Old 03-27-2019, 04:42 PM   #151
Devilman
Re: 1976 CCSB Duramax Project #trucknamedsue
Originally Posted by RADustin View Post
what cooling fan arrangement do you have?
the 2nd gen cummins cooling parts essentially bolt in the 80+ core supports. It doesn't go in as cleanly in the 73-80 supports IIRC.
I haven't got to fan/fans yet, but it'll be some sort of electric setup.
My truck is a 78 and the 2nd gen parts bolted right in same as on my 86 from what I remember.
Devilman is offline   Reply With Quote
Old 03-27-2019, 07:19 PM   #152
rennat_2006
rennat_2006's Avatar
No the 06 is my personal truck. The swap truck is one im doing for a friend, he bought motor and trans with like 75k out of a totalled truck back in like 2010
1972 C10 cheyenne super -350/th350 Wifes truck
1971 Nova- 6.0l with some goodies and a t56, 98-02 camaro brakes all around, tubular control arms, etc
2000 zr2 blazer- rock crawler offroad toy, one ton axles and lockers front and rear.
2006 2500hd- 500hp duramax/built allison trans,traction bars, and some other goodies.
rennat_2006 is offline   Reply With Quote
Old 06-07-2019, 11:32 PM   #153
83GMCK2500
How's Sue doing these days?
Devin
1983 GMC High Sierra 2500, 4x4, RC/LB, 400 S.B., SM-465, NP-208, Corporate 10 bolt & 9.5" 14 bolt
1996 GMC Sierra SLE 3500 DRW, 4x4, EC/LB, Vortec 454, NV-4500, BW-4401, AAM 925 & AAM 1050
1997 GMC Sierra SLT 1500 4x4, Z71/F44, EC/SB, Vortec 350
My Introduction with my '83s History
New Daily, the '96
83GMCK2500 is offline   Reply With Quote
Old 07-09-2019, 11:10 AM   #154
RADustin
work hasn't stopped, just the updates.
I really need to update everything. I'll be working on that.
1949 Chevy 3100 P/U
http://67-72chevytrucks.com/vboard/s...d.php?t=302780
1976 GMC Sierra Classic C35 CCSB
http://67-72chevytrucks.com/vboard/s...25#post8188825
RADustin is offline   Reply With Quote
Old 07-09-2019, 03:12 PM   #155
RADustin
here we go- this should catch up to mid Jan. I'll make a few more updates, a few weeks progress at a time so it's more manageable.
left off assembling the frame. To match the coil springs, I sprayed a few pieces here and there gloss silver. So the frame and frame pieces are semi gloss black, 4 links and axles are gloss black, and accents silver.
started machining on the rear hubs to change the bolt pattern and hub diameter to be all Ford pattern and match the front unit bearings.
skimmed the OD, pre machined and pressed on piece of DOM, final machine DOM.
designed transfer fuel pump mount. It's 3D printed plastic and a stainless clamp.
I actually finally got my own 3D printer around xmas time. one of the first useful things I printed was these shock shaft jaws. I back filled them with resin so they are strong. Used them to revalve the rear shocks.
One of the last fabrications for the frame was a crossmember under the back of the cab. I needed extra clearance than the stocker because the transmission and tcase are so long and high up. Had to make crossmember also clear exhaust.
powdercoated and installed-
made the gas tank sump and draw straw/return. I cleaned inside of tank from lose coating before assembly.
for the fuel sender on the primary tank side, its installed without the sock since the 3/8" feed is now a feed from the transfer pump. The 1/4" line is a return from lift pump. I also checked the checked valves and didnt like their flow, so I ripped it out and will use an external ball check.
more assembly- sway bar is dodge 2500 application and from hellwig. its adjustable on 3 positions. I'll be starting at the softest.
dropped engine in-
changed lift pump from crap CP4 to a Fleece CP3K.
installed fuel tank. Painted silver for accent. Bottom is textured and painted silver.
shortened oil dip stick tube, and changed end.
since I'm converting to all LB7 cooling parts, I had to swap out a bunch of LML ones for LB7-LMM.
this is why- reference this pic for later, stock LML cooling- notice height over alt-
The coolant neck needed a custom foot to work-
the water pump difference. LB7 on left(top), LML the other one. I swapped LB7 outlet to LML housing.
rear hitch got powder coated. Has integrated air fitting for tools and electrical(not really shown). I 3D printed a cap for the air fitting with snap on feet.
body work on passenger fender, in poly primer-
and urethane-
I'm using the cab venting system from the 2014. So I put the vents in the rear wall of the cab and will fill the ones in the doors.
I'll keep working on getting yall caught up. Lemme know if I skipped over something too quickly.
1949 Chevy 3100 P/U
Old 07-09-2019, 03:58 PM   #156
Low Elco
Daaaaaaang! This is gonna be too awesome. This truck stuff is cool and all, but we'll need more info on the puppy.
Low Elco is offline   Reply With Quote
Old 07-09-2019, 05:33 PM   #157
Devilman
I've said it before, I hope you're making duplicates of everything for when I drop my truck off with you 👍🏻👍🏻
Old 07-09-2019, 05:39 PM   #158
buffydores
buffydores's Avatar
Just utterly amazing.
Old 07-10-2019, 12:24 PM   #159
daddyjeep
daddyjeep's Avatar
I was thinking the same... lol
85 K30 crew cab dually - Project http://67-72chevytrucks.com/vboard/s...d.php?t=694939
87 Wrangler Rock Crawler - Reason for the project http://www.wranglerforum.com/f330/da...ld-122601.html
04 1500 crew cab
http://67-72chevytrucks.com/vboard/s...d.php?t=786514
daddyjeep is offline   Reply With Quote
Old 07-10-2019, 01:11 PM   #160
rgunlock
rgunlock's Avatar
You take the term "truck build" to a whole different level. Everything is looking great (and beefy)!
