Old 01-26-2012, 04:01 PM   #176
aggie91
I'm just glad to be here!
aggie91's Avatar
Re: Project Goldilocks, '66 C10 SWB BBW Build
Here is another link for performance parts for the 250 inline 6.
http://www.cliffordperformance.net/
Looks like they only have a split header for the 250. You could fab your own 6 into 1 header. on the 250 there IS 6 ports, but ports (2 & 3) and (4 & 5) only have bolt holes for the flange on the outter edges of the ports and not between them. If you look at the head and the gasket, those pairs of ports are divided by about a 1/4" of material making them separate ports.
The cast split headers on the stovebolt web site look like 4 ports on the outside, but I bet they are split on the inside...
I use to have a 6 in mine, made 250 hp easy. You could build 300 hp and still be steatable with a standard trans...
Karl
1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues)
http://67-72chevytrucks.com/vboard/s...d.php?t=372424
The LST Challenge:
http://67-72chevytrucks.com/vboard/s...=1#post7812257
Korbin's 1st Square: "Sunburn"
http://67-72chevytrucks.com/vboard/s...d.php?t=418618
1985 GMC Sierra: "White Trash", Korbin's 2nd now...
http://67-72chevytrucks.com/vboard/s...d.php?t=632305
Henry - 1984 Chevrolet, Owen's 1st Square
aggie91 is offline   Reply With Quote
Old 01-26-2012, 07:25 PM   #177
theastronaut
theastronaut's Avatar
Originally Posted by McMurphy View Post
I think I did that to you along the line of 6 cylinders into one exhaust tube, not necessarily 6 ports. I am glad someone else remembered the Stovebolt site, I could not recall it at the time I made my posts.
I cut my hood support in the front last weekend as well, like what you are talking about for forced (ram) air.
Cannot wait to see how you do yours!!
Sweet! How much faster does it go now?!? I'm thinking of some sort of sheetmetal duct work and airbox that seals down on the air filters.
You're right, I was looking at dad's 292 from about 20 feet away when I was posting and only saw the four exhaust legs on the manifold. No problem making my own headers if I need to. The guys in brazil are getting 300+ hp at the wheels, the one guy I posted vids of is getting 373hp at the wheels with 15:1 CR and methanol!!
theastronaut is offline   Reply With Quote
Old 01-26-2012, 09:24 PM   #178
65Pickup
65Pickup's Avatar
Pump fuel will probably be the limiting factor, the turbo will more than make up for the breathing limitations of a straight 6. I can't wait to see your progress, very cool stuff.
65Pickup is offline   Reply With Quote
Old 02-05-2012, 06:31 PM   #179
hill64step
Nice build thread! I texted you last year about the extra bbw cab you had for sale, and I think I still have your number saved in my phone. I'm originally from Abbeville. I was looking through your posts and I think I recognize the place in some of your pics. Do you work at the place behind the high school right off of the 28 bypass? I remember taking a 50 Pontiac Chieftain convertible there to have a windshield put in when I worked at John's Rod Shop. After I left John's I worked at the Line-X right there across from the high school on 28 bypass.
64 Stepside.. A work in progress..
hill64step is offline   Reply With Quote
Old 02-06-2012, 11:54 AM   #180
theastronaut
I'll use an electric pump and run the line thru a gutted stock pump. Best of both worlds.
That's us! I got the bed strips for my '66 from John, and had the bed in the blue '65 sprayed at that Line-X. Small world!!
Old 02-06-2012, 02:31 PM   #181
clemdaddy
clemdaddy's Avatar
fantastic work... and well written thread too.
man, i'm enjoying your build. and thanks.
clemdaddy is offline   Reply With Quote
Old 02-06-2012, 07:43 PM   #182
McMurphy
McMurphy's Avatar
I think he means standard gasoline you get at the pump.... Only so much you can legally do to raise the octane in that stuff. After that you are no longer street legal if I am not mistaken.
For my ram air I am thinking of a cowl induction not dissimilar to the old GTO RAM III and RAM IV but with one of those dog eared Oldsmobile air intakes.
Fun times !!
Michael McMurphy
My 66 Stepside
My 64 Tow Truck
My 66 Tempest
Table Of Contents Added to Page1
McMurphy is offline   Reply With Quote
Old 02-06-2012, 08:21 PM   #183
65Pickup
65Pickup's Avatar
[QUOTE=theastronaut;5170017]I'll use an electric pump and run the line thru a gutted stock pump. Best of both worlds.
