http://67-72chevytrucks.com/vboard/s...d.php?t=157669 FAQ how to's 1956 Chevy Apache 1967 C10 SWB FleetSide (under construction) 1969 K10 SWB FleetSide (Future Build) 1972 C10 SWB Stepside (Future Build) 56 chevy truck : http://www.cardomain.com/ride/2955823/1 67 truck build: http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1 69 k10: http://67-72chevytrucks.com/vboard/s...d.php?t=389470 |
#160 |
Restoration Virgin!
#161 |
lookin good brother!
#162 | |
Restoration Virgin!
![]() Thanks brother!!!
#163 | |
Tot Roddin'
![]() Still lovin' the project Geoff!
-Nate ![]() 1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6) 1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior) 2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package) |
#164 |
Under Construction
Geoof, how did you go about painting the VC's, and breather. I have contemplated touching up my son's, but alot of masking.....
#165 | |
Restoration Virgin!
It was actually super easy.....I actually taped up the 1st cover and sprayed it with some high temp semi-gloss (I didn't waste my time taping the second one or the Air cleaner cover)....I waited about 5 minutes, then put some minerial spirits or paint thinner on a rag and wiped off the finned/ raised and over sprayed areas.....then wiped it down real good with a wet cloth.....be sure to use cloth that won't leave lint like I did originally!!.....hope this helps and let me know if you need anymore info!!
#166 |
Under Construction
cool, i was thinking along those lines, thanks for the info.
#167 |
#168 |
Restoration Virgin!
Stopped by this cool car wash in Cooleemee, NC on my way home from a car show this weekend in Winston-Salem.....I never really recognize the rake on the Mistress unless I take pics of her!!!
#169 |
Under Construction
lookin good....
#170 |
I love the way your truck turned out it is fricken awesome.
Right now my Dad and I are in the process of fixing up my truck its a 89 GMC Sierra c1500 short box. We decided to paint it a tangerine color that looks similar to the color on your truck and after seeing how great it turned out on your truck it puts my mind at ease. I love the way your truck turned out its just awesome haha |
#171 |
sweet truck, man! Enjoyed your thread. Something tells me that mine can take longer than anticipated.
'67 Impala '69 Chevy 350 C-10 shortstep |
#172 | ||
Restoration Virgin!
Thanks Heath!
![]() Here's the Mistress at the Lake!!!....Took this with my camera phone...turned out pretty good! ![]()
Geoff with a G 1968 Chevy C10 SWB The Mistress 1972 Custom Deluxe C20 Suburban A Suburban Named Isabella 1966 Ford Mustang Mama's High School Graduation Present Last edited by gcburdic; 08-16-2009 at 07:37 PM. |
#173 |
VA72C10
That's a sweet camera phone picture
#174 |
Under Construction
Ah.... aint nothing like being alone with your mistress at the lake!!
#175 |
Just an FYI I have a 72 c10 long bed, your truck has been officially selected for my inspiration. I might even go as far as jacking your color also. Mine will have minor differences and probably won't look as sweet as yours but none the less, I will try my darndest.
1972 C10 LWB Cheyenne Super ![]() God Said,"Owning A 10 Second Import Is Like Coming Out Of The Closet, In The End Ur Still Gay" ........................__ ..........._______ |__\__ ..........|__(O)______(O)] |