Rick
78 GMC K15 SWB, 350/NV4500/NP205/4.10s Project Hazel
71 GMC C25 350/TH400 - Project Angie
59 Chevy SWB Stepside (next in line? Not sure now )
2001 GMC Sierra K2500
rgunlock is offline   Reply With Quote
Old 07-15-2019, 04:00 PM   #161
RADustin
Thanks, my mistake for not introducing her. Her name is Penny, Golden Retriever, 10.5 months old(born Aug 30th). She was just a few months in those pics. She's been a hoot. That particular night at the shop was good. I kept 'losing' tools while she was 'sleeping'. Come to find out she was retrieving them back to her bed for safe keeping. I found them all when I was packing up to leave for the night.
that can definitely happen. I'd rather do a full frame though. Easier, cheaper, faster, better.
Thanks!
my mistake! I'll get some more updated pics of her, only about 45lbs. so real small. Perfect size.
Thanks bud!
I have more pictures uploaded on my laptop. I'll get them posted shortly.
1949 Chevy 3100 P/U
Old 09-12-2019, 06:40 PM   #162
GMC Guy
GMC Guy's Avatar
utterly amazing progress so far! I love the cab vents, had that idea years ago but never executed. My thought was that it would help the doors close easier with the windows rolled up.
Greg
1974 GMC
1/2 Ton SWB Fleetside
L33 5.3/4l65e
.................__
............._____l __\__
..............l_(O)_ l___(O)]
GMC Guy is offline   Reply With Quote
Old 09-16-2019, 12:07 PM   #163
aggie91
I'm just glad to be here!
aggie91's Avatar
RADustin - its been two months, we need updates!
Karl
1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues)
http://67-72chevytrucks.com/vboard/s...d.php?t=372424
The LST Challenge:
http://67-72chevytrucks.com/vboard/s...=1#post7812257
Korbin's 1st Square: "Sunburn"
http://67-72chevytrucks.com/vboard/s...d.php?t=418618
1985 GMC Sierra: "White Trash", Korbin's 2nd now...
http://67-72chevytrucks.com/vboard/s...d.php?t=632305
Henry - 1984 Chevrolet, Owen's 1st Square
aggie91 is offline   Reply With Quote
Old 03-19-2020, 10:15 PM   #164
Indyfab
Indyfab's Avatar
What ever happened to this project?
Indyfab is offline   Reply With Quote
Old 03-23-2020, 10:26 PM   #165
83GMCK2500
It's still under construction, I'm following him on instagram and have seen recent updates. I really hope he has time during this quarantine to update this thread with the latest updates.
Devin
New Daily, the '96
Old 03-26-2020, 11:06 AM   #166
RADustin
yeah let me work on some updates. Things are moving along.
1949 Chevy 3100 P/U
Old 03-30-2020, 08:43 PM   #167
87max
87max's Avatar
Glad you ditched cp4 better to play it safe. Looking good ��
87max is offline   Reply With Quote
Old 03-31-2020, 02:45 PM   #168
LT7A
That would be cool. I have only a short list of things that I marvel at. But this truck is on it.
Old 04-01-2020, 10:06 AM   #169
Hart_Rod
Hart_Rod's Avatar
Pretty incredible build,
Hart_Rod is online now   Reply With Quote
Old 04-03-2020, 04:24 PM   #170
STOCKISH
Formerly- 1972SuperCheyenne
STOCKISH's Avatar
Wow, absolutely amazing work so far. Keep at it!
--Josh
Old 08-29-2020, 06:44 PM   #171
buffydores
buffydores's Avatar
We need an update amigo.
Old 08-31-2020, 12:26 PM   #172
aggie91
aggie91's Avatar
5 months with no updates? Come on man we need pictures!
Karl
The LST Challenge:
Old 08-31-2020, 05:24 PM   #173
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
You sir are building a piece of art! I'd like to get access or find a guy to have all the cool tools to be able to make one off parts as you have. Very nicely done!
Ryan
1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread
1972 GMC Sierra Grande Longhorn 4x4
1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed
1972 C10 Suburban Custom Deluxe
1969 Chevy milk truck
1971 Camaro RS 5.3 BTR STG3 Cam Super T10
1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project
Tired of spark plugs? Check this out.
Dieselwrencher is offline   Reply With Quote
Old 09-22-2020, 10:28 PM   #174
jadedbird
jadedbird's Avatar
to get the 4x4 tunnel in and effectively convert my 2wd cab to a 4x4 cab, I started by laying the weld in half in and marking around it.
then I offset the marker line with tape to make the cut line. also mapped out the front bolt in half.
cut out the rear half and cleaned the bottom of the lip. This was terrible work. I use weld thru primer on the weld in parts lip and the cab side lip to help prevent rust. I'll also seam seal everything later on.
drilled for plug welds and celco'd in the weld in half from the bottom.
welded in. I perfer to TIG the rosette welds so I can heat everything up, fill, then keep the heat on letting it all flow. Also cut front half. I didn't cut front and back out of cab at once to keep as much material in there at all times.
test fit front bolt in piece.
Then I was able to test fit the cab. It fits perfect. I'm very happy. The ride height is a little low for what it'll be final, but its close. and ofcourse the final tires will be bigger.
Where did you get the back half of the 4x4 tunnel?
I need to make my 2wd floor a 4wd so the transmission will fit.
jadedbird is offline   Reply With Quote
Old 09-23-2020, 06:06 AM   #175
buffydores
buffydores's Avatar
So satisfying to see your updates.