Thanks McMurphy I am referring to octane, 93 pump gas will limit the horsepower for a street ride. Race fuel or octane boost if the compression is too high to hit the upper horsepower. I'm no builder, just what my builder told me. Do you have a way around that, or does the turbo compensate for the pump gas?
Old 02-06-2012, 09:52 PM   #184
hill64step
Thought I recognized the place. I'd love to check out your project sometime when I'm back down that way. I need to get down there within the next few weeks to get some work done on mine(It's at my parent's house in Abbeville). My frame is sitting outside in primer, and I've got to get it painted before it starts to rust lol.
Old 02-07-2012, 01:00 AM   #185
theastronaut
Glad you're enjoying it!!
Fun times !!
I did misread that as "fuel pump" instead of pump fuel. . Can't wait to see what you come up with for your ram air system, sounds like its going to be awesome!
We have 105 octane E85 ethanol/gas blend at nearly every station around here and it's a good bit cheaper than regular 87 octane gasoline. It only has about 70-80% of the thermal energy that gasoline has, so it has to be jetted richer to compensate. It uses more fuel that way but since it's cheaper the cost per mile should be about the same. Since its 85% alcohol it also runs way cooler than gas does, so it helps the engine to run cool even with way high compression. For now I'll use three two barrel Dellorto carbs or triple throttle body efi. A turbo isn't out of the question but that would be way down the road after everything else is done and sorted out.
Let me know when you're in the area and I'll give you the grand tour My frame is outside too so it's gotta be sandblasted again since its already started rusting.
Old 02-07-2012, 03:10 AM   #186
65Pickup
65Pickup's Avatar
Aaaah the E85 didn't consider that, we don't have it here in canuck ville. I got into straight sixes when I had a '48 Chev Coupe, so I'm looking forward to your progress.
Old 03-08-2012, 11:32 PM   #187
theastronaut
Well, it looks like it'll be even longer til I get started back on Goldilocks. The engine in my daily started knocking so I've got to fix that now. I got the engine out tonight and it's torn down to a short block, hope to have it back together in a few weeks, depending on the extent of damage and the time it takes for the trip to California and back for machine work. It's getting harder and harder to find quality parts for VW's and even tougher to find shops that know how to work on them. I'll try to get started back on the frame while everything is at the machine shop, the symptoms of C10 fever are still in full effect and I need a good dose of project progress!
Old 03-09-2012, 12:17 AM   #188
MalibuKasey
Artist
MalibuKasey's Avatar
or.... more cowbell!
66 Chevy C10 283ci~cough~ SBW Fleet Buttercup '66
MalibuKasey is offline   Reply With Quote
Old 03-09-2012, 12:49 AM   #189
theastronaut
Check your email!!
Old 03-09-2012, 01:28 AM   #190
MalibuKasey
Artist
Your killing me smalls!!
Old 03-16-2012, 11:53 AM   #191
theastronaut
Ok, to keep everyone "in the know", I'd emailed MalibuKasey a link to a post on here about some KILLER custom billet 18x8 and 18x10 wheels that look just like stockers, even down to the rivets on the backside! I've been drooling over these things since they were first posted, but the price tag is, umm, "steep" to say the least. I'd have to sell Goldilocks and my VW to be able to afford them!
Details here:
http://67-72chevytrucks.com/vboard/s...8&postcount=43
Old 03-16-2012, 11:58 AM   #192
theastronaut
The VW knock turned out to be an easy and cheap fix, it was just a broken cam thrust flange. It didn't tear anything else up so no machine work needed, and only about $150 in parts to fix the damage and upgrade so it doesn't happen again. That means more cash left over for Goldilocks. I should be picking up a T56 soon so I can get everything mocked up.
Old 03-16-2012, 02:52 PM   #193
likaroc13
Rollin' Old Skool
glad to hear about the Beetle...kinda wish i still had my '63, but with all the traffic around here i'll stick with my automatic S-10 (i'm no manual trans. expert, ha)....and that's interesting about the wheels...i subscribed just so i can keep up with whatever updates are made...but kinda like Scoti, it looks like i'll be sticking with 15's, lol
Phillip
My Build threads:
1966 Chevy C-10 "Black Betty"
Pics:
Previous Rides:
Old 03-16-2012, 04:30 PM   #194
theastronaut
Yeah, I'll probably stick with my stock 15's until I figure out what I'm going to do about wheels. I eventually want to go with bigger brakes that will make bigger wheels necessary though. The 12" discs it has now already require a 1/4" spacer to clear the 15's. The Titan rims aren't going to work after all since the offset is all wrong and no way to fix them. I'm kind of itching for lightweight 18/19" forged three peice wheels but I'd really rather have something more original/classic looking.
I don't think I could drive an automatic daily, I'd go crazy! Our whole family only owns one automatic car, so I grew up driving stick and still love the extra driver interaction and the ablity to always to be in the right gear at the right time- something an auto can't always do.
Old 03-16-2012, 09:06 PM   #195
likaroc13
Rollin' Old Skool
yeah, i guess if i had grown up around manuals i'd be more fond of them...i know lots of people enjoy shifting gears....my wife used to drive a stick in high school, and she loved it....some pics of my old beetle:
http://smg.photobucket.com/albums/v6...20VW%20Beetle/
Phillip
My Build threads:
Pics:
Previous Rides:
Old 03-17-2012, 10:43 PM   #196
McMurphy
McMurphy's Avatar
I am planning to go manual trans in mine too!!
Michael McMurphy
My 66 Stepside
My 64 Tow Truck
My 66 Tempest
Old 03-24-2012, 03:45 PM   #197
pdxhall
pdxhall's Avatar
I've been following you build and I would like to know if you ran into any issues when you flipped the center crossmember? I was considering buying a new dropped crossmember but I might change my mind after seeing what you did. I've seen builders just flip the trailing arm mounts (which is a lot of rivets to remove!) but not the whole crossmember.
pdxhall is offline   Reply With Quote
Old 03-24-2012, 08:18 PM   #198
theastronaut
If I remember right, there's 12 rivets to remove the T/A crossmember. There's doubler plates on the bottom of the frame rail that have four rivets each. I already had the crossmember out of it so it was easier to flip it than take the T/A mounts off. If you take the mounts off though, you can easily fab brackets that are adjustable. I don't have my trans in yet to check for driveshaft clearance at full drop, but I'll probably have to raise the top of loop to clear the shaft. The biggest reason I had it out was I wanted to get rid of the rivets and weld the crossmembers back in to get rid of flex. It would probably be easiest to just take the brackets off if your's is already together.
Old 03-24-2012, 10:44 PM   #199
theastronaut
Since there no physical progress being accomplished, I'll post the "mental progress".
When I bought the truck it came with an old Esso filling station key chain, and the previous owner told me the history of the truck. It was bought new by a guy that started working at our local downtown Esso station when he was in high school. He eventually took over the station when the station owner retired. I've had a few guys tell me that they remember the truck being parked at the station, and usually inside if there was room for it. When he passed away (around '08) a family member got it and kept it until our mechanic bought it.
So I'm thinking about doing some door art (?) with an Esso logo and the old address and phone number. I don't think I want it to cover a large part of the door though, like most guys have on their doors. Or I may not even put anything on the sides of the truck and just use the corner of the tailgate. Either way, I want to somehow get an Esso logo and the "Thomas Esso Station" name on the truck somewhere but do it more tastefully than the typical door art.
Old 03-28-2012, 06:18 PM   #200
theastronaut
Finally some real progress!!!!
I pulled the column out today after work and started shortening it. Decided to go three inches since that seems to be about as much as you can shorten it, and I don't like being close to the steering wheel when driving. I put about 100 miles on the blue '65 I restored this weekend and the first thing I noticed was how close the steering wheel was.
I disassembled it and stripped it to bare metal with a DA to have a clean starting point.
Decided where my first cut would be. It would have been easier to move the cut back a little but I wanted to save the "M" in the split of the tube.
I blacked out the area with a sharpie and used a sway bar clamp off my VW for an even edge to scribe the cut line.
Then measured 3" over and made another scribed line, and cut out the middle.
Reassembled on a piece of angle iron to align the two pieces. You can see how the clamps help make an even cut for a tight joint. I also beveled the edges slighly for better penetration.
Welded up.
And the welds ground down and smoothed with the DA. I cut out the groove where it was welded along the seam with a triangle file so the weld area matches the split along the length of the tube. Nobody will ever see it but that kinda stuff drives me crazy if I know its there.
